C7 base powertrain
There's some speculation along those lines, I believe Popular Mechanics mentioned it, and claimed to have "sources". The only fact here is that nobody knows for sure, but I wondered how you all would feel about it.
I know wat you're thinking:
"Gasp! Did he just take the side of Nissan's GT-R?"
No, Corvette all the way, but you can't deny the performance of the GT-R
When C7 debuts, there will be only one engine under the hood. It will be a pushrod V8. Following years might see a significantly higher-end model a la Z06 or ZR1 with a more powerful engine derived from the base V8.
The standard Corvette will have something other than a pushrod V8 when GM can't justify building one for any other vehicle (including trucks) and the current design becomes cost prohibitive to update for Corvette-only use -- and not one minute sooner.
I suppose though the Camaro would probably be more likely to get a Twin Turbo setup first, since the base model is V6.
I could see Ford doing it in the Mustang, to cater to a different market that fancies such a powerplant. Mustang has the 84 SVO as a historical reference point, and Ford has a big investment in the EcoBoost brand. But they still have trucks and have built a new motor for them, and it'll fit the Mustang, so they'll keep building V8 Mustangs. As for the same thing happening to Camaro, I don't think GM has the motivation, interest, or frankly the daring to offer it, nevermind the engine on the shelf in the first place.
I think until somebody makes the case that forcefed V6s make more economic sense than naturally-aspirated V8s in pickup trucks (which remain huge volume sellers), we'll continue to see those V8s in rear-drive performance cars too. I think recent market pressure has, if anything, made powerplant priorities for pickup trucks MORE like that for cars (i.e. a little more cost for lighter weight and better efficiency is justified), so I don't think the truck V8s will be allowed to fall far behind the advances applied to front-drive car engines, and those V8s will remain the best choice for the kinds of cars we love.
Unless some jacka$$ on Capitol Hill decides that displacement-based taxes/limits makes sense, and then we're all screwed.
All that said... "what if?" I'd rather have an equivalently-modern and powerful V8. Only way a turbo V6 is better in my book is if the available V8 is a stagnant design by comparison -- and that doesn't mean the turbo V6 is good so much as the V8 is bad.
.Jinx
"yeah, I would never buy a V6 Corvette"
The fact that the Camaro's base engine is V6 is exactly why I think that if any model were to get a Twin Turbo V6 setup, it would be the Camaro. Not for the base, of course, but for the higher trims. It wouldn't be such as ridiculous to add Turbos to an engine that is already being used in the vehicle, than to offer it in a platform not designed for it. If the Camaro survives long enough to have another body style, what if GM builds it on a smaller platform? A TT V6 option wouldn't be unreasonable at all. It would just end up the Saturn Sky's big brother
Ford intends to put a Turbo V6 in their trucks, this has been documented. And there's serious talk of the adding an 'Ecoboost' Mustang model in between the 2011 base V6 and GT, too. Further our Camaro 'sources' on Camaro5.com have told us of a 3.8L turbocharged V6 engine that's undergoing research and testing for that car, too. I only mention this as indirect evidence that the prospect of a Twin-Turbo sports car is not impossible.
Again, don't construe anything I'm about to say as though I'd rather have a Boosted V6 instead of a good OHC V8s. I don't.
In the spirit of continuing this conversation, please consider these points.
--Turbocharged V6s give nothing up in torque to their V8 counterparts.
--They are much more easily modified for more power. As with manufacturer tunes for the Solstice and Cobalt turbo models, you can just "turn up the boost" for 20% + more power (and keep your warranty!!).
--They are more easily packaged into smaller vehicles, due to the turbochargers not inherently "attached" to the engine. You can plumb around things and move them with more flexibility.
--They have the potential to be FAR more fuel efficient than equivilant powered V8s. Notice I said potential. As in the case of the Cobalt, it's base 30mpg rating (before 'XFE') was maintained in the turbo SS version, but it gained 100 hp and ft/lbs. So, it's not unreasonable to expect an coupe and convertible model of the C7 get a 30+ mpg rating, while maintaining it's 400+ hp/torque.
I see the last point as the primary rationale behind this move, if ever the Corvette team decided to do it.
Thoughts?
They can provide the power. However, I wonder what is the fuel economy of those cars versus the Corvette? Real world, everyday use.
I think I already know the answer
Ford intends a lot of things... but the F150 doesn't have an EcoBoost V6 yet. It's reasonable to believe such a beast will see the light of day, because Ford has a lot invested in the EcoBoost brand, but it's quite another thing to think it'll still be around five years later or it'll have killed the V8.
As for the potential to be FAR more fuel efficient than EQUIVALENT V8 powertrains, we're years from even seeing that scenario put to the test. Remember, the current rash of turbo sixes (and turbo four underhood of the departed Cobalt SS, Sky, and Solstice) have had technology applied to them that hasn't yet been applied to the domestic V8s.
