6 Speed Auto
Old Jan 22, 2005 | 01:07 PM
Vette346's Avatar
Vette346
Default 6 Speed Auto
I know this thread has been posted a couple hundred times on this forum, but with the new STS-V making its debut at Detroit with the 6L80 auto transmission, does anyone know if this will make its way into 2006 model year Vettes or will we have to wait longer? The STS-V will go on sale sometime in the fall as an 06 model, so Im hopeful we will see this transmission finally go into the C6. It is more than able to handle the hp/torque figures from the LS2. If anyone has any info on this I would greatly appreciate it.
-Chris
Old Jan 22, 2005 | 01:32 PM
oklahoma's Avatar
oklahoma
go to gm hydramatic web site and read about x-15 transmission there is a graph showing the 0-60 times and fuel mileage with the 4-65 and the new trans and a statement about deproliferation of diff ratios
Old Jan 22, 2005 | 01:50 PM
Vette346's Avatar
Vette346
What is the exact address for the website, Ive had a hard time finding it on google and yahoo?
Old Jan 23, 2005 | 10:56 AM
oklahoma's Avatar
oklahoma
Default six speed auto
http://www.gm.com/automotive/gmpowertrain/
Old Jan 23, 2005 | 02:08 PM
2000 green hornet's Avatar
2000 green hornet
Default great info. heres the chart
I found the hydramatic website. And was able to copy the chart. I am not sure exactly what it is explaining but i like the performance improvement of 4 to 7 %! And also fuel economy improvement of 1 to 4%. Seems like the future is bright. andy
Old Jan 23, 2005 | 06:12 PM
shopdog's Avatar
shopdog
You have to be careful reading that chart. For a 3.15:1 rear axle, the chart shows the A6 gaining 2.6% economy, but *losing* 2% performance compared to the A4 used now. The A6 only looks good when you compare it to the A4 using the 2.73:1 rear axle. Then economy is nearly the same, but performance is up 5%. But note that's 5% over the A4 with the 2.73:1 ratio, and not over the A4 with the 3.15:1 ratio, which still wins for performance.
Old Jan 23, 2005 | 07:18 PM
bdc6's Avatar
bdc6
2006 will be A6....
Old Jan 23, 2005 | 11:14 PM
2000 green hornet
Default 6 speed automatic performance question
Wow. If the new transmission causes a loss of performance of 2 percent for a 2.6 percent economy gain I don't think it will help the sales of Corvettes with them.
The 2005 models with the four speed automatic will surely hold their value well! GM must know we don't buy Corvettes for economy. It already gets great mileage for it's power. Something doesn't make sense here.
I would think that a 6 speed automatic transmission would have to increase both economy and performance if it is to be desired.
Andy
Old Jan 23, 2005 | 11:23 PM
LS WON's Avatar
LS WON
Default How about the 3 spd. Turbo 400 Trans?
Turbohydromatic 400.
Old Jan 24, 2005 | 01:46 AM
shopdog's Avatar
shopdog
Andy
A more complicated, heavier, and larger transmission, why would you expect it to be better? Perhaps it would be better if you wanted to get better gas mileage while towing a trailer with your Corvette. But with the broad torque curve of the LS2, there's really no reason for more than 4 speeds, and a well chosen rear axle ratio. Never was.
Old Jan 24, 2005 | 04:31 PM
Vette346's Avatar
Vette346
As always, thanks for the info guys. I have to say that a 6 speed is going to give a performance advantage to the car over the A4, regardless of the axle ratio. Look at todays Accords, they run 0-60 in 6.4 seconds with the V6 in part due to the engine, but also due to the fact that it has a 5 speed auto that keeps it within its powerband. Yes the LS2 has an amazing power curve, with more than adequate power at any rpm, yet it still makes more power in certain places than others. Having an 00 A4 coupe with the 2.73 rear, when you nail it going 30-40mph, there is often a slight hesitation as the revs build. Not that the car is lacking in power, but there is a half to full second delay as the car builds up revs. With the A6 it would allow the car more tightly spaced ratios over the A4, and thus better acceleration particuarlly for passing situations. I truly hope that it does make it into the 06 model year, which if it is the case I will hold off buying the C6 until the fall...
Old Jan 24, 2005 | 05:19 PM
eugenee326's Avatar
eugenee326
Default Why would they stick to 3.15 rear?
