C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
BTR trinity intake
Old Jul 11, 2021 | 06:18 PM
C6vettegfw's Avatar
C6vettegfw
Default BTR trinity intake
Anyone got any pics of this intake mounted up?
Old Jul 12, 2021 | 08:07 AM
99vetteran's Avatar
99vetteran
The Gen6 Camaro guys are running them and Pray Performance has several he has been flow testing. Here is some flow testing from Brett on the heads and intake
Pray Performance | Facebook
BTR TRINITY INTAKE - GEN V WITH INJECTORS - BLACK - TRA-GENV-INJ-BLK (briantooleyracing.com) This info does say it will clear and work on the C7. Good news.
Old Jul 12, 2021 | 08:20 AM
C6vettegfw's Avatar
C6vettegfw
Sorry bud I asked if anyone had pics of it mounted up. I actually wanted to see what it looked like in the engine bay.
Old Jul 12, 2021 | 08:51 AM
99vetteran's Avatar
99vetteran
Hopefully someone will, its still early. I'm going to check on one today with Btr as I've bought a lot from them so I'll check to see if they have any pics of one mounted. If so I'll post them.
Old Jul 12, 2021 | 11:06 AM
99vetteran's Avatar
99vetteran
I just ordered one and should be here Wednesday and I'll install it then on the dyno hopefully by the end of the week. Don't tell my wife. OK? I use this dyno for all my tuning and have made dozens and dozens of pulls on it so I should be able to get a pretty good comparison with my ported msd. I don't expect it to make more power till I have it ported but want to get a stock baseline first
Old Jul 12, 2021 | 11:44 AM
robert miller's Avatar
robert miller
Default ttt
Buddy you are as bad as I am on chging stuff out on the car don't much more & get a piece on it & then pull it for something more. It does come port inj correct if not I having my procharger set up drilled & putting meth down it when in boost. Robert
Old Jul 12, 2021 | 01:02 PM
99vetteran's Avatar
99vetteran
Yes I'm bad about that. Oh well **** happens. I post once I get everything lined out. I have to find a map wire extension since it mounts on the rear of the intake.
Old Jul 13, 2021 | 03:24 PM
T/A KID's Avatar
T/A KID
I don’t see this intake being better then stock unless you are spinning quite a bit of RPM..
this is just off visual perception of runner length and guessing on CSA and plenum volume
Old Jul 13, 2021 | 03:33 PM
T/A KID's Avatar
T/A KID
I bet MSD makes more TQ and Hp everywhere
Old Jul 13, 2021 | 03:38 PM
99vetteran's Avatar
99vetteran
I haven't seen a comparison on that but would love to see it. According to Btr it made a little more power then the MSD. Post those if you have them please. Now if I can get it to run as good as my Msd then I'll be happy with that cause it does look cool. Then this winter I'll do the heads and cam which will really be more applicable to this intake.
Old Jul 13, 2021 | 05:01 PM
C6vettegfw's Avatar
C6vettegfw
I’m using it as I am are going port injection and Brian’s manifold sill come plumbed ready to take injectors.
Old Jul 13, 2021 | 05:10 PM
99vetteran's Avatar
99vetteran
I ordered mine with that option also. We are going to try and flow test it on my buddies flow bench and compare it to the ported msd. Brett at Pray Performance is currently testing it, unported and ported. Here are some preliminary number
click on that and you'll see additional info about the intake
Here is some additional info on intakes he has ported for a comparison.
Number 2 is unported and 3 is ported
Old Jul 19, 2021 | 02:32 AM
C6vettegfw's Avatar
C6vettegfw
did you get it mounted up after? Wound be nice to see what it looks like in the engine bay. Thanks.
Old Jul 19, 2021 | 07:34 AM
99vetteran's Avatar
99vetteran
I decided to return it. I ordered the one with the port injection provisions because I was told that there would be plugs I could use until I decided what to do about running additional injectors or possibly NOS. I did not come with those as claimed, I was going to have to rig up something on the rear for the brake booster since its not direct fit as the MSD. The map sensor needed to be run to the back of the manifold so that would require a map extension which is not a big deal you can buy those. Couple other things didn't fit like the MSD or the Lt1 manifold so just decided it wasn't for me. Probably better suited for someone that has more mods and maybe a converter. I could have worked everything out but decided just to stay with the MSD for now. Maybe a winter project.
Old Jan 18, 2022 | 10:52 AM
RunningWolf's Avatar
RunningWolf
Cruising
Default BTR intake
Old Jan 18, 2022 | 11:18 AM
RunningWolf
Cruising
Old Jan 18, 2022 | 08:20 PM
ss2z06's Avatar
ss2z06
Are there fittings for the evap and everything that the oem one has?
To BTR trinity intake
Old Jan 18, 2022 | 10:05 PM
RunningWolf
Cruising
Not sure. Had the work done at Star fabrication in New Braufels,TX 210-264-7010. Ask for Rob.
Old Jan 19, 2022 | 08:24 PM
edsc7's Avatar
edsc7
There is no port for evap , you’ll need map sensor extension harness as it relocates it
Old Feb 21, 2022 | 05:33 PM
black_c7's Avatar
black_c7
Originally Posted by RunningWolf
that dyno graph was btr with what intake ?
