Issues with Supercharging LT1
Its all in the install and the tune .... Procharger on mine , No problems , I do not hesitate to drive my my car anywhere . Its not a garage queen and I drive it hard
Dave
Boosted my FBO LT1 with an LT4 blower at 93k miles now at 97k on a conservative tune 550 whp @6psi and i get on it often. Should last a good while on this setup but of course anything can happen once you boost a non boosted car.
Recently installed an A&A on mine and could not be happier, I also have a great tuner.
As far as a reptuable shop , there are many but Mike Carnahan and Brandon Leeb who were Vengence Racing's Tuners here in ATL opened up Elite Tuned in Tampa/ St Pete. You can contact them at info@Elitetuned.com
Dave
I know of nothing you can add to your engine short if new pistons and opening ring gaps. I won't pretend to be an expert, but I will share what I've learned and my understanding and results. You can make ~600 rwhp safely with a knowledgeable tuner and proper parts working together. I started with 2" TS catless headers (bought used for cheap), mid pipe and a CAI. That netted me 442 rwhp. If I had it to do over I would get the 1 7/8" Kooks or American racing. The only reason I wouldn't do TS again is there is one header pipe that hangs particularly low on the drivers side. Next I added a ported OEM intake from edgyvette for ~$350. That did not boost my top end BUT, it did boost 12 HP throughout my mid range and upped my peak HP by 750 RPM. I was very happy with that mod seeing what it did for midrange.
A few months ago I did an A&A as recommended for a stock engine - 4" pulley. I ended up with 591/545 at the wheels. I see other guys end up with 550 which I assume is just the blower and maybe a CAI. If you are going to go with the A&A, don't bother with a CAI, you use the factory set up but you have to modify it. However, if you are interested I have a Holley CAI I'd like to unload.
I have had zero problems, not a knock, ting, stutter or otherwise act like this was a factory set up. I am still getting 28/29 mpg on the highway. These things are unbelievable with what they return in performance and tech. It still boggles my mind. 600 rwhp AND 29 mpg. That is crazy!!At 591 rwhp my tuner was very adamant I not add any more go fast parts. I have reached the limits of the factory fueling. To go further I'd need to install bigger pumps and supporting equipment. I'll also say this, 600 rwhp is insane on the street. Traction becomes a real issue. My next go fast goody is sticky tires in the spring. One thing begats another. If I ever owned another C7, I would not do it again. This has scratched the itch. It's fun, there is the wow factor at shows and cars and coffee, but I'm still figuring out the sweet spot to accelerate quickly in the first 3 gears without sending the tires up in smoke. Roll into 3rd gear at 35 mph at 1/2 throttle and the rear kicks out. It held it sideways to 80 mph and I never floored it. Let out and shifted into 4th. Not clutching it, not slipping anything, just throttle. Just know where you are heading.
Remember, just because you can, doesn't mean you should. You can absolutely boost the stock bottom end LT1 but, it's a crap shoot that people swear isn't. It's almost like the LS7 valve drop issue. People will stand on their soap box and proclaim that it's not really a problem or that it only happened on select vehicles, etc. Drop in rods, pistons and an appropriate cam for boost and a properly sized fuel lobe, along with supporting fuel mods, and you'll have an LT1 that will run just as hard as many modified LT4's. Remember, there's no free lunch. You'll have to give and take somewhere. Choose your shop carefully and I would always ask to see the results of shops who specialize on LS's to see what they've accomplished with LT's. They are not the same to build and tune but a lot of shops treat them as though they are and their results are subpar--however, most customers couldn't actually tell the difference.
Dave
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
With the LT1 stock internals, I would stay as close to the 600WHP as possible. Remember that you lose approximately 20% from the crank to the wheels. So at 600 HP at the wheels, thats a little over 700HP at the crank.
GOOD LUCK!
Me myself. Having a high mileage LT1 car. In my opinion to do this conversion safely. I have decided to do a drop in forged pistons and rods. Along with DOD delete, with other upgrades like either running a LT4 head or Katech doing the porting on the LT1 heads (Changing compression etc) and drill & tap the LT1 heads to accept the supercharger without using the LT4 adapter plates. Which makes the LT4 oem heads a more budget friendly choice if your wanting to eliminate the adapter plates. Kong X port on the LT4 supercharger. Katech oil pump, valley plate , bigger cam, trunion upgrades vavle springs, good lifters, LT4 HPFP LT4 injectors, DSX low side fuel pump, meth injection, E85 flex sensor kit, etc. Not to mention all the other parts it takes to make this conversion process happen smoothly. I guess it depends on HP numbers your wanting out of the car. We are shooting for 700+, All this work only makes sense if you bought your car really cheap (You like tinkering around on your car) or it's paid off and plan on passing the car on to your children or plan on keeping the car in the family. Other than that. Buy a ZO6. Because it can be a money pit fast. Good luck
