C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Stock diff problems. Haha
Old Nov 29, 2016 | 10:50 AM
Ls2000's Avatar
Ls2000
Default Stock diff problems. Haha
Old Nov 29, 2016 | 10:55 AM
jacksnorm's Avatar
jacksnorm
Originally Posted by Ls2000
Is that from those 1.3 60fts?
Old Nov 29, 2016 | 11:08 AM
T/A KID's Avatar
T/A KID
Buddy with an f1x z06 m7 shattered his a few weeks ago... I hear wavetrac is building one
Old Nov 29, 2016 | 11:31 AM
jacksnorm's Avatar
jacksnorm
Was that with stock or DSS axles?
Old Nov 29, 2016 | 12:39 PM
brent eb02's Avatar
brent eb02
ouch !!
Old Nov 29, 2016 | 12:51 PM
123sugey's Avatar
123sugey
Dig
Broke on the street or track ?
Old Nov 29, 2016 | 03:35 PM
Elite275's Avatar
Elite275
I heard RPM has something in the works close to release as well.
Old Nov 29, 2016 | 03:45 PM
robert miller's Avatar
robert miller
I don't think so I just called today. I ask and was told to buy a 3:42 gear set up from GM.
Regroup on this RPM should have something out for us within the month of Jan/2017.
Old Nov 29, 2016 | 05:05 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
We have adapter C6Z diffs into them now. We broke 2 C7 Diffs in one of our cars and have since installed a Level 4 RPM C6Z diff and its been good since.
Old Nov 29, 2016 | 11:33 PM
Ls2000's Avatar
Ls2000
I am sure it broke from 2 years of abuse at the track and massive tire shake last time out at the track. We are woking on different gears set up and options from the c5-c6 cars.
Old Nov 30, 2016 | 07:50 AM
Elite275's Avatar
Elite275
Frans96ss - Could you provide more information on how the adapter works, or if this is a part that you manufacture and sell to work with C6Z diff that you're currently using?
Old Nov 30, 2016 | 08:00 AM
rkj427's Avatar
rkj427
Pro Mechanic
new supplier of rear differential assemblies to GM for the C7 models, not the same supplier as the prior generations, so some unexpected "growing and learning pains" to be expected.
another scenario is that these meet original GM specifications, but vehicle produces more torque, or load than originally anticipated and originally designed for.
Old Nov 30, 2016 | 01:05 PM
Dave01GT's Avatar
Dave01GT
I know your pain. I'm on my 3rd. The only reason I'm not on my fourth is because I haven't been able to get it to the track in the past month.
Old Dec 10, 2016 | 01:03 AM
Ls2000's Avatar
Ls2000
Old Dec 10, 2016 | 08:57 PM
Dave01GT's Avatar
Dave01GT
Find a set of spiders that work?
Old Dec 11, 2016 | 08:53 AM
div7racer's Avatar
div7racer
I also broke the spider gears in my 2015 Z06's A8 differential after a year of drag racing.Instead of repairing the unit back to stock specs or replacing with another stock unit, I modified a stock unit to use 4 spider gears instead of the 2 it was designed with. It has been working excellently , with many passes since the modification, including completing Hot Rod's Drag Week 2016 event.When I did the modifications I started with a complete carrier assembly from a Z51 in order to take advantage of the higher ratio (2.73 vrs 2.41) of the Z51. I have some pictures and can explain the process and procedures I went through if anyone is interested.Ed Urcis
Old Dec 11, 2016 | 09:08 AM
Dave01GT's Avatar
Dave01GT
That would be amazing! I'd love to be able to make an all out pass without breaking the spiders on the first launch.
To Stock diff problems. Haha
Old Dec 11, 2016 | 10:02 AM
JHEBERT's Avatar
JHEBERT
Ed,
I for one would love to hear more about the 4-pinion spider setup, I have done them in fords and solved the issue. Did you use a block to support the inner end of the 2 short spider pins or did you machine flats on 2 long ones so they interlock?
I know for certain I am going to have issues here, I may not get my 1.29 60 but the 1.32-34 is coming....
John
Old Dec 11, 2016 | 10:12 AM
div7racer's Avatar
div7racer
Originally Posted by JHEBERT
Ed,
John
I actually made a block like a 9" Ford has AND machined a radius on the short pins that allowed them to butt up to the long cross pin.If you want to send me a PM with your regular email I will send you some pictures. I can also give you my phone numbers if you want to discuss this or anything else. Ed
Old Dec 12, 2016 | 10:28 PM
Ls2000's Avatar
Ls2000
