C 7 engine
Old Dec 29, 2010 | 09:53 PM
zrone90's Avatar
zrone90
Default C 7 engine
My corvette club passed this info out the other day. Is this old news? There was a picture with it of a renditon I have not seen before but could not copy it.
By Drew Johnson
Seemingly confirming one of the worst kept secrets in the industry, a
General Motors insider has revealed that the next-generation Chevrolet
Corvette will be one of the first road-going vehicles to feature GM’s new
5.5L V8.
According to one of Motor Trend’s inside sources, the Corvette C7 will come
equipped with GM’s new 5.5L small block V8. The new mill will feature a
number of technical advancements — including direct-injection and a new
combustion system – but will retain its old school overhead valve design to
cut costs and keep the engine compact.
Power for the new engine will likely total 440 horsepower, which would be a
slight improvement over the 436 horsepower currently available in the C6
Corvette. However, thanks to the 5.5L’s smaller size and its advanced
features, expect a noticeable jump in overall fuel economy – improving on
the C6’s already impressive 26mpg highway rating.
Chevy’s new 5.5L has already made its world debut, appearing between the
fenders of the C6.R racecar. GM has also committed $890 million to
develop and produce the new small block. Expect to see the C7 Corvette in
2012.
Old Jan 3, 2011 | 05:14 AM
Joe_Planet's Avatar
Joe_Planet
i wonder what the tq will be?
Old Jan 9, 2011 | 12:34 PM
vette54728702's Avatar
vette54728702
zrone90, is there a link to the picture / rendition so we could see it ?
Old Jan 10, 2011 | 04:00 PM
Vette_Pilot's Avatar
Vette_Pilot
I hope that there will be a strong market for the C7!!!
Old Jan 12, 2011 | 04:55 PM
NORTY's Avatar
NORTY
Here's the only pic I have of the engine~
not bad for a toy!
Old Jan 13, 2011 | 08:32 PM
Tim01Coupe's Avatar
Tim01Coupe
As my Ford engine Lead Engineer buddy says "massive amounts of torque" in this configuration. Check out Ford's Eco Boost V6 for an idea, add cubes and two cylinders. Do the math. He told me about these engines 6 years ago and I am still amazed.
Old Jan 15, 2011 | 02:15 PM
BluegrassMotorsport's Avatar
BluegrassMotorsport
I believe the engine is supposed to be a 4.4 instead of a 5.5, but all the other information seems to be in line with what other sources have reported.
Old Jan 18, 2011 | 11:42 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I heard them talking about the 5.5 liter motor well over a year ago while watching the C6R's racing at ALMS. Its what engine they have been running ever since they switched from GT1 to GT2 class.
http://www.corvetteracing.com/cars/g...t2-chart.shtml
http://www.corvetteracing.com/technology-transfer.shtml
Where the C6.R and ZR1 differ significantly are in situations where GT rules actually prohibit the use of the more sophisticated ZR1 components. For example, the ZR1 is equipped with carbon-composite brake rotors, while GT regulations require ferrous (steel) brake discs. And, where the ZR1 utilizes a 6.2-liter supercharged\ V-8, the C6.R uses a naturally aspirated, production-based 5.5-liter small-block V-8.
The Corvette C6.Rs' engines are developed, built and maintained by GM. Designated LS5.5R, the naturally aspirated powerplant is based on the Corvette Z06's 7.0-liter LS7 engine (which in turn was developed with the 7.0-liter race engine used in the C6.R GT1 cars), and is built with a production cast-aluminum cylinder block.
Pending GT2 class regulations specify a maximum displacement of 5.5 liters. The reduction in displacement to meet this requirement was achieved by shortening the crankshaft stroke and reducing the cylinder bore diameter. In accordance with the regulations, the race engines have two 28.8mm diameter intake air restrictors. The LS5.5R engines are equipped with dry-sump oiling systems, CNC-ported aluminum cylinder heads with titanium intake and exhaust valves, and sequential electronic port fuel injection. The race engines use E85R ethanol racing fuel in the ALMS and E10 fuel in Le Mans.
