C7, best data as of June 2011
#61
I could see GM going with the smaller CID with direct injection (with the base model) to improve MPG and possibly sales. I would be heartbroken to see the Z06 transform into an LSA clone ... I don't think they are going to do that simply because it would probably kill the sales of the ZR-1...
We'll see the C7 coupe as a 2014 model with the DI 5.5 V8. Maybe the vert will be ready at s.o.p. too. As far as the C7 Z06 goes, no need to introduce it immediately, they'll have to focus on QC and production of the base cars which will be in big demand at first.
Sadly, the ZR1 and the 427 LS7 will die with the C6. By 2014 with our ever-increasing regulations they'll be unacceptable. It was wonderful that both were built, but they did compete with each other for sales. The C7 Z06 will combine the best of both and hopefully top their performance. It does seem wrong to add a supercharger to a track car like the Z06. But by then GM will have had over 5 years experience
supercharging LS engines and optimized efficiency and heat issues. Maybe it will be a decent track car.
A Z06 that's heavier than a base coupe doesn't sound right but maybe we can accept it if it's lighter than any previous Z06.
The 5.5 liter V8s will be at the introduction of the C7. Who knows what models and engines and technology will come later...
#62
Every time a new generation of Corvette is coming it's fun to speculate about all the wild possibilities. But after much research and separating educated guesses from insider knowledge, here is the most reliable prediction:
- Currently it looks like production will start in June 2013
as a 2014 model.
- C7 engine is a direct injection 5.5 liter V8 with cylinder
shut-off, goal is 440 hp, 20 mpg city, 35 mpg highway.
- Z06 will have the 5.5 liter with an Eaton supercharger, the
smaller 1900 as used on CTS-V and ZL1, not the 2300 ZR1
unit. (No plans for a ZR1 model at this time).
- All models will get an aluminum frame built in-house at
Bowling Green (up until now Z06/ZR1 frames have been
built by Dana Corporation in Hopkinsville KY).
- A 6-speed dual-clutch transmission is planned, unsure of
the source or if it will be available at start of production
- There will be a large touch screen but many functions
will be controlled by a central menu/select ****. There
will be a better-integrated voice activation system,
similar to Ford's Sync system.
- More weight saving aluminum and carbon fiber parts,
including the removable targa roof panel.
- More carbon fiber interior panels and leather, and far
better seats. A very nice interior.
- Styling is reminiscent of the concept Stingray and
Sideswipe movie cars from the side but front and
rear are more traditional Corvette, headlights similar
to C6 and round taillights.
- All interior and exterior lighting is L.E.D.
- Much of GM's $131 million investment in Bowling
Green will go to upgrading the plant to build the new
aluminum frame and to add stations to build right-
hand-drive versions to increase Corvette sales
worldwide.
All "speculation" of course. Does anyone have more
facts to add?
as a 2014 model.
worldwide.
facts to add?
Nice! Very reasonable and sensible. Could you comment on:
1) Eight-speed automatic transmission?
2) Expanded usage of magnesium?
3) Goodyear or Michelin tires?
4) Features of the 5.5L Gen V small block:
-- Two or three valves per cyclinder?
-- Cam-in-cam?
-- High or low pressure DI?
-- Side or central injection?
5) Rear hatch - glass or polycarbonate?
#63
Received 4,376 Likes
as a 2014 model.
as a 2014 model.
I don't think they will go with the supercharger on the Z06. They don't need to. They could probably get to 505HP with a DI 6.2L or a little more with cam phasing or cam in cam or a 6.4L. A supercharger takes HP and therefore fuel to drive so it hurts mileage to get the same HP. Plus it get tuned a little richer on WOT to protect it.
I think the ZR1 will go turbo when it comes out. It will be more fuel efficient. Will they go with a 5.5 with higher pressure or a 6.2-6.4 with lower pressure? I don't know, maybe the 5.5 for a slightly stronger block.
I think it is possible that they could lose substantial weight in the interior with lighter seats and lighter sound deadening and other materials. Maybe go to a lithium ion battery (ok $2k to replace a battery seems like a lot).
