Let's talk Centris and PCV.
Someone pointed out concern with my routing due to the drivers valve cover going directly to the inlet of the blower and not going through the catch can saying I'm sucking dirty air right to the blower. Below is my current configuration which is the A&A recommended routing but with one of the catch can outlets T'd in.
He suggested running the drivers valve cover into the line coming from the valley so that both would run into the catch can like so.
I'm confused on either being used as an evacuation point as everything I knew previously was that this line was part of the "Clean side" for drawing in metered air to the valve cover and the evacuation came from the valley cover but every setup I see tends to use the drivers valley cover as part of the dirty side.
When I talked to Elite they suggested that both valve covers should be joined like so.
My head is spinning trying to figure out what the "Proper" way to have this setup is to maintain the closed system but be able to properly evacuate with as little junk going through the blower.
Input... tech discussion... etc.. all welcome. lol.
I wasn’t sure what the affect of pulling that much vacuum on the drivers valve cover is as I’ve seen that connection labeled as fresh air IN not dirty air out and running right to the blower inlet is going to pull a lot harder then the factory setup. There’s so much conflicting info out it makes my head spin lol.
Best pic I have of current routing which is reflected in first paint diagram.
**** I just run a breather system that connects no where to vacuum lol.
but for sure you cannot do the middle drawing. the valley plate fitting is the pcv control point which you are defeating by tying the driver line into it.
Solutions for the common gearhead #made in USA
mightymousesolutions.com
facebok.com/mightymousesolutions
#mmsolutions
Six time NMCA True Street Champions
Home of the first Twin Turbo C7Z 7.81 @ 176
3470# Stock bottom end and heads Corvette Stock Bottom End Record Holder
gm has changed their purpose for that fitting 3 times on c7 dry sump, so is not an easy one to answer. tadge always seems to have a great 'we meant to do that' approach lol.
trying to control the oil is not easy, but if you get control of the air, you also get control of the oil.
to simplify all that is going on just think of them as passages to the crankcase
one of which, will have a pcv valve, and it must connect to the intake manifold with a dedicated line
one of which needs to connect to open fresh air, preferably metered (this is dry sump forward port)
then there are the lines to and from the oil tank, which are to participate in the pcv system as well as maintain air balance above the oil within the system as a whole
some cans defeat the pcv
some cans go direct in line of it
some are a mix of using pcv and giving auxiliary method of crank flow control with additional line or vent point
none of this directly answer your question, but once you understand the job that needs to be done, the layout comes naturally following.
clean air in, dirty air out, blowby out
Picture 3 basically duplicates the PCV changes GM has made in 2017+ in linking both valve covers to a fresh air source from the dry sump tank and using the valley cover as the single evacuation point which is filtered through the catch can and uses the blower inlet as a vacuum source for when the intake manifold is under Boost.
