smalll block/ big block?
Old Nov 28, 2004 | 06:26 PM
2000 green hornet's Avatar
2000 green hornet
Default smalll block/ big block?
What is the difference between a small block and a big block motor? Is it something more than the size of the displacement of the combustion chambers? Does a small block or a big block have some type of advantage in the amount of power they make? Andy
Old Nov 28, 2004 | 06:59 PM
hubes's Avatar
hubes
the big block is basically a big small block, it can have a much larger displacement and can therefore make a lot more power, they also weigh more. the small block has a 4.4 inch bore spacing, whereas a big block has a 4.84 inch bore spacing. also the old small blocks had a deck height of 9.025 inches, and the big blocks have either 9.8 or 10.2. the new gen 3 and gen 4 small blocks have a 9.24 inch deck height. hope this helps
Old Nov 28, 2004 | 08:17 PM
AU N EGL's Avatar
AU N EGL
Arn't most of the new Chevy LSx small blocks aluminum vs the big block is cast iron? Big weight difference.
Old Nov 28, 2004 | 09:36 PM
hubes's Avatar
hubes
you can get aluminum big blocks, but theyre expensive, oh, and btw, it would be awful hard to put a big block in a C6 if thats what your thinking
Old Nov 28, 2004 | 10:46 PM
jschindler's Avatar
jschindler
So what would be a big, big block?
Yeah, I guess a 540 or 572. Maybe something from Sterling!
Sorry, I just had to bust your ***** over that one!
Old Nov 28, 2004 | 10:50 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Already been done:
http://forums.corvetteforum.com/showthread.php?t=923437
Old Nov 29, 2004 | 10:08 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Originally Posted by BW1
If I'm not mistaken, the 427 Andy refers to is still a small block.
Also World Products has a 454 small block.
Old Nov 29, 2004 | 10:33 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
the big difference is the external diamentions because even the 7.0 liter gen III engine is considered a small block because the external diamentions are the same as the 5.7 liter use in the C-5 corvettes
To smalll block/ big block?