Lots ideas and ways to lose weight, it just cost money
#64
How about 10% size downscale = 5-10% reduced weight
More exotic material = another 2-3 % reduced weight
Pneumatic valve control= reduced weight AND almost unlimited rpm
Dual clutch = better performance AND better mpg
Less weight= smaller tires, = better mpg and better performance
Cw down to 0.28 = better mpg AND better performance
Even with "only" 505 HP from 5.5 GDI it would perform better than current Z06
So please GM, surprise us
Rune
Rune
#65
Uhhhh.....wrong try again please. Comparing a turbo to a NA motor is a very poor analogy and example. And as another posted already pointed out just look how power output has gone up in conjunction with fuel economy over the past 50 years. It is possible to make more power with better fuel economy - especially with a properly setup turbo motor. Your oversimplification of "physics" is flawed and therefore incorrect
#66
well i must say everyone has their own idea of what they want the new c7 to be for me i dont much care what it has for a power plant as long as it still kicks but on all the big boys
i just recently got my first c5 or any vette for that matter and with 140k on her is averaging 26.8 mpg i have put 3800 miles on car since i bought it. this much fun and great fuel economy at the same time should not be legal
as far as 10k rpm i dont think that is all that hard to get nascar runs pretty close all day long. na is great but what about the extra volumetric efficiency that a little press brings to the table. with cam phasers and di and all the other benis from modern electronics it only makes sence to add turbos or superchargers. look at what a new diesel truck can do. you better not miss a gear with some of these boys.
my hot rod before my 00 hrc was and still is 87 turbo regal. both seem to get along in garage so far. remember back in 87 who owned the streets and with only 231 cubes and 15psi
if i had my way i want awd for wet traction fat torgue down low for less shifting and nice hp number up top wait come to think of it i like my c5 it is perfect it cruises down the road at barely 1300rpm doing 70ish will accelerate without a downshift it is so lite and nimble great aero every where i go with it people always admire it and ask questions PERFECTION
#67
The way the new Porsche 991 is looking, the C7 will be just as light, smaller, and much more powerful.
#68
Runge_Kutta seems to have knack for finding online patents, and other similar information. What I have seen from the information he posted from back in 2008 was:
5.5L OHV Direct injection with Cylinder deactivation
6.2L DOHC Direct Injection with Cylinder deactivation
both have cam phasing
6.2L as a potential 3V Engine.
This was from GM/Delphi presentations. Much of Runge's "speculation" on the C6 Z06 was spot on as well (based on filed patents). So, I tend to put faith in patents and information such as what was in the .pdf files he posted links to. But, that does not mean GM can't change the displacement, or make other changes in subsequent 3-4 years since many of those were filed.
#70
#71
The touch interface you were talking about sounds like the CUE concept that they are going to be putting in all the Cadillacs..
I would not be surprised if GM put this in the Corvette.
http://www.pcworld.com/article/24177...ml#tk.rss_news
I personally wish the corvette has this interior touch system:
http://www.viddler.com/explore/engadget/videos/3321/
I'm quite tempted to look very hard at the new Tesla.
#72
Let's put this displacement conversation to bed...NOW.
A 5.7 liter V8 with direct port injection, valve or cam timing, etc, making, say....500hp at 4,000rpms....
VS
A turbo charged 3.0 liter V6 with direct port injection, valve or cam timing, etc, making, say...500hp at 6,000rpms...
You know what BOTH of these guys have in common? They use the same AMOUNT OF GAS!
VS
#73
No, they don't. The turbo engine needs 11:1 AFR to survive under boost conditions whereas the NA engine can run at 13.5, and for a more precisely metered DI engine, damn close to 14.5. So the larger-displacement NA engine produces it's power more efficiently. It is also about 100lb lighter, more reliable, and packages in about 2/3 the space of the turbo motor. Advantage "big displacement" V-8...again.
Look at the new 2012 BMW 528i. It's a 2L turbocharged 4. If you actually look at the performance and fuel economy stats for this new engine, it's pretty hard to argue with. I'm not recommending a 2L engine for the Corvette but the writing's on the wall on this issue and I'm afraid there's no getting around it.
#74
Turbos are the most efficient way to get displacement on demand. Artificially adding displacement with a turbo gives you the ability to have a no-boost 2L engine that turns into a 5L engine with just 22Lbs of boost.
This was the exact scenario for the Solstice GXP and Sky Redline. 2.0L that boosts up to 22Lbs. (That's 1.5 bar) On paper you double your N/A power for each bar of boost you add. The solstice had 260HP and got 42 MPG. (I know because that's what I got when I drove it from Los Angeles to Phoenix and back.
HOWEVER, this isn't something I want in the Corvette. I think GM knows best. The 5.5L is going to be awesome.
BTW, I didn't buy a Corvette for economy.
#75
The truth of any of these threads are nobody knows for sure, I am still saying that this threads et. al. are 99.99% speculation. We will all know for sure when GM unveil's the model in a couple of years!
But its still interesting to read the posts to get somewhat of an idea of how this car will turn out.