With the 6 spd auto I would imagine that the rear end ratio could be raised to increase performance substantially. Why wouldn't it be closer to the 6sp manual rear?
Old Jan 25, 2005 | 12:35 AM
2000 green hornet
Default 2 Speed Powerglide Automatics in the beginning
I go way back and remember the 50's Vettes with the two speed Powerglide automatics. Then I think in the 60's they starting offering three speed Turbo Hydramatics or something like that. Probably in the 80's maybe they came out with four speed automatics.
Maybe in the 00's we will see even more speeds. They do become more complicated and i guess heavier and larger, but I would hope they keep the Vette's powerfull engine ever more in the sweet spot of it's power curve as the car speed increases.
I would hope the engineers are seeing a way to give us a performance and economy increase at the same time. Any truck engineers working on a towing package for the Corvette should pack up and go try to tune those Cobras to their advertised horsepower. Ford needs you bad. Those old two speed powerglides were not too much fun from a dead stop takeoff. Once you got to about 30 miles per hour though they really started to roll! Andy
Old Jan 25, 2005 | 04:57 AM
shopdog's Avatar
shopdog
The chart claims a 5% performance boost over a 4 speed with the 2.73 rear. But that's not a performance rear end. Go with the 3.15 rear ratio, and the 6 speed's claimed 5% performance boost becomes a 2% performance loss compared to the current 4 speed.
Old Jan 25, 2005 | 05:08 AM
shopdog's Avatar
shopdog
Because GM Powertrain didn't design the 6 speed to work that way. They chose to give it stiffer low gear ratios instead of giving it multiple overdrive gears (the MN6 has two overdrive gears). So a stiff rear would substantially limit top speed, and hurt MPG.
The way I read the specs for this thing, it looks like it belongs in a truck rather than a performance car. They've given it more low end grunt than the A4 (yet in the Corvette, you're already traction limited on the low end, so more grunt isn't wanted or needed), and the only way to get any top end is to use a really numerically low rear ratio.
It belongs in a truck, one that tows a trailer, because what's needed there is more low end, and high speed doesn't matter, so you can still use a stiff rear ratio. But for a relatively light car like the Corvette, it is all wrong.
Old Jan 25, 2005 | 05:16 AM
shopdog's Avatar
shopdog
Which are basically 3 spds with an overdrive.
That "sweet spot" is awfully broad.
The way I understand it, GM Powertrain's mandate was to reduce the number of transmissions and rear ratios used across the entire GM line. In other words, this transmission isn't special to the Corvette. It looks to me as though it is primarily intended to be of benefit to trucks.
I would say one thing about the old Powerglides, they turned out to be great transmissions for dragsters and circle track cars. They're very light, and can easily be made to be very strong.
Old Jan 25, 2005 | 12:23 PM
Vette346's Avatar
Vette346
Not to in any way doubt your reading of the graphs, I'm hoping that the one you looked at was for a truck application. The new trans is part of a family of six speeds for GMs rwd cars and trucks, sharing something like %65 percent parts comminality, but with different ratios and other tweaks. The one found in the C6 I would think is the same unit found in the new STS-V(440hp/430lb-ft). To quote Csaba Csere from Car and Driver talking about the supercharged Northstar in the STS-V,
"...is coupled to a brand new six-speed automatic transmission, the GM 6L80. With a 6.00 ratio spread between first and sixth gears, this transmission should be able to fully exploit the blown engines broad torque curve while delivering decent fuel economy. The transmission also provides for manual gear selection as well as Cadillac's excellent Performance Algorithm Shifting, which makes the transmission feel at home on tracks and winding roads."
To 6 Speed Auto
Old Jan 25, 2005 | 12:55 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
One should wonder: what are the weight and physical dimensions of this transmission.
Old Jan 25, 2005 | 02:02 PM
LS6v's Avatar
LS6v
If the 6spd offers better performance with a 2.73 than a 4spd, it must have more aggressive ratios. So, I can't understand how a 6spd is slower than a 4spd with a 3.15 rear.... Even though it has to shift a couple more times the shifts should be faster with a smaller ratio spread.
I read that the transmission has an extra clutch to decouple from the torque converter. Allowing quicker and smoother downshifts... could it be decoupling from the torque converter under acceleration as well, then shifting, and re-engaging?
Old Jan 25, 2005 | 02:07 PM
slowtrak's Avatar
slowtrak
Big deal . That means the A6 transmission will get 20.4 mpg instead of 20.0 with the A4 .
