Circle D converter
My tuner recommended a 3200 rpm 258mm and Circle D recommended a 3400-3600 245mm converter.
I drive the car on weekends and not looking to give it half throttle to get the car to move.
Goal is to dip into the 9's
will be adding:
stage 2 cam spec'd by tuner
circle d converter (one of the above)
might get ported heads (any recommendations?)
current mods:
nitrous 100-150 shot
NO stand alone fuel cell
lt headers
catless x pipe
zr1 tb
ported stock intake manifold
afe cold air
e85
I'm running a 258 "2d" which is around a 3400-3600 in mine. Really wish I did the converter from the start, it feels amazing really. No issues at all. My converter was spec'd for a d1sc build with a goal of around 750hp.
Current mods are:
cam motion supercharger cam
circle d 2d
msd
95
vararam
2" tsp headers
flex fuel (only get 69% e here)
drag pack
My best et is a 10.18 at 133 but then I destroyed an axle. I have a feeling my car should dip into the 9s as it sits if I can get it together before the weather gets warm.
Mod's
BTR stage II cam
circle D 2800 stall
A/A TI with small upper pulley
All forged motor with ported heads from Cajun
LG 1 7/8 headers but looking to put on 2 inch headers
RPM 3:42 rear with wavetrack & 300m halfshafts
solid 3 1/4 inch C.F. driveshaft with NO couplers
driveshaft axles.
MSD ported intake & meth with z06 pump & inj.
LG motor & rear end solid mounts.
Car runs great. Circle D is the only way to go here in a converter.. Robert
How did it affect your drivability from a stop? - It launches really well. It's very streetable and well mannered on public streets. Don't get me wrong, it's definitely noticeable but very minor.
Current Mods:
TS&P fully built 416 stroker motor
ECS 2200 Centrifugal
Custom Intercooler Setup
TS&P PRC Heads
Forged Callies Magnum Crank
Forged Callies I-Beam Rods
Forged Mahle Racing Pistons
TS&P VVT-3 Cam (with bigger fuel lobe)
American Racing Headers 2" - 2 1/8" x 3 1/2" collectors
Corsa Extreme Exhaust, no cats
Supplemental / Secondary Fuel System
Prometh / Alky Control hybrid Methanol System with (9) meth injectors
Bigger Injectors
Custom MSD Airforce Intake
(Several other small / not mentioned parts or mods)
Worked closely with Texas Speed on this build. It should stand the rigors of up to 1300+ horsepower pretty consistently. Patiently waiting on the V15 (which it seems that it will never be released). Sigh.
That is funny on the 12 month warr well at least you have a full season to try & brake it then when you take it back you can say
JUST DRIVING DOWN THE ROAD AT 80 MPH & the dam thing started doing a big clunking sound.
Really good luck and the car looks really nice under the hood one of the best I have seen in the c7... Robert
