C7 Mule Cought Testing pics
Old May 27, 2011 | 05:04 PM
C6-Stingray's Avatar
C6-Stingray
Default C7 Mule Cought Testing pics
Here
http://blogs.insideline.com/straight...-turbo-v8.html
Old May 27, 2011 | 05:23 PM
Z_Rocks's Avatar
Z_Rocks
I can not believe for the next two years, we have to go through these rumors tortures!
Old May 28, 2011 | 02:28 AM
Senna1994's Avatar
Senna1994
The C7 is under that car. You will see more by summer, keep an eye on those wheels.
Old May 28, 2011 | 03:03 AM
McGirk94LT1's Avatar
McGirk94LT1
The wheels??? That is the c6 logo in the center, although it doesnt look like a center cap, as if the middle is a solid piece. And im pretty sure I've seen those wheels before somewhere. Refuse to believe you know anything about it. I believe its a new engine in there but come on dude.
Edit: Yeah they are just new wheels for 2011+. Add your name to the list of people acting like they know something but dont...
Old May 28, 2011 | 07:09 AM
I Bin Therbefor's Avatar
I Bin Therbefor
Default Sure looks like one
Originally Posted by C6-Stingray
Folks been asking, where are the mules?
These pictures have all the right attributes for showing a genuine mule; license plate, published by Priddy showing twin vs quad exhaust.
IMO, there's a turbo V6 under the hood. But only IMO.
Old May 28, 2011 | 11:39 AM
bgreen83's Avatar
bgreen83
I hope they offer a v8 turbo. Easy to turn up the boost and upgrade turbos.
Old May 28, 2011 | 12:09 PM
Z_Rocks's Avatar
Z_Rocks
I very much doubt GM will do a V6. Maybe a smaller V8 but not V6. It will turn people off.
Koenigsegg, has a 5.0L V8 making big numbers
Engine
Koenigsegg aluminum 5,0L V8, 4 valves per cylinder, double overheadcamshafts
Compression: 9.0:1
Bore: 91.7 mm Stroke: 95.25 mm
Sequential, multipoint fuel injection.
Twin turbo superchargers
1.3 bar boost pressure.
Dry sump lubrication.
Performance
Power output: 940 hp at 6900 rpm – redline @ 7250 rpm
Torque: over 1000 Nm from 2700 to 6170 rpm
Max torque: 1100 Nm at 4000 rpm
Acceleration: 0-100 km/h (0-62 mph) 3 seconds
0-200 km/h 8.0 sec, 0-200-0 km/h 13.5 sec
This should be the direction GM would take to go after a bigger market.
Just my two cents!
Old May 30, 2011 | 05:03 AM
Lothar34's Avatar
Lothar34
Engine
Compression: 9.0:1
Performance
Just my two cents!
A turbo V6 wouldn't turn me off. They could come close to the current power levels with a TT DI 3.6 and probably get better mileage. It's not written in stone that the Vette has to have a V8.
We're already pretty certain that the next SB will be a 5.5L DI engine with no turbos...
...but it'd be cool if those heads fit on the Gen 3 and 4 engines. Big boost plus use the inejctor holes for an aftermarket direct meth injection kit =
Old May 30, 2011 | 08:44 AM
Kenny94945's Avatar
Kenny94945
I think this is a legit pic and the first "spy" photo.
Keep your camera and video out for interior, suspension and brakes, wheelbase and sound!
What town was the mule located? Detroit? Bowling Green? Be ready CF co-members!
Old May 30, 2011 | 10:35 AM
jazzlove's Avatar
jazzlove
From: San Antonio Texas - Any sufficiently advanced technology is indistinguishable from magic
Yea....Aaaaarrrgggh!
Old May 30, 2011 | 05:02 PM
TGstring's Avatar
TGstring
From: cruising between USA and Canada... SAVE THE WAVE!
I'd venture to say it's legit and a mule as well.
As for what motor?
don't know.
Not sure whey they didn't walk up to the car and snap a few good ones of the interior...
Old May 30, 2011 | 10:17 PM
I Bin Therbefor
But a mule for what? The C7 or the additional product line intended for BG? Maybe the running gear for a Cad coupe? A Cad coupe would make more sense as the home for a turbo charged engine with the Corvette staying with a pushrod engine. Recall that the previous attempt by Cad at a coupe was a double overhead cam engine. So putting two different engines in the same basic chassis architecture is no trick.
Old May 30, 2011 | 11:14 PM
69L79's Avatar
69L79
From: Hamilton Square NJ, Ocean City N. J. Key Biscayne Fla.
Those two little skinny tail pipes sure look imposing.
Old May 30, 2011 | 11:26 PM
SCM_Crash's Avatar
SCM_Crash
Well, here we go again with speculations and such.
I will say this, though. I'm not an expert on C6 stuff, but it sure looks like the front of the car is sitting higher than usual. (correct?)
If so, whatever is under the hood is lighter than the LS3 setup unless it's just missing lots of stuff like A/C components and what not.
Old May 31, 2011 | 12:51 AM
ZL-1's Avatar
ZL-1
They often use earlier model un-saleable pilot cars for mules.
With its less-bright red and GM Mark of Excellence chicklets, this one appears to be one of the 2006 pilot cars.
The 15-spoke wheels are from the GCA catalog of dealer-installed accessories.
We'd like to think there is something special under the hood. Stock mufflers are quiet yet pretty efficient, so what on earth kind of engine couldn't just be plumbed into the stock mufflers? ...maybe it has turbos which silence the exhaust so much that louder mufflers were needed to give it a little better sound??
Just speculating...
Old Jun 1, 2011 | 01:27 AM
Jinx's Avatar
Jinx
Maybe this is an engine mule for a completely different FR car.
BTW, isn't the stock base exhaust just a dual exhaust with double tips?
Old Jun 1, 2011 | 07:39 AM
HarryWild's Avatar
HarryWild
What C6 is this? It does not look like the GS model. Anyone know?
By the way; I like the wheels with this Corvette, that why I am asking.
To C7 Mule Cought Testing pics
Old Jun 1, 2011 | 08:05 AM
GiggityGiggity's Avatar
GiggityGiggity
base model, rims are new tho, not available on C6 from GM as OEM, you might find it in the GM catalogue tho.
Old Jun 1, 2011 | 08:45 AM
Mitch3000's Avatar
Mitch3000
They're GCA wheels as ZL-1 posted above.....
Old Jun 2, 2011 | 03:40 AM
HarryWild's Avatar
HarryWild
Thanks for the replies.
That is the exact setup - color and wheel style that I want for the further C7.
