New build-going to the dark side
#81
Received 1,762 Likes
ttt
Hit one more big problem with the set up in the car. I just got back from Rio & now have to get a Dewitt fan set up for the car. The stock fans set out to far, & hits the intercooler pipe & not going to put a big dent into it to get it to fit.
Man it is one thing after something else on this. But it is what it is & the stuff you put up with when doing this stuff. Robert
#83
Dewitts radiator is over 1 inch plus thicker than the stock piece. Nothing to due with the A/A kit at all.. Just one of those thing when you go chg out one piece on these cars you more than not will have one r more things to chg out ...
#85
Just got the fans on wed's got them in also last night, got all the piping hooked back up cold side and all. Working on my Meth can for the car at the moment. Having to get a new feed plug tig welded into place now. It is always something. But again only reason for the new fan set is me putting Dewitts rad into the car back after I got the car. Stock fan cover just came out to far into the cool blower pipe.
But I do have all the blower set up on the car. Most of the meth set up on the car. Now also having my pillar post covered for the 3 gauge's putting into the set up to be able to read every thing. Robert
#87
As you can tell no big rush on my end at least I know it is correct. Plus been sick & on vacation, also takes time getting other parts in for meth tank pillar & all of that stuff.
I will post some pic's soon of the job & parts. Love the meth tank set up for the car not using the washer tank. It is a tank about the size of the LMR catch can tank. It sets in the same spot as that did in the car plus had it power coated black also like the other parts in the set up.
#88
subscribed
#89
Well after week of crap working with the 3 gauges on the pillar. This is not going to work out at all to be able to see them good enough if something goes bad.
I now have chg that and putting the 3 gauge's and the box behind the Nav cover door. Crap is always something but will be done are should be going to tuning within 2 weeks & done. Not be able to work on the car much at all from work job & the wifey asking what am I doing on it. Robert
#90
Waze
robert miller (04-22-2017)
#91
#92
But really with each of the diff pods r gauge's I have a fix in my mind were the damage point is and can start to let off r back out of it. We will see I will have all 3 gauge's in behind the screen by Monday night.
#94
Received 1,194 Likes
St. Jude Donor '15
You can also make dash logic set alarms if there's any issues so you don't have to look at anything, which is pretty awesome IMO. It can ding at you and/or put warning messages on the HUD/DIC, whatever you want it to do. It's a pretty neat little device.
#95
Crap just one more thing now to hold me back are to get for the car. Looks like more than not going to order this on Monday. Hope not a big overlay on getting it from them. Robert
#96
what does it cost and is the install easy?
#97
St. Jude Donor '15
It just plugs in to the OBD port. Setup wise you connect it to a computer and change what it is displaying, alarms, etc. It has a bunch of default stuff you can use by default.
If you want to show things like actual afr from a wideband then you'll need to connect the output from a wideband to dash logic and set it up on dash logic. I've posted some pics around here somewhere on how to do it
I should start selling the things with as much as I push the things . I really like them
#98
#100
