Seeing 20 pounds of boost, car is making 820whp on mustang dyno on pump. Problem is at 6200rpm the power falls off drastically. With the stock 4.5" pulley it pulled to 6500rpm. Ive been looking at an array of dyno sheets and im seeing most are 6500-7000rpm.
I dont think its belt slip, we have the belt cranked tight. Only thing we're thinking now is a possible blockage with the intercooler. But wanted to see if anyone else had a similar issue before we started hacking and welding bung on my charge pipes to test.
Procharger admits theyve seen issues with their intercoolers an also states it should be making more power at 20 pounds and the blower is not maxed with only 58K rpm on it.
Any insight is appreciated!!
Every FI setup needs to be pressure tested. Simply use an air compressor to push air into a vacuum hose and block the blower inlet using a PVC cap with a hose clamp. make sure you remove any crankcase vent tubes- do not pressureize the crank case. Keep the dipstick pulled up so you can tell if anything is going in there.
Looking at the JTM post above their car was also falling off at 6300rpm... Switched to LME and carried much more power to 6700rpm... Maybe this procharger intake cant keep up.
Power was falling off, but not boost, Boost drop at higher RPM's is a common issue with the standard kits.
Due to kit restrictions, at what power level did you notice them most? Intake/Intercooler, 8rib?
I intend on going with a griptech pulley first then see whats going on. Followed with the LME intake. HOPING the PC standard intercooler is as advertised and can keep up.
Never had issues with belt slip, LME intake will not have an affect on boost.
My money is on the belt slipping. Pc knows there is a problem thats why they make a 10 rib pulley setup.
Another way that i would think of is to make the intercooler outlet piping diamter to 3.5” or even 4, so you can have less restrictions, if you have the procharger race intercooler i know its flow good up to 1100whp, so its either a boost leak or belt slip
keep us updated and good luck
Thanks for the responses!!
Looking at the 10 rib setup, would like to have everything done on that end and eliminate belt slip as a possibility.
G1pro has a larger core procharger kit replacment intercooler so after that option ill kick the tires on that. Lastly going to the LME intake, not for the boost drop issue but for performance. Guys with these setups seem to be bolting on big power with this over the procharger intake.
Yeah saw where VR has a used race intercooler with 4" outlet for sale on ebay. That would work for higher boost applications. But to hit 20 psi that race intercooler you have should NOT be the issue. You may have a leak.
that kind of waste of money, you could do it with s tire tube, cut a rounded 9” peace making the valve in the middle, put it on the procharger inlet with a clamp and apply pressure to it
yeah if you have more time on your hands than I do. Sure. You can build a house with popsicle sticks also. Point was to get him in right direction of how to pressure test. Damn guys you tear apart every single person trying to help on this forum. How about just appreciate we all are trying to add helpful content here. ****.
I appreciate the replies fellas, hoping its just belt slip. Not sure if i should "waste" the money on a 8 rib griptech or just start moving forward with a 10 rib set up. I dont plan on spinning the blower any hard for some time, once this is figured out.
calm down brother, all i meant was to save him couple bucks your way is right but cost more than the other way, both do the same thing. Your point was helpful and much appreciated. Nice build by the way and i wish my car was built as professional as yours
