C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Engine code P129D and P12A6
Old Aug 30, 2023 | 04:52 PM
Tramel84's Avatar
Tramel84
Cruising
Default Engine code P129D and P12A6
Need help everyone. Just had my boosted grandsport motor forged built. Upgraded my hpfp to Lt4 style and the injectors. Low side fuel system, and Alkymethanol kit installed as well. The car was on the dyno and had one great run. Well the next run the pedal was floored, however the car didn't go vroooooooooom(lol) codes P129D and P12A6
I've swapped throttle body and still the same result no coded for the TB. It as if the ecu is not tell the fuel to be pushed when the car is commanding it. The car drives ok normally but if I push the pedal to the floor nothing happens. Just imagine you're trying to merge and you push to do so but the vehicle doesn't pick up any speed nor sprint. All helped welcome. Thanks in advance.
