C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
The. Ultimate. Acceleration
Old Jun 14, 2024 | 11:21 AM
Mike@SolerEngr's Avatar
Mike@SolerEngr
Supporting Vendor
Default The. Ultimate. Acceleration
SOLER PERFORMANCE | GENERAL MOTORS
JUNE DISCOUNT CODE: SALE5P
NEW option: A brand new reworked part (0 miles / BNIB).
CORE EXCHANGE option: A refurbished and reworked part shipped right after your order. The $X deposit is refunded when we receive your unmodified core unit within a month of order delivery.
REFURBISHED option: A refurbished and reworked part shipped right after your order. No deposit or core return is required.
REWORK YOUR OWN option: Ship your unmodified unit to us right after placing your order, we’ll rework it in 1-2 business days and send it right back to you. Contact us prior to order if reworking an already modified or ported unit.
FEATURES: • Optimized Active Contours with sonic flow nozzles • Porting Taper and Upstream Bore with Velocity Stack • Greater Discharge Coefficient of Plate/Blade interface • 16 Ra Microinch, Diamond Polished Surface Finish • Shaftless high-pressure side of the blade for Larger WOT Flow Area (91 mm Effective Bore) • Self-Cleaning Throat/Flow Gap • Dome and Thread-locked Screws • Dimpled shaft trailing edge
BENEFITS: • Lower weight to power ratio at part throttle, for a more nimble/spirited driving experience • Linearization and smoothing of the curve for a more predictable response and crisper shifts • Immediate response right off idling while keeping idling function undisturbed (No Hesitation/Stumble) • Does not require tuning. Warranty safe. • More air/power at every single throttle position after idle. Crucial for starting or expanding power gain modifications
1 YEAR WARRANTY*.THROTTLE CONTROLLER:
The perfect match for our Throttle Bodies. Easy installation. Premium features.
SE0525-TC DLX BLUETOOTH® THROTTLE CONTROLLER: CORVETTE 7/8, CAMARO 6, CADILLAC CTS 3 & MORE
FEATURES: Dual control, directly on the display or remotely from your smart device. Ten Modes, with a total of 64 possible settings (see chart). Sturdy aluminum construction, buttons, and heavy-duty harness. Self-adjusting OLED display intensity for optimum visibility. Real-time throttle position gauge. Fail-safe vehicle-specific design. Does not require the display to operate, for those who prefer a fully concealed device.
BENEFITS: Controls pedal sensitivity, allowing the driver to adjust an otherwise widely considered non-linear (slow/spongy) pedal response/map. Increases the sensation of acceleration/power, very important for driving pleasure in finely tuned sports cars. Complements performance Throttle Bodies in achieving total throttle control as a system. Plug-and-play modification. Warranty safe modification. Easy installation (15 min, no tools or special skills required).
Old Jun 17, 2024 | 12:01 PM
Mike@SolerEngr
Supporting Vendor
Website: SOLER PERFORMANCE | GENERAL MOTORS
Email: tiffany@solerengineering.com
Call/text: 251-468-9786
FOLLOW US ON INSTAGRAM: SOLER | PERFORMANCE
