C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Codes popping up
Old Sep 26, 2021 | 09:15 AM
17WhiteGS's Avatar
17WhiteGS
Default Codes popping up
Everytime I'm hitting around 5500 with my setup my car almost falls on its face and sputters until 6500 then let's go.. I got ecs blower and direct port meth. I started the car this morning and 2 codes popped up
c1151 and b2111. Can't find anything. Any idea? Thanks in advance
Old Sep 26, 2021 | 12:13 PM
16 Stingray's Avatar
16 Stingray
What does your dyno graph show 5500 and up?
Old Sep 26, 2021 | 01:25 PM
17WhiteGS's Avatar
17WhiteGS
Old Sep 26, 2021 | 02:53 PM
Gary barnes 1098's Avatar
Gary barnes 1098
Call ecs tomorrow. I’m sure it’s an easy fix since they did the tuning.
Old Sep 26, 2021 | 04:03 PM
17WhiteGS's Avatar
17WhiteGS
Ya I try not to bother them, they are super busy. Just seeing if it's something major or not
Old Sep 26, 2021 | 05:04 PM
16 Stingray
Originally Posted by 17WhiteGS
Nothing on here. Looks like car is pulling strong?
Old Sep 26, 2021 | 10:59 PM
17WhiteGS's Avatar
17WhiteGS
Ya, this started happening a week after the tune, I thought it was low meth but it's not. I have a guage on my fuel rails for the direct port meth and when I test it it only reaches 20 lbs on the guage. So maybe it's the pump going bad after 400 miles
Old Sep 27, 2021 | 06:37 AM
Gary barnes 1098
You getting a green light when your in boost showing pumps reaching pressure? If you are, ain’t pump, if no light it is pump.
Old Sep 27, 2021 | 03:04 PM
17WhiteGS's Avatar
17WhiteGS
Ya I'm getting green light, but I thought it had to be at 40-50 lbs... only showing 20lbs when I test it
Old Sep 27, 2021 | 05:18 PM
Gary barnes 1098
Car has to be running. I know you were dynoed on a hub dyno that can be generous but nevertheless your at 685, your lt1 fuel system has got to be at full tilt. Maybe your running out of fuel at 5500 rpm. You have got to be at that fuel systems limit. Ecs definitely knows what they are doing so I’m kinda at a loss? But if your getting green light your at least 50 psi and meth is working fine.
Old Sep 27, 2021 | 05:38 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Neither of those codes should effect drivability, those codes are not in HP tuners software, but here is what came up when I googled them;
Definition of check engine code B2111:
GM:
Lumbar Down Switch Failed
Reason For C1151 Code
The reason of C1151 OBD-II Engine Trouble Code is Engine Oil Temperature Sensor Malfunction.C1151 the main thing to check is to verify the operation of the VCT solenoid. You're looking for a sticking or stuck VCt solenoid valve caused by contamination. Refer to vehicle specific repair manual to perform component tests for the VCT unit.
Old Sep 27, 2021 | 06:21 PM
17WhiteGS's Avatar
17WhiteGS
Ok thanks!
17WhiteGS's Avatar
17WhiteGS
GM:
I must suck at googling, could find crap. Thanks doug
Old Sep 29, 2021 | 10:18 AM
Gary barnes 1098
Ever get it figured out?
Old Sep 29, 2021 | 04:38 PM
17WhiteGS's Avatar
17WhiteGS
No, checked plugs there clean, checking gap on plugs and swapping wires to see if that changed. Must be a ignition issue, not a tune issue at all.
Old Sep 29, 2021 | 05:23 PM
Gary barnes 1098
If you do have msd wires, I’d bet money on it that’s your problem.
Old Sep 29, 2021 | 07:08 PM
MeanRay1's Avatar
MeanRay1
I had a very similar issue with my car falling on it's face at 5200 RPM. I didn't have any codes, my tuner could see a slight missfire. We upgraded to a custom set of Granatelli Wires and BAM! Solved the problem. MSD Wires were the issue..
To Codes popping up
Old Sep 29, 2021 | 08:11 PM
17WhiteGS's Avatar
17WhiteGS
I dont, I've read all the upgraded wires awireless what stock can do. I have stockers on my car, ordered new plugs and wires to be delivered for tomm so I will find out real quick hah
Old Nov 6, 2021 | 10:28 PM
twinstang's Avatar
twinstang
you ever figure out what’s wrong?
Old Nov 7, 2021 | 10:43 AM
17WhiteGS's Avatar
17WhiteGS
Ya I Mis gapped some plugs like a idiot hah
