C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Estimates
Old Aug 30, 2016 | 04:42 PM
JustVette's Avatar
JustVette
Cruising
Default Estimates
Just got my '16 z51 A8 at the beginning of the year. I'm new to this so any knowledge on what where when how is an awesome plus.
Looking to save up for a blower and other mods. Curious on estimated pricing for everything + install tune. More specifically near OKC area (where I live).
I work quite a bit so traveling is limited for me. My list of mods would be:
Supercharger (undecided on brand)
ARH LT 1 7/8 or Kooks LT
Alky Meth
Install and tune.
I'm more then certain the Hp/Tq gain would be more than adequate for me. Once this is done then maybe I'll look into more. It's somewhat a daily drive/road trip car. Sorry if I'm vague but I'll try to clarify...like I say I'm new so any knowledge/experience is much appreciated.
Old Sep 1, 2016 | 12:41 AM
Bleachcola's Avatar
Bleachcola
Skip the alky meth and do e85
It's 85% alcohol lol
Old Sep 1, 2016 | 07:58 AM
C7&7's Avatar
C7&7
Theres waaaaayyyyy more to it than that to do e85. You actually need meth to do e85 in most cases. E85 setups on the c7 require way more fuel. Lt4 high pressure fuel pump and injectors and usually a secondary low pressure pump as well.
to the OP. If you are planning to buy your own parts and have a shop install and tune them, then you're looking at probably about $2500-$3000 in labor and tune. You'll have ~ 700 rwhp car depending on how much boost you run. 650-700 without a doubt.
Old Sep 1, 2016 | 10:20 AM
Unreal's Avatar
Unreal
Plus availability of e85. I would never build a car that required e85, as you don't know when/if it will go away. Arizona just switched to e54, so if someone built a car that "needed" e85, they are now screwed. If you want to run ethanol, run flex fuel and keep setup mild enough that it can run on pump or e85 or anything in between, just with a power difference.
Old Sep 1, 2016 | 10:53 AM
JustVette's Avatar
JustVette
Cruising
Hard to believe Chevy doesn't already have Flex Fuel on their Corvettes. Sounds like another good investment to consider along with everything.
Old Sep 1, 2016 | 10:59 AM
Bleachcola's Avatar
Bleachcola
Originally Posted by C7&7
Theres waaaaayyyyy more to it than that to do e85. You actually need meth to do e85 in most cases. E85 setups on the c7 require way more fuel. Lt4 high pressure fuel pump and objectors and usually a secondary low pressure pump as well.
It's not as complicated as you make it sound
To run e85 you need about double your fueling
Don't need meth, once again e85 is 85% alcohol, meth is 100%
Old Sep 1, 2016 | 11:02 AM
Bleachcola's Avatar
Bleachcola
If it goes away just run pump gas and tune for it , you will have huge injectors left over
Though once you do e85 you get hooked on it, 85% alcohol at the pump, for a dollar less per gallon than 83. guys online are buying it in barrels if thier state doesn't carry it
Old Sep 1, 2016 | 11:07 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
The problem is that you can't just replace injectors on the DI engine like you could in previous year models.
Old Sep 1, 2016 | 11:29 AM
Unreal's Avatar
Unreal
I run flex fuel, have had nothing but e85 in the car for past 18 months. 2 weeks ago Arizona switched with no notice to E54. Now everyone that isn't flex fuel is having to get retuned, and mess with their cars. A huge pain in the *** for a lot of people. For people who did 14:1 compression and crazy builds, they now have to order e85 in barrels for $7 a gallon.
Old Sep 1, 2016 | 11:42 AM
Bucknut2006's Avatar
Bucknut2006
'How do you propose pumping twice the fuel through the stock injectors? Even the LT4 ones aren't that much bigger than LT1. On top of that, meth is using separate nozzles so it's additive 100% alcohol.
Old Sep 1, 2016 | 11:44 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
With what injectors?
Old Sep 1, 2016 | 12:59 PM
ChiefP's Avatar
ChiefP
OP, your thread went a little sideways, but the answers you need are here in this forum. I made my decision based on the info here. I'm going A&A, but its not nearly the only good choice. Some have package deals for just what you're looking for. Pricing varies based on whether you go PD or Centri, and whether you install or the shop does. Many of the shops/supporting vendors are here as well, so my advice is to find some time to do some reading. There are other C7 forums out there, but I've found this one to be the best.
Old Sep 1, 2016 | 01:16 PM
JustVette's Avatar
JustVette
Cruising
It's welcomed lol. I enjoy reading...learn more everyday. It's actually a good debate on which is better.
I enjoy the advices too. I'm love the hell put of my z51 and the mods is a dream. Can't imagine what it's like with 200 more hp. He'll even 70 rwhp lol.
Old Sep 1, 2016 | 04:39 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Feel free to give us a call if you would like to discuss our supercharger system.
Old Sep 1, 2016 | 05:25 PM
robert miller's Avatar
robert miller
Old Sep 2, 2016 | 03:29 PM
C7&7's Avatar
C7&7
He's just doing simple math. He's obviously not done his due diligence on the LTx platform just yet.
Old Sep 11, 2016 | 11:52 AM
Cordes Performance Racing's Avatar
Supporting Vendor
Please do not listen to the guy saying just do E85, it takes a lot to run e on these cars and we have some of the most experience around doing it on them. I can help you put together a solid package for your goals and work with you on finding a tuner in that area or just bring the car to us for install/tune or just tune if you want to DIY.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
To Estimates
Old Sep 17, 2016 | 02:44 AM
CDH76's Avatar
CDH76
Alky Meth
Install and tune.
If you do not install it yourself then you are looking in the area of $12,000 give or take.
Old Sep 17, 2016 | 04:41 PM
NoOne's Avatar
NoOne
Who pays that?
If its a PD blower maybe but for a Centri 5K for the kit, $700-800 for the install, $500 for the tune.
Add about 1200 for the meth between kit and install.
Headers are what $1800 plus install and its already at the shop?
Old Sep 17, 2016 | 04:59 PM
c0ke's Avatar
c0ke
Originally Posted by NoOne
Who pays that?
I don't know where you're getting those numbers lol
Here a kit is in the area of 7k for a centri, 2k for install and 800 for a tune.
So with meth thats about $10,500
and headers are $2500 so in the area of 13,000 out the door.
