C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Questions on using meth
Old Jul 29, 2018 | 02:11 PM
chevyfanatic's Avatar
chevyfanatic
Default Questions on using meth
planning on running Meth with my new Maggy 2.3 SC
  • are you using a particular brand of washer fluid ?
  • if not are you just buying pure meth and mixing ?
  • are you mixing washer fluid for higher meth content ?
  • are you using the windshield washer tank ?
  • any issues so far like pump failures ?
thanks
Old Jul 29, 2018 | 05:32 PM
Kazman1960's Avatar
Kazman1960
thanks
Using windshield washer tank and pure Meth .
Old Jul 29, 2018 | 11:09 PM
OilfieldVette's Avatar
OilfieldVette
I assume, but may be wrong, that using the WW tank for meth means your not using it for WWF? Orrrrr does it actually do both?
Old Jul 29, 2018 | 11:25 PM
chevyfanatic
well you can use washer fluid in there since its meth based but prob answer is no.
Old Jul 30, 2018 | 06:29 AM
Patriot Six's Avatar
Patriot Six
VP Racing M1, 100% meth.
Old Jul 30, 2018 | 11:53 AM
pj-c7's Avatar
pj-c7
VP M1 70/30 in windshield washer tank. Couple of months so far, no failures.
pj
Old Jul 30, 2018 | 12:08 PM
chevyfanatic
what about boost juice ?
no takers ?
Old Jul 30, 2018 | 07:45 PM
Patriot Six
Boost juice is a 50/50 mix. Most get best results with 100% meth. Only problem is 100% meth is corrosive and the pump needs to be changed about every two years. Find a VP dealer locally and get a few 5 gal cans and it will last you a while.
Old Jul 30, 2018 | 07:56 PM
Kazman1960's Avatar
Kazman1960
We only have 6 months driving season where I live , I guess if I drain the tank I should get 3 or 4 years maybe to a pump
Old Jul 30, 2018 | 08:16 PM
Patriot Six
Drain the pump and fill with blue windshield washer fluid for the winter. Some have gotten up to 4 years out of a pump. I haven’t been so lucky.
Old Jul 30, 2018 | 08:21 PM
Kazman1960's Avatar
Kazman1960
Ill give it a shot this coming winter
Old Jul 30, 2018 | 08:42 PM
chevyfanatic
ok. maybe I am stupid but I thought everything I read says to run a 50/50 mix ?
Old Jul 30, 2018 | 08:43 PM
Patriot Six
You can run 50/50, but to get the most benefit from the added octane, 100% meth works best plus you still get great IAT reductions.
Old Jul 30, 2018 | 08:47 PM
chevyfanatic
hope the IAT are better ! eventually he will be in LV one day. This is why i went to METH and the Maggy 2.3 for added power due to the elevation and Heat.
But now I here even the Maggy runs hot in LV. Cant win.
Old Jul 30, 2018 | 08:55 PM
Patriot Six
For some perspective, at a roll racing event three weeks ago in 90+ deg heat, my IATs were about 122 at the start of the run and 90 after 160+ mph passes. This is with an A&A supercharger. Meth works.
Old Jul 30, 2018 | 09:34 PM
kc stingray's Avatar
kc stingray
i had a magnuson 2300 installed on my camaro ss. was advised by magnuson not to run meth, due to the meth eating the coating on the rotors. might want check with magnuson first before installing meth.
Old Jul 30, 2018 | 09:57 PM
chevyfanatic
fwiw - https://prometh.com/blogs/tech/72804...n-supercharger
To Questions on using meth