"Turbo V6s give nothing up in torque to their V8 counterparts." Are you sure? I say there's insufficient sample size. You're not comparing Ford's cutting-edge EcoBoost to its long-in-the-tooth 4.6L, are you? Or Godzilla's motor to the base Vette?
"They are much more easily modified for more power." You don't really think nobody's going to notice that you've turned up the boost when you attempt to use that warranty on your damaged motor, do you? There's no such thing as a free lunch. The Turbo V6s that give nothing up in torque to their V8 counterparts will be highly tuned from the factory, and those guys are wise to warranty shenanigans. The days of the Eclipse GSX and Supra Turbo are behind us. And you can get big power boosts out of NA V8s too, if you don't care about longevity. Nitrous, anyone? And don't forget, for really serious power, the NA V8 can still take a turbo or supercharger and go where that smaller V6 can't follow...
"They are more easily packaged into smaller vehicles" -- often, but not always. A pushrod V8 is longer but vertically compact. And the turbo plumbing has *some* packaging flexibility but it still takes up space. And this is only an issue for the next generation anyway; present Camaro and Mustang are designed for V8s. You don't really think a next-generation Camaro or Mustang is coming soon, do you? One that's been designed with an engine bay too stubby for a V8? That implies a serious change in mission, not to mention styling. Camaro will disappear before it's built that way. Seriously, if Chevrolet's going to build an I4/V6-only 2+2 sporty car, they'll give it a different name, or go dark for five years first. As for Mustang... Ford has no suitable donor chassis, unless you think Probe Take Two is imminent, and I doubt they're going to invest big bucks in radical changes to the Mustang's unique platform as long as it still sells.
So, yeah, all this Turbo V6 action is interesting, but the case for dropping the V8 from Camaro and Mustang in the near future just isn't there.
And the Corvette's identity is so firmly planted in the V8 that, as I said before, it'll lose its V8 only when GM can't afford to maintain the design. Your suggestion that fuel economy might push the issue ignores the fact that Corvette is already a fuel-economy star among its peers... and its sales volume isn't significant enough to cause a CAFE panic, even if it does have to sacrifice a little efficiency in the name of keeping its identity.
The only scenario where I see the death of domestic V8 performance in the nearer-than-flights-of-fancy future is one in which the government flat-out mandates minimum fuel economy per vehicle (not fleet average) at absurd levels with no gas-guzzler-tax exceptions...
...which the People's Republic of California is certainly going to try, but those Birkenstock-bedecked a$$hats forget there's still serious car-loving and prestige-loving contingents to the culture, and once folks realize the impact of ratcheting down consumption limits there's going to be riots in the streets.
So, not to be hostile, but until there's some evidence that pickup trucks are going to lose their V8s or the ponycars are going to be replaced by small-sedan-platform-sharing coupes -- and before you start posting links, keep in mind that most talk of future product plans in this age of instablogging is outsider conjecture heaped upon the back of the faintest sliver of real news -- all this V8-bowing-to-turbo-V6 talk for domestic performance cars is either Ford FlavorAid consumption or fear-mongering.
And BTW, the Porsche doesn't have a turbo V6. That's a flat-six, and it's there because it's part of the 911 DNA. The Turbo V6 in Godzilla? Same story. It's not that geeks with a clean sheet of paper chose a blown six for inherent superiority; those cars have those motors because that's what they had to work with.
Still, I think an EcoBoost V6 Mustang "welterweight" could be cool. Import buyers might cross the line for it.
.Jinx
Just a few things, though...
Oh, and please, call me Joe.
It also achieves excellent gas mileage -- on a recent trip to Ohio from NJ, Dad and I (close to 600 lbs between us) achieved 27.5 mpg to, and 31.5 mpg from, including many hills -- and this was with the air on, and the top down/windows up. Astounding. And even in 6th gear, the car still pulled away from all other cars up the steep hills at over 65 mph without downshifting to 5th.
Although smaller displacement turbo engines have the capacity to achieve excellent mileage, most don't seem to, at least in Car and Driver tests -- with the exception of some BMW turbo'd cars. I think for me, the Vette's V-8 has so much torque down low, that I don't have to goose it as much to get the "Push in the back" feel.
If GM could make the smaller powerplant have a similar feel to what the vette has now, I'd be okay with it. I have a late model Altima with the VQ V-6 and it sounds nice ripping along, so I'm cool with that.
But I don't think there is much to be gained by going to a 6 cyl. model in terms of MPG, other than having more compact packaging options.
Hopefully, GM continues to have their minds in the right place with the continued development of the Vette - it has always been GM's bright spot. If you ask me -- they have made excellent choices regarding the Vette.
TomZ
My guess it will be a Hybrid so we can hang on to our V8's!! This also ties in with GM's move with Volt etc (also GM's quest to sell more Vetts in Europe).
Audi have avery clever Hybrid system where the electric motors are build into the gearbox & lightweight slim batteries under the centre of the car keeping the weigh distribution balanced.
That Hybrid system of Audi's you mention sounds incredibly similar to GM's dual-mode Hybrid system it co-developed with BMW...
