When to do the first oil chg?
Old Jan 11, 2005 | 10:19 PM
portmgr198's Avatar
portmgr198
Default When to do the first oil chg?
I now have 1100 miles on my C6. When should I do my first oil change?
Old Jan 11, 2005 | 11:45 PM
jkress's Avatar
jkress
Too late mate, I'm dumping at 100, 500, then every 3K. Oil is cheap, engines are not.
Old Jan 12, 2005 | 01:49 AM
cet001's Avatar
cet001
Just follow the instructions in section 5-18 of the owner's manual.
The computer calculates oil life based on several engine and driving parameters, so mileage between oil changes will differ from person to person. Although, if your superstitious or obsessive-compulsive, feel free to change your oil as frequently as you want.
Old Jan 12, 2005 | 04:16 AM
LS WON's Avatar
LS WON
Default What is the oil drain plug size on the 2005 C-6? 13 mm?
Does the C-6 come with a magnetic oil drain plug from the factory? if not is it a good idea to get one?
I don't want to cause any magnetic fields around all of these computers and sensors. I don't want no trouble
Also I heard old school at the first break in do oil change or the first 1,000 miles but on our cars break in is at 500 miles
Old Jan 12, 2005 | 09:16 AM
RaisedInNormanHall's Avatar
RaisedInNormanHall
Default If I was you I'd do it now!
My coupe will definitely not see 1100 w/o a change. I plan to change @ 500 miles and then between 50-25% of life according to the monitor or 3 months, whichever is more frequent. If they recommend you break it in, I recommend you swap it out!
Old Jan 12, 2005 | 01:08 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default The Great Question
We ran a poll on the Gen Board last week. Check it out.
Every car I bought new, I changed the oil before 1,000 mi then every 3-4k after that. I’m sure you’ll get 100 different answers here. I changed at 4,000 with the DIC showing 68% remaining. Projecting out the DIC Oil Change function, I’ll be able to go 11-14k between changes. For your first change, I recommend 2-4,000. Whatever you feel comfortable doing. Much sooner and you’ll extend the period for your rings etc. to seat properly (the real break-in period). Go longer and you’ll impart unnecessary wear. For the first 1,000 mi or so, an engine cranks out some metal. You can see a sheen in your oil when you first change it. Just the material for a change is $40 ($5/qt x 6, and $10 for a filter). As for GM, they’d just say follow your DIC. I’ve done that many times and it’s got me in trouble.
Old Jan 12, 2005 | 01:30 PM
HalM's Avatar
HalM
When the DIC says so...all the objective data I have seen says M1 is up to it (Internet UOA's abound)...
Old Jan 12, 2005 | 01:52 PM
jschindler's Avatar
jschindler
I did mine at about 750 miles. I'm sure you can go until the factory recomendations with no problems (look at the millions of people who do). But cars are my passion, so I change the oil more often than needed just because it makes me feel good.
Old Jan 12, 2005 | 03:37 PM
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
Default Agreed
The feel good thing
Old Jan 12, 2005 | 04:11 PM
thebiggman's Avatar
thebiggman
I did my first one at 1200 miles
Old Jan 12, 2005 | 04:45 PM
LS WON's Avatar
LS WON
Default Will be doing it before or at the 1,000 mile mark
Main concern is with the basic and extended warranties when you change the oil yourself can they pull that void the warranty proproganda on you?
Or the person who changes the oil has to be certified mechanic? Otherwise everyone would be sending their cars in for oil and filter changes.
I looked under the C-6 and to me it looks like an easy change as the access is easy as my dealer charges $100.00 for that very same change.
Old Jan 12, 2005 | 08:41 PM
Shylor's Avatar
Shylor
This is a very uninformed statement. GM's oil life monitoring system is very good, they spent a lot of time finally making something right. Changing the oil every 3k miles is a waste of good oil and is not cheap insurance. Today's oils and engines are much better than those from the 60's, so let go of the old standards. If you must change something every 3k miles, change the oil filter.
Old Jan 12, 2005 | 09:28 PM
archtop's Avatar
archtop
I'm changing mine next monday,that's 3 months.I have 2300 miles,after that its every 3 months or 3k miles.Gm gave me a 2 year 24k miles customer care policy after I b!tched about picking my car up from the dealer with a blown speaker.That means oil and lube every 3 months or 3k miles ,thats their recommendation for a corvette.Oh yeah also includes free tire rotation.
Old Jan 12, 2005 | 09:36 PM
Got Vette?'s Avatar
Got Vette?
why would some suggest to change oil first 500 or 1000... is there some reason?
Old Jan 12, 2005 | 09:59 PM
vetteship's Avatar
vetteship
Good you got something back for the bad speaker. I don't believe their recomendations is a valid one, and you don't need to worry about the lube or tire rotation, your C6 tires are not interchangable and are unidirctional (18"x8.5" front and 19"x10" rear). I would trust the oil monitoring system in the car or once a year as recommended in the owner's manual.
Old Jan 13, 2005 | 01:50 AM
Happihank's Avatar
Happihank
This is my first Vette. Reading the suggestions about when to change my oil. My head is spinning! Mine's at 2100 mi and at 80%. Ive already poured a quart in because the DIC asked to too. The first 2 oil changes are free for me ( I was the Dealers first 6 speed Z51 sale) Change it, not change it? I was going to was gonna wait for DIC to tell me too, but now some of you....change it at 100 miles!
Old Jan 13, 2005 | 07:55 AM
Wayne88's Avatar
Wayne88
To clean any metallic material from the new engine parts.
To When to do the first oil chg?
Old Jan 13, 2005 | 10:21 AM
Zivnuska's Avatar
Zivnuska
I'm confused.
Half the time we are supposed to believe that Dave Hill and his people are geniuses that can walk on water when they are not designing, building and testing our beloved Corvette.
The other half of the time we are supposed to believe that Dave Hill and his people are idiots who don't know enough to put proper maintenance recommendations in the owners manual.
Make up your mind!
Old Jan 13, 2005 | 06:45 PM
LS WON's Avatar
LS WON
Default A visit for a guess what did they break now?
If it ain't broke they will fix it all right.
Old Jan 13, 2005 | 06:48 PM
LS WON's Avatar
LS WON
Default It is easy enough to do yourself
And costs alot less than when they do it so you save time and money and don't have to leave the car there all day for them to listen to your stereo or smoke and eat lunch in your Corvette or go for a sunday ride.
