Huge thanks to LMR as always - 900 wheel Novi1500
#41
Yeah no restrictor, 14 psi pulley, ported heads, cam, double meth 40% e85 i lose boost as it goes up I go from 13-11
#42
Whats the 14 psi pulley? You mean the 3.75? I didn't see 14 psi with just the 3.75 pulley. Had to run the bell to get to 14 and up.
#43
Good to go bro! ...we had a 1500 and the best we could do was 800.2 rwhp. We upgraded several things but among those, we upgraded to a ECS 2200 head unit (around 22 pounds of boost). Kept our 1500 kit in place and basically upgraded the just the head unit and bigger meth nozzles. We hit 1182 rwhp but we are running out of fuel. We need to upgrade our fuel delivery setup.
We are super happy for ya hitting THAT high of a number on a 1500 head unit!!! Awesome!!!
#44
#45
You lose boost when you're on e40? Or just in general it falls off? That doesn't sound right. Sounds like belt slip if it happens all the time or the car is starving for fuel if it only happens on e40. The bell would add a pound or two of boost I would just make sure you're not solely on 93 when you run the bell. I don't run my bell on just 93.
#46
Nitrous solves it
#48
#49
yeah u have to get an innovators west balancer 10rib belt and 2200 unit is a little over 5k in parts, no labor its crazy more than a fulll 1500 kit, I wonder if there different prochargers or some other headunits that will bolt right up
#50
If anyone has a used 2200 head unit call me asap! Lmao
#52
#54
Pro head unit require different mounting brackets. There are brackets available from ecs that allow the use of a pro head unit with their (ecs) kit.
#55
Supporting Vendor
#56
trailered the car down to lmr yesterday to do a little change on my meth setup and do a iat breakout. First time i've ever hung around the shop and spent the day with the guys and watched steven tune on the car. Getting it dialed in on e85 (well e40) for the tx2k event in houston in two weeks.
Huge thanks guys. Big props to steven and staff for their support on my build over the years from a bone stock c
ar to a 650 package to a 750 package to what it is today.
93 octane vs e40
93 octane vs e40
#58
