[Z06] LS7 Dry sump diagram
I have been searching for a while now and can't find a diagram of how the LS7 dry sump oil system is routed or how it works. I have just gotten pieces of information.
Here is where I am at:
There are 2 oil pumps in the dry sump system. I know on is behind the front cover but I dont know where the second one is.
The dry sump pulls oil from the sump tank but does the sump get filled with from the oil pan via the oil pump behind the front cover? If that is the case where is the oil pump for the sump tank? Any info would be great. Thanks.
Pro Mechanic
Received 3,952 Likes
here's a diagram to get you started........... do you have a GM Service Manual for your car........
bornloser_182 (03-21-2017)
what Dan said.
Only 1 physical pump with two gearotors in it.
