Hey guys, looking for some input on which route to go. My car currently has the A&A Si kit with meth and Corsa exhaust. Getting ready to get the bottom end forged along with a BTR cam. Here’s my dilemma...I’m trying to decide what would be the better option. Built bottom end, adding headers and a xpipe, low side fuel system in anticipation of going to a Ti later, or just stick with my stock manifolds, do an xpipe with the forged bottom end of course and just get the Ti instead of headers? I’ve already spoken to A&A and doing headers or the Ti upgrade will essentially cost the same but I’d make a lot more power with the Ti obviously. I’m just thinking with headers, xpipe and corsa Xtreme with a cam is going to be really loud. I don’t necessarily mind loud, but being in California I’m trying to stay under the radar as much as possible with my Yellow Stingray
Anyway, just curious what you guys think, should I upgrade the blower now and add headers later or do headers now and blower later?
U need headers to help the car breath better especially FI so that would be the first thing u should do. I would say do headers cam and upgrade to ti headunit and u should be good till around 750whp. I ran my car like that for couple of years with no problem. After you get tired of that power level which u probably will in few weeks then do built bottom end with lt4 injectors and pump along with dsx low side and that ti head unit will be good up until high 800s. At this point make sure u have twin or triple disc clutch. After you get tired of that then upgrade to ysi and port injection and the list goes on and on...get ready to spend some money because nothing is cheap about c7s. GL
Thanks! But yea I’m doing the built bottom end right away as I’m pretty sure I have a bad piston ring. So it’ll be built with cam, but for the same anoint of money I was thinking Ti over headers but I’m listening...
Also, once we do the build I’m throwing in a mantic twin so I’m good there.
You kind of need headers. Headunits can always be swapped easily. A&A can take your si headunit and upgrade to ti with extra cash. And from my experience since your whole motor is out I would rather do triple disc and be done with it. You will never have to worry about tearing **** apart to swap clutch again since it's a pain in the ***.
Man just now getting my car back from doing the same set up on her. I went LT headers, TI head unit with meth, 3 inch mid pipe, All forged bottom end, BTR stage II cam with a 38% fuel increase, MSD ported intake from mamo, with the ported 95 T.B. on it I also did a set of ported heads from Cajun edgevette in here a vendor...LT4 inj & LT4 pump also.... Robert
Nice our setups will be similar. My shop offered me a good price on Kooks with the xpipe so I’m definitely not passing them up. I’ll send in the Si in exchange for the Ti. I’m also doing a BTR cam, but not sure what they’ll spec out for me. Car should make really good power, I’ll definitely need some tires for it, maybe some Toyo triple 8’s?
Some good advice in this thread! I’ll just add if you still have the stock cats, they will begin to choke you down if you decide to upgrade the head unit to a Ti, so some Kooks headers with Green Cats (or no cats) is definitely suggested before pushing your build forward.
I cant tell from your info if you are a m7 are A6 in the trans some guys in here has said even with the stock converter that this car will pull the car with the BTR stage II cam. Other has said with this cam if the tuner knows what he is doing he can get that to work out. But if you are a m7 I think I would do a good upgrade on the clutch when it was down r a good CIRCLE D converter LIKE I did in my car for so more help in it doing better... Good luck man on which ever you have and do on her.. Robert
Just for reference I made 715 whp on stock manifolds and no headers with a TI at 13 psi, 10.5 forged pistons and a cam with no meth. The stock exhaust manifolds flow pretty good. It depends on your goal. My low side and high side fuel system were both tapped out at this point on a stock lt1 fuel system with the cam lobe. I added a single nozzle meth and 2" headers with a msd low side fuel pump voltage booster. At 15 psi was able to jump to 800 rwhp. Just wanted to give you real world results. If I were to guess the headers, extra boost and meth all contributed equally to the extra 85 hp. Probably the meth more than the rest due to the extra fuel, octane and cooling effect. I will say I love the sound of the headers though. On your setup the addition of headers would probably net you 20hp maybe 30 hp on the high side.
Thanks guys! I’ve decided I’m going with Kooks LT’s and off road Xpipe. I’m going to go ahead and do the Ti as well, since why not...lol! Will have to get my fuel system figured out, will I need the LT4 Injectors? I’ll be running a cam with a fuel lobe obviously and dual nozzle meth. It was mentioned above going with a mantic twin, this is more power than I’ll ever need. This car is driven a lot, it’s not a garage queen. 800 wheel is the goal, anything over is gravy.
Btw Robert it is an M7.
Man do the mantic twin on her, YES plus do the LT4 pump & the LT4 inj on her also. I have all of this with a 10m & 15 m nozzle of the meth also..Your car will be fun for sure.. Robert
Fuel system wise all you need is LT4 high pressure pump and LT4 injectors. You don't need a low side system at this power and boost level. Just do the LT4 hardware and dual nozzle methanol and you'll be fine. It's going to make a tad over 800 if tuned properly. I was basically at this exact same build at one point (but I had the novi1500). I even could run like e50 which took me over 900 wheel. I was overspinning the 1500 and had a bell mouth on it as well.
If you ever plan to do the YSI that's when you're need a low side.
Robert is right when the motor is out just bite the bullet and do a clutch. I LOVED my manic twin but it gave up the ghost when I went to the 2200X. I then went to the Manic triple though. They're great clutches.