I just hope GM learned something about there new 5.5 Liter motor when both C6R's blew there motor at last years 24 hour Le Mans race in France ...
The No. 63 Corvette C6.R retired from the 24 Hours of Le Mans shortly after 7 a.m. this morning after completing 225 laps. Antonio Garcia was on his out-lap after replacing Johnny O'Connell in a routine pit stop when he reported a noise entering Mulsanne corner. Telemetry confirmed a problem, and the engine expired before he reached Indianapolis corner.
http://www.corvetteracing.com/histor.../lemans6.shtml
No. 64 Corvette C6.R retired with an apparent engine problem.
http://www.corvetteracing.com/histor.../lemans7.shtml
Toque
Old Jan 19, 2011 | 02:24 PM
JerriVette's Avatar
JerriVette
Cadillac ATS V info released today with 6.2 liter direct injection Vvt putting out 470hp 438 lb/ft and I believe the c7 engine will share
Old Jan 19, 2011 | 04:52 PM
The Highlander's Avatar
The Highlander
I agree
Just 4 more horses from a bump in generation? Not bloody likely.
Old Jan 19, 2011 | 06:38 PM
I Bin Therbefor's Avatar
I Bin Therbefor
Default Utterly facinating
http://www.thetruthaboutcars.com/201...s-engine-list/
This is NOT a GM announcement, but interesting speculation. As Corvette usually has a small power advantage, I suspect for marketing reasons, do you suppose that the C7 will retain a 6.2 liter with direct injection and Vvt with say 480 to 500 hp, and better gas milage in the street version instead of the assumed 5.5 liter? Is this the Z engine with the 5.5 liter the regular engine? What happens when you put a blower on it ala LS9?
The plot thickens!
Last edited by I Bin Therbefor; Jan 20, 2011 at 05:21 PM. Reason: Missing reference
Old Jan 19, 2011 | 08:38 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Someone who is a GM supplier and partially involved in the C7 development program says the new engine will be smaller than the 6.2L, but not a 5.5L. No indication as to whether bigger or smaller than 5.5, but HP is said to be right around the current numbers. So that 440 number could be a preliminary but correct rating.
Old Jan 19, 2011 | 11:12 PM
danl72's Avatar
danl72
It will be very interesting to find out what GM will do. As long as it is not a V6, I am fine with it.
Old Jan 20, 2011 | 03:46 PM
RichieRich's Avatar
RichieRich
Originally Posted by highlanderc
I agree
It's 2011, bud. Look at Audi's S4. They DROPPED the power from the last gen to current gen and they're still selling like hotcakes because everything about the car is better, including the performance despite the slight drop in peak HP.
I would expect a modest increase in power, but a substantial increase in area under the curve, refinement, and most of all, fuel efficiency.
Old Jan 20, 2011 | 04:47 PM
JQuest54's Avatar
JQuest54
They can give us 4 HP so long as they take 500 lbs. I'd trade that any day.
Old Jan 20, 2011 | 11:37 PM
Gearhead Jim
St. Jude Donor '13
The big questions are; will they actually take away the 500 lbs or something close, and what will it all cost. A $70,000 stripped base Corvette that's only 150 lbs lighter than today would not be attractive to very many people.
Stay tuned!
Old Jan 21, 2011 | 01:18 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
5.7?
That would be new...
To C 7 engine
Old Jan 22, 2011 | 09:14 AM
vettedoogie's Avatar
vettedoogie
Yeah, they learned the NEW engines needed some tweaking and when they did, they won Petit Le Mans. How's that?
http://www.youtube.com/watch?v=TQqRU...yer_embedded#!
Old Jan 22, 2011 | 05:20 PM
Toque's Avatar
Toque
I saw that and thought that was great !!!
10 hour race though... 24hrs is quite a bit more though. Hope they pull it off next year.
Toque
Old Jan 27, 2011 | 02:13 PM
GARYFINN's Avatar
GARYFINN
From: S/W ,Fla-Ohio State Football isn't a matter of life or death,Its Much More serious than that
not bad for a toy!
