C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Random meth kit question
Old May 9, 2017 | 11:52 AM
teddyca's Avatar
teddyca
Default Random meth kit question
So I bought the Alky control kit and been running the last year. Now looking to up the boost and HP a little with LTs, smaller pulley, and making my kit a dual nozzle. When I first ordered it cam with a M10 nozzle and my tuner asked that I get a M15. So instead of just getting the nozzle I bought a kit that included the fittings and lines for a dual nozzle and one M15. If I don't change the setting on the box and add the second nozzle before a tune will it in turn put more meth in my system?
Old May 9, 2017 | 12:54 PM
Unreal's Avatar
Unreal
Yes. Adding a second nozzle with add a significant amount of meth.
Old May 9, 2017 | 03:23 PM
robert miller's Avatar
robert miller
Default ttt
Yes for sure will put more into the intake. But if me I would look at the tuner to look at just looking at that & also the smaller pulley upgrade. I wouldn't do the smaller pulley & the 10 with the 15 without letting the tuner look at working on the tune. Robert
Old May 10, 2017 | 12:13 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Teddy, yes it will add more meth. You would need to turn down the **** on the meth control box to lower the dual meth down to the approx amount of what the single nozzle was spraying. The problem You run into is that turning it down too low drops the pressure to the point that you lose proper atomization. So, you tune for it and leave it turned up where it is now. Best recommendation is don't add the nozzle until the day before your tune gets redone..
Old May 10, 2017 | 03:50 PM
C7&7's Avatar
C7&7
Just add enough boost to equal the amount of meth you're straying.
The equation is:
(Nozzle 1 + Nozzle 2) / 2 = PSI You should run ATLEAST
To Random meth kit question
