C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Boost venting
Old Mar 26, 2018 | 12:23 AM
onebad1lE's Avatar
onebad1lE
Default Boost venting
Just installed blower and it runs perfect except on a c7 grand sport
But when I hit high boost I get a puff of smoke - should I install a venting
System some kinda catch can when u know u need them ?
Old Mar 27, 2018 | 09:56 AM
RpeterK's Avatar
RpeterK
Installed blower? What is high boost? Was it tuned before being driven? Smoke from where?
Old Mar 27, 2018 | 12:57 PM
robert miller's Avatar
robert miller
Don't sound good at all the only place the smoke can come from is the crank case & your PCV so it is smoking from your valve cover plugs & PCV lines . If me I would not be getting into heavy boost until I had stuff checked out. Plus any OIL leaks on the floor Like from the front are rear seals. Robert
Old Mar 27, 2018 | 01:25 PM
bullitt4110's Avatar
bullitt4110
I’d definitely add a catch can system, I have the Mighty Mouse system on my car
Old Mar 27, 2018 | 01:49 PM
stab1991's Avatar
stab1991
Would like for him to sign on and give some more info.
Old Mar 27, 2018 | 03:22 PM
onebad1lE's Avatar
onebad1lE
Default Boost
12lbs and found oil on engine thinking lines maybe routed wrong ?
Old Mar 27, 2018 | 03:34 PM
stab1991's Avatar
stab1991
I’m guessing you have meth and not running too much timing? Where is the puff of smoke coming from?
Old Mar 27, 2018 | 03:43 PM
robert miller
Also would like to know this.. Still smoke is not good if running & in boost.. Robert
Old Mar 28, 2018 | 10:25 PM
smajicek's Avatar
smajicek
More info would be nice like what blower, who did it, was it tuned afterwards etc... come on OP open up to us more so we can help you out?
Old Mar 28, 2018 | 10:40 PM
jacksnorm's Avatar
jacksnorm
12lbs is alot of boost for stock pistons. Without proper venting you will surely blow through the front or rear main seals.
Old Mar 29, 2018 | 11:14 AM
robert miller
I have the same only the wild set up from David. Great vendor does know his stuff on that part of these cars... Robert
Old Mar 31, 2018 | 09:54 PM
onebad1lE's Avatar
onebad1lE
Well think I blew front seal. Adding venting system from valve covers
Old Mar 31, 2018 | 10:22 PM
jacksnorm's Avatar
jacksnorm
You will also need to vent the Valley cover.
Old Mar 31, 2018 | 11:11 PM
smajicek's Avatar
smajicek
12 # is also quite high for stock lt1, its going to blow up on you soon.
Old Mar 31, 2018 | 11:34 PM
onebad1lE's Avatar
onebad1lE
Naw motor is fine. I got greedy with timing and had no venting. Why valley —aren’t valve covers vent then whole block ? The LMR kit only does valve covers
Old Mar 31, 2018 | 11:46 PM
stab1991's Avatar
stab1991
I have the LMR kit on order for my ECS setup on a dry sump. As soon as it gets here I’ll post up all the routing for you. Just have no idea when they will be shipping out so my car is just sitting till they get them back in stock I guess.
Old Apr 1, 2018 | 12:58 AM
onebad1lE's Avatar
onebad1lE
Thanks. Pm when u get it.
To Boost venting
Old Apr 3, 2018 | 05:29 PM
onebad1lE's Avatar
onebad1lE
Default Custom set up
Here my new venting system used filter for valve covers and
refit stock system
For dry sump tank
Now will fix front seal and lower timing back down
Old Apr 5, 2018 | 11:31 AM
onebad1lE's Avatar
onebad1lE
Default Tested
started car and no more leak when idle could front seal just leak under boost?
Old Apr 5, 2018 | 11:40 AM
robert miller
You would be lucky if that is the case on the car.. Robert
