I agree. Too retro hot rod for modern cars. Besides the aero effect and the conflict with side skirts, you wouldn't put them on Vettes unless you could put them on the ZR1 and I like the skirts better.
Looks and aerodynamics are easily overcome as seen in the new Viper coming out.
There are both pros and cons to side pipes and the 2 biggest pros are getting heat out from underneath the driving compartment as well as making the underneath the car much easier to work on with the exhaust system out of the way.
Cons were associated with tuning around the extra bend in the exhaust, and getting enough sound reduction out of skinny mufflers without introducing too much back pressure.
The old C2 Corvettes looks-wise did well with side exhaust, but despite all their ferocious sounds they choked off horsepower, and on long freeway trips, the exhaust right behind the ear became very annoying.
On mine I used spacers to get the covers to fit over 4 inch side-pipes with spirals instead of baffles that would cause birds to nests to fall out of the trees
That C6 in the Magazine looks utterly ridiculous with those pipes on there.Yes,to each his own and thank God for that!SIDE PIPES on a 67??Sure.No place for them on the new Vette.
Maybe if they where to exit Merc. McLaren SLR style. Hard to run them all the way under the door exposed and not look clumsy/out of place on a modern car.
I am shocked people are not overwhelmingly putting yes. How do you not like to emulate the C6R???
Because the OP specified pipes, not exhaust. The C6R is not what comes to mind when you think pipes. Plus, he's asking about the base model C7. Seems like the C6R setup might be more appropriate for the race version of the C7 than for the base street version.
I'm not convinced side would pipes do the driving compartment any favors - now you've got to cram mufflers in there, which would almost certainly reduce legroom, and unless they exhaust immediately behind the front wheel, the occupants are _still_ surrounded by hot exhaust pipes (except now the weight has been relocated to the extreme edges of the car, precisely where you don't want it).
Even worse: 1) they're going to be dangerously hot, unless they're shielded, in which case they'll be pointlessly heavy. 2) They're going to leave soot all over the side of the car. 3) They're going to get smashed up and ugly after a few run-ins with speed bumps and after every trip to the dealer. If anything, GM needs to make the Corvette rocker panel area less fragile, not more fragile.
I do like sidepipes on an AC Cobra 427 (real or replica) or maybe even on a '63 - '67 (midyear) Corvette but not so much on a modern era Corvette.
Although the Vipers made them look good as well.
