C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Help with meth system!
Old Dec 13, 2018 | 12:17 PM
8850's Avatar
8850
Default Help with meth system!
Got it figured out. Had wrong line for boost. Works great now!
Old Dec 13, 2018 | 12:59 PM
robert miller's Avatar
robert miller
Default ttt
I hate the snow meth set I bought one new yrs ago couldn't get it to work correct. I sent it back and got one from ECS meth kit. Try putting the setting to hit at 3 psi if it is working and you have that much psi on idle & text light working & motor is also. It has to be hooked up and also grounded good mine was doing the say thing also I just pulled it.. Robert
Old Dec 13, 2018 | 02:14 PM
8850's Avatar
8850
The Snow system works fine in the garage as long as I'm not connected to manifold and at WOT. I tried a 2 psi setting and more and it would work fine in my garage but not WOT connected to my manifold. Seems to me if I get vacuum in that gauge I should also get boost. The pic where the vacuum gauge was reading zero and where my boost switch is connected to a hose and how I set the switch with my compressor.
To Help with meth system!
