C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Eldebrock E-force or Procharger??
Old Jun 20, 2014 | 12:48 AM
mikebid15's Avatar
mikebid15
Default Eldebrock E-force or Procharger??
These are my only 2 options since I need a CA carb approved charger for smog. I see the Procharger is centrifugal and eldebrock is modern roots style. I understand roots more low end and centri more high end. I will more than likely use the factory tunes til I find a reputable shop in the Bay Area for custom tune. It will be daily driven and tracked a few times a year. Curios what people's opinions are about which set up would fit the stingray better or anyone who has driven/own either. Thank you
Old Jun 20, 2014 | 01:21 AM
Theta's Avatar
Theta
St. Jude Donor '14-'15
I have yet to see a shop here actually have an E-Force in stock, let alone installed.
We all at least know ProCharger has systems working and on the road with the included tuner.
Old Jun 20, 2014 | 03:40 PM
Callaway Chris's Avatar
0Callaway Chris
Former Vendor
Callaway's patent pending SuperCharger for the new Stingray is 50-State / CARB compliant, and is the only package which has a real powertrain warranty, supplementing the GM Factory powertrain coverage. We are peerless in this regard.
Power, style, and exclusivity - backed by the most powerful warranty in the business! Callaway is powerfully engineered, indeed
We'd be glad to discuss this option with you further - please feel free to drop us a note: info@callawaycars.com
http://www.callawaycars.com/cars/callaway-c20-corvette/
Old Jun 20, 2014 | 05:27 PM
Unreal's Avatar
Unreal
Out of those choices, procharger. Eforce isn't even available yet and no results that I've seen.
Having it tuned will void the carb, then again most places wouldn't pick up on that.
Old Jun 20, 2014 | 05:54 PM
RideZX6R's Avatar
RideZX6R
Any reason ECS isn't on the list? Or a turbo kit for that matter? JW
Old Jun 20, 2014 | 06:19 PM
need4speedmotors's Avatar
0need4speedmotors
Former Vendor
Wow thats an amazing package, I wonder how this drives in comparison to the Z06
Old Jun 20, 2014 | 06:28 PM
Theta's Avatar
Theta
He needs CARB approval, as he put in the original post.
Only a few options for that.
Old Jun 20, 2014 | 06:33 PM
Translator's Avatar
Translator
I read on a post/thread a few months back from Andy that A&A was also working on a 50-state CARB certification for their kit.
Old Jun 20, 2014 | 07:17 PM
Unreal's Avatar
Unreal
My choice would be A&A for carb but you have to wait for them to get it.
Old Jun 20, 2014 | 07:26 PM
Theta's Avatar
Theta
Old Jun 20, 2014 | 09:19 PM
RideZX6R's Avatar
RideZX6R
Reading comprehension > me evidently Doh!
I'd agree honestly. TVS blowers (e-force) are really nice, but ultimately they heatsoak compared to centrifugal blowers and centrifugal will make more top end power
Old Jun 20, 2014 | 09:34 PM
0Callaway Chris
Former Vendor
...TVS blowers are really nice, but ultimately they heatsoak compared to centrifugal blowers and centrifugal will make more top end power
In testing, The new Callaway SuperCharger we designed has virtually zero heat-soak, pass after pass, pull after pull. In fact, the other week, run after run, our temperature variances were within ONLY 3 degrees! Heatsoak is not an issue with Callaway's design.
Originally Posted by Callaway Cars
Callaway's third generation Corvette supercharger system is a completely new design. Callaway engineers developed a new supercharger housing and associated intake manifold for improved airflow and increased charge air cooling capability. Intake manifold runner cross-section and length were tuned for a broad torque band while maintaining excellent peak horsepower. Eaton’s 2300cc TVS rotor pack was selected for its high thermal efficiency, OEM-certified quality, and service-proven reliability. A new triple-element intercooler configuration provides significantly lower inlet charge air temperatures than possible with single and dual element designs. Because of the added volume of the new internals, the supercharger housing itself extends through the hood. Consequently, both conductive and convective heat transfer mechanisms are utilized to remove power-robbing heat from the inlet charge.
