C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Best 2 inch header for supercharged application
Old Apr 21, 2016 | 06:53 PM
mowe's Avatar
mowe
Originally Posted by Silverboost
This is the first post I have seen that shows a loss with a 2" header on a FI C7. Of course the conditions could have been different also, temps, diff dyno, tuning, ect. I have actually seen posts with gains from 2" vs 1 7/8" on lightly modified C7's. So on goes the 1 7/8 vs 2" debate.
You don't lose on the top end. You lose all under the curve. That's what people fail to realize. In the quarter mile and street driving all that under the curve power and tq gets you moving.
Old Apr 21, 2016 | 08:01 PM
Silverboost's Avatar
Silverboost
I am with you on the low end loss. I am sure it does move the curve. I am at 800rwhp so any more low end is pretty much useless in my application. What I was questioning was the loss of top end power.
Old Apr 21, 2016 | 09:17 PM
blown81bu's Avatar
blown81bu
i think im flying for 1 3/4"...135 on 8lbs of boost
i wouldnt put 2 or larger ...fitment is great to
Old Apr 21, 2016 | 09:26 PM
Seannyc's Avatar
Seannyc
You are goin fast
Should I go 1/34 stepped 1/78 long tube headers from Lg
Or full 1/78 Longtubes
They say straight 1/78 will be better for s/c and the stepped will lose only a bout 8hp up top but gain more down low the stepped turns in to a long tube 1/78 I don't see any reason to not go with the stepped
While still havin top end from the 1/78
If it turns into a long tube
My goal is 700 to 750+
Old Apr 24, 2016 | 02:31 PM
3 Z06ZR1's Avatar
3 Z06ZR1
From my experience.
I would use 2 inch before 1 3/4 which is better for an Ls1.
I used 1 3/4 and they ran friggin hot and I gained power and cooler going to 1 7/8's .
The Blown 6.2 is best with 1 7/8's or 2 inch.
Old Apr 24, 2016 | 04:43 PM
blown81bu's Avatar
blown81bu
Originally Posted by 3 Z06ZR1
From my experience.
How u figure..?
I went 135 on 8lbs..
Try this
1 3/4 up to 700 rwhp
1 7/8 up to 900 rwhp
2" 900 and above
Horsepower addicts diid testing to with lt1 and made no gain w 1 7/8 over 1 3/4 700 or less and dont even use headers on z06s
Also i had an ls3 22lbs boost 900 rw w 1 3/4..went to 2 and no gain
Theres not much power in header size period!..nothing ur gonna notice on a drag strip
Old Apr 24, 2016 | 06:13 PM
algZO6's Avatar
algZO6
2
How u figure..?
Try this
2" 900 and above
Paul, you can't say that considering you didn't get a clean pass with either set of headers. OP, if you are considering any type blower get the 2"
Old Apr 24, 2016 | 07:42 PM
blown81bu's Avatar
blown81bu
was on same ecs dyno actually lost torque down low by alot and less power..it was hard to beat LG 1 3/4 long primaries for the c5
true no clean passes either was an issue with trans that i figured out while i was parting car out..u would never believe what i found....
Old Apr 24, 2016 | 08:39 PM
Seannyc's Avatar
Seannyc
So from your information should I go stepped header from Lg full 1/78
Old Apr 24, 2016 | 09:25 PM
blown81bu's Avatar
blown81bu
That looks like a really nice header indeed
Old Apr 25, 2016 | 12:04 AM
3 Z06ZR1's Avatar
3 Z06ZR1
2
How u figure..?
Try this
2" 900 and above
I have used both sizes that's how.
I would dig out my old dyno's where I swapped out 1 3/4 KOOKS with ARH 1 7/8ths and had a size able gain on the same tune at just under the 600 rwhp level.
ARH does use a much better flowing cat than Kooks as well.
My tuner had a hard time with it as well. But not it's worth it. You run what ever you want.
I do wish I would have went 1 7/8's
instead of the 2 inch I have in my office on the floor.
But I'm sure it will work well since I'm going with a pulley.
And a intake filter that flows 680 cfm.
Old Apr 25, 2016 | 01:22 AM
Seannyc's Avatar
Seannyc
What exactly did hp u gain by switching
Old Apr 25, 2016 | 08:28 AM
  #33
Silverboost
I gained 30 rwhp at 3500 rpms switching from the stock manifolds to 2" headers and a pulley change with the tune untouched. It carried that gain through the power band to 36 rwhp at 5800 rpms. I did gain 1lb of boost with the pulley change so it's hard to tell what just the headers did by themselves. The 2" headers seemed to do fine even in the lower rpm range. Could I have made more power down low with 1 7/8? Maybe. Would it have been significantly more? I doubt it. Again this was with the tune untouched. I was at 715 rwhp at the time.
Old Apr 30, 2016 | 11:47 PM
  #34
3 Z06ZR1's Avatar
3 Z06ZR1
I have the dyno sheets but not on this laptop.
I went from 513 to 572 same engine, same car, same dyno, same tune. I changed from Kooks 1 3/4 to 1 7/8's ARH
I also removed the rubber corner boots and hard piped the charge tubes the whole air path. that helped some of it.
I still remember my tuner's own disbelief.
Old May 1, 2016 | 03:28 AM
  #35
Seannyc's Avatar
Seannyc
That's a pretty big improvement
Would u go with a stepped header 1/34 turns in to 1/78 or full 1/78
On a. S/c
Old May 5, 2016 | 08:40 PM
  #36
NoOne's Avatar
NoOne
I am not the person to do the math but I'm sure others could.
If you changed the pulley, how much did mass air flow change? If you did not retune then aren't you just running leaner?
My question is based on the airflow change does that calculate out to 36hp on the pulley change alone without considering the header at all?
Old May 6, 2016 | 04:03 PM
  #37
Silverboost
My comparison is not the best one to go by. When I put the headers on untuned it was running lean but it did jump 36 rwhp at 5300 rpms with no tuning changes. At 715rwhp it was pretty much at its limit of fuel supply. Im sure it would have had even better results above 5300 but it was out of gas. I could never get a good tuned number after the header install because there was not enough fuel to go with the HP increase. I then put a single nozzle meth set up on and it jumped 83 rwhp mainly due to the extra fueling.
