C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Bigger SuperCharger
Old Jun 10, 2016 | 10:58 AM
  #41
officermartinez's Avatar
officermartinez
Originally Posted by Bucknut2006
Well, I think that sold me on the upgrade. Already have the Z06 pump/injectors and the largest meth nozzles. Did you step up to a 3 nozzle system? I know the F1X guys tend to do that.
Glad to have helped a tiny bit in you making your decision! We did not do the triple nozzle setup. Instead, we settled on a dual nozzle setup with (2) 15# nozzles and the maxing out the meth controller.
So, aside from the upcoming Z06 injectors and boost a pump, the next phase of "upgrades" will focus on non engine components.
Old Jun 14, 2016 | 10:39 PM
  #42
black_c7's Avatar
black_c7
pretty nice numbers, i see that it ran almost to 7300 rpm is that safe ?
Old Jun 22, 2016 | 10:21 PM
  #43
Bucknut2006's Avatar
Bucknut2006
How is the new setup treating you? Any issues?
Old Jun 23, 2016 | 11:27 AM
  #44
officermartinez
No issues but we've been on our beach vacation for the past two weeks. Car ran solid when we drove it prior to going on vacation.
Old Jun 25, 2016 | 11:11 AM
  #45
Steven Popham's Avatar
Steven Popham
St. Jude Donor '16
So what caused it to fall at 5600? Mine (was) doing the same thing. I'm asking for all the numbers and nobody is wanting to provide details so I'm heading up to lethal right now to find out maf volume and see what the dyno chart looks like.
We followed you and went to a 416, low pressure fuel pump, sump, bigger lines e85 sensor, ysi and 2,nozzles but they are saying 825-835 is what they are getting. I'm going to call Christian and drive it to Dallas at the end of July
Old Jun 26, 2016 | 09:40 AM
  #46
C7&7's Avatar
C7&7
Take the car to Steven at LMR. He'll dial it in.
Old Jul 22, 2016 | 10:05 AM
  #47
officermartinez
Still a tiny issue here. We arrived home from our vacation. Since then, we've only been on ONE W.O.T. run. I'm not sure exactly what RPM we were at but it was somewhere in the mid to high 5000 rpm range, the car felt like it was running out of fuel (which I am pretty positive that's what is happening). After reading things about the boost a pump, I'm not convinced that we should go that route. Is there a more suitable solution? Hoping to get this tiny gremlin nipped in the bud before WANNAGOFAST @ Sulphur Springs in November.
Old Jul 22, 2016 | 10:13 AM
  #48
Steven Popham
St. Jude Donor '16
Be careful on that run, sulphur was the scariest go fast event I've driven on. The powder sand on the road made it feel like ice, I backed out of it at 155ish because the car was skating around.
After my fire I don't think im going to do a meth dependent car again
Old Jul 22, 2016 | 10:16 AM
  #49
C7&7's Avatar
C7&7
You didn't upgrade the low pressure side at all? Stock in tank pump? First step will be to find it where you're losing fuel, on the low pressure side or the high pressure side, or both. I know Joe at CPR has done many low pressure side secondary systems, but as for the high pressure side if you're using lt4 HPFP and injectors that's all we have right now. Options are a lot more meth or a direct port system on top of the DI system. Congrats you've pushed the fuel system to the limit.
Old Jul 22, 2016 | 03:37 PM
  #50
officermartinez
Thanks Steven! Do they not prep the strip? At those speeds, I would agree about letting off! Nascar uses commercial trucks with blowers on them to help clean debris / dry the track. Surely those type of trucks could be rented out or used to somewhat prep the straight away. As for meth, my wife and I are very much aware of your recent tragedy!
Just got my quote from James over at Deatschwerks about 2 hours and 45 minutes ago. Our high side seems to be mostly "OK" but the low side cannot keep up for sure! Would sure love to see more injector options but things are pretty limited at the moment. Yep, we cannot go any further with our current fueling capabilities.. sigh
Old Jul 22, 2016 | 09:43 PM
  #51
Bucknut2006
Since WGF uses runways, they are not prepped. It's also more of a roll race and the launch is just a small part.
Old Jul 23, 2016 | 01:12 AM
  #52
officermartinez
Ugh.. Hmmmmmmm, might have to reconsider my wife hitting the track in our C7 at 1200hp at full throttle!
Old Jul 23, 2016 | 06:34 AM
  #53
on3wego's Avatar
on3wego
year I was at sulphur Springs last year. it was a mess. I waited till after the lunch period and let other people run to help blow off some of the dust. I still managed to get 171.36 spinning at the beginning of course lol
Old Jul 23, 2016 | 10:42 AM
  #54
C7&7's Avatar
C7&7
You could do direct port!
Old Jul 23, 2016 | 04:03 PM
  #55
officermartinez
What kind of RWHP numbers are you putting down now?
OMG.. my wife would probably kill me! ..Don't give me any ideas.
Old Jul 23, 2016 | 10:41 PM
  #56
C7&7's Avatar
C7&7
Do it! You'd never have fuel issues again if you upgraded the low pressure side too
Old Jul 25, 2016 | 09:51 AM
  #57
officermartinez
Well.. with only a small fueling bug on the top end at WOT, I think we are going to call it "good" for our C7. It's well above the 1000 hp mark. I've got another project that has been 10+ years in the making. After speaking to my high hp hotrod connections, I'm officially in the market for a brand new racing setup for my 1995 4th gen T/A. The car has been restored by yours truly. I have all new parts for the car that I'm just going to have to sell off because I am going a different route with it. I originally built the car to be a weekend cruising car (355cid, beefed up internals, LT4 hotcam, built 4L60E trans, etc). It has exactly 0 miles on that motor and trans. After much discussion, I'm leaning towards a 400cid (or slightly bigger) twin turbo (or would consider a big supercharger) setup. I'm trying to get my ducks in a row. Looking to be around the 2000 crank hp number.
Old Jul 25, 2016 | 06:27 PM
  #58
C7&7's Avatar
C7&7
Man... I wouldn't call a fueling issue on the big end at WOT a "small bug"... I'd be scared to get into it at all.