Cross-section of new Callaway supercharger design,
illustrating improved airpath and compound intercooling
For example, in dynamometer testing, inlet air temperature increased by less than 10ºF during individual runs, compared to increases of at least 35ºF with other intercooler designs. That means more consistent performance at the track and dragstrip, as well as increased power on the street during summer months. To prevent drive belt slippage, a new 10-rib pulley system has been incorporated. In fact, certain new technical features are significant enough that utility and design aspects of this system are patent pending with the US Patent and Trademark Office.
Old Jun 21, 2014 | 08:39 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Ditto on that! The one that for only 300 more. Has
1. Superoir design uni-brackett stronger and lighter less mass.
Super easy mounting.
Forged pieces the others don't have.
2. Superoir intercooler design. Their's doesn't block the radiator cooling and has a scoup to catch air.. the rest are trying to catch up and copy.
3. Balancer even GM puts a better crank balancer on the new Z.
So does A&A in the kit it's a 600-700 piece at his cost and IS better!
4. NOW Has advanced air straighter insert to make for a smooth Supercharged power.
5. Has hard piping the whole way. Some just have silicon tubes!
You get alot for your money when compared!
He is working to make it better constantly! Great service!
Old Jun 21, 2014 | 09:11 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Oops ! Wrong picture!
Old Jun 21, 2014 | 12:42 PM
Q8 c7's Avatar
Q8 c7
Does edelbrock intercooler fit this way also?
Old Jun 21, 2014 | 12:59 PM
kp's Avatar
kp
I'm a procharger guy, the company and their head units treated me very well for years. Even in the turbo world I did very well with a D1SC and F1A and a 347 inch LS1 in class engine and blower size limited 10.5 and 275. Plus a few 9-10 second street cars..
But I put a 2.3 TVS (same as the edelbrock blower) on a stock 2011 mustang auto, with just the blower, tune and drag radials it was a 10.70/130mph car. Thats a little 5 liter engine at 4000lbs.
Looking at the C7 offerings, with an auto (if I didnt want to swap torque converters) I would probably do the edlebrock if ETs were a concern and that was the only mod I was going to do. Its expensive and not as easy to install, but the C6 Edelbrocks I have seen were very OE quality.
The Procharger is cheaper, easier to install and most likely a little lighter as well. But will need a torque converter to realize the true ET potential, the lower cost would offset the converter but some dont want to dive that deep into it.
If its a manual you can make your choice, either one will provide enough power to give you clutch and/or drivelibe problems if you take it to the track and try to get a decent ET with sticky tires
But for just driving around with a manual I would probably pick the procharger, linear power increase, easy to tune. No air to water pump/hoses to mess up, less heat soak/faster inlet temp drop with the air to air as well.
Andy makes some nice stuff, so does ECS but the CARB thing is the killer.
IMO its best to wait it out and see some results, its a lot of money to spend to regret a decision down the road. Wait for some real results and user feedback..
Old Jun 21, 2014 | 01:50 PM
Q8 c7's Avatar
Q8 c7
Well said,thanks for the information
To Eldebrock E-force or Procharger??
Old Jun 21, 2014 | 06:07 PM
Stunt's Avatar
Stunt
I believe the E-force kit was just released.
See this thread in c7 general:
http://forums.corvetteforum.com/c7-g...k-e-force.html
Old Jun 21, 2014 | 06:55 PM
Z_Rocks's Avatar
Z_Rocks
Chris, does this require new Hood?
I would go with this package for a total performance and warranty.
Old Jun 21, 2014 | 09:43 PM
0Callaway Chris
Former Vendor
We modify the original hood with our trim ring to allow the supercharger to fit through, nicely. It's quite tidy, and the supercharger is really neat to see through the hood
Thank you for your post - for power - and total performance which we've delivered for nearly 30 years on Corvettes, and backed by a real powertrain warranty, we appreciate your consideration.
