C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
RPM limit of SBE
Old Feb 17, 2026 | 02:51 PM
GARY2004Z06's Avatar
GARY2004Z06
Default RPM limit of SBE
Assuming that valvetrain stability is achieved and the DOD lifters are replaced, does anyone have any knowledge to what the maximum rpm can be achieved on the SBE making 850 RWHP?
Power to be made with a 2650, port injection, E85, a very small cam and other supporting mods.
BTW- It's a manual trans.
I'm evaluating potential 1/4 mile trap speed with respect to RPM and non-EOM gearing.
TIA
Old Feb 18, 2026 | 10:37 AM
xxDevilDogxx's Avatar
xxDevilDogxx
TIA
you could test it and run it out till it gets valve float , stops making power , or throws a rod lol .
Old Feb 18, 2026 | 03:07 PM
GARY2004Z06
Originally Posted by xxDevilDogxx
you could test it and run it out till it gets valve float (won't be an issue with the correct valve springs), stops making power (the bottom end of my Bolt-On LS7 was perfectly fine at 7500 rpm although it made no power up there), or throws a rod (hence the quandary) lol .
FIXED.
Old Feb 21, 2026 | 09:07 PM
wildhog's Avatar
wildhog
I can only tell you my 2014 C7 on the dyno with 840WHP my RPM was max at 6600. All built top end PRC Heads, Terminate cam package, on E50 and SBE, M7. But not safe to run unless you run race gas all the time. 13PSI on stock bottom end is not going to last. Currently at 760WHP and 9.5PSI all good now.
Old Feb 27, 2026 | 02:34 AM
Centribase08's Avatar
Centribase08
I spin mine to 71-7200
Old Mar 12, 2026 | 06:11 PM
GARY2004Z06
Thanks for the responses
Old Mar 14, 2026 | 10:17 PM
EXCUSES.Z06's Avatar
EXCUSES.Z06
I had my SBE 2.9 Whipple car up in the 71-7200 range, on LS7 lifters and upgraded trunnions.
To RPM limit of SBE
