release date for trans. and diff. specs. ????
2.29 X 3.90 = 8.93 = 58 MPH
1.61 X 3.90 = 6.24 = 83 MPH
1.21 X 3.90 = 4.72 = 111 MPH
1.00 X 3.90 = 3.90 = 134 MPH
0.81 X 3.90 = 3.16 = 165 MPH
0.67 X 3.90 = 2.61 = 200 MPH
0.43 X 3.90 = 1.68 = good gas mileage
Compared to the C6 entry level transmission
2.66 X 3.42 = 9.10 = 57 MPH
1.78 X 3.42 = 6.09 = 86 MPH
1.30 X 3.42 = 4.45 = 117 MPH
1.00 X 3.42 = 3.42 = 153 MPH
0.74 X 3.42 = 2.53 = 207 MPH
0.50 X 3.42 = 1.71 = good gas mileage
But at least something in the 3.55 range would be nice.
I hope not either, I'm hoping for only two overdrives and the rest making up a very tight, close ratio gearbox but I'm not counting on it.
I do track my Z06 probably 30 days a year at high speed (think Sebring) tracks and would really like another gear to use at the track. We basically
use 3rd and 4th at the track.
And I do plan to track the C7 from day 1.
I will let you know how she does.
A couple of optional ratios would be nice but I doubt we will see that..
But we can hope.
Any dates for the drivetrain release??????
A 3.73 rear (either standard or optional) for the manual car and maybe a 3.2x or 3.3x for the automatic (with it's much steeper first gear I assume?) would rock.
With all of these proposed/rumored extra transmission gears and tall diameter wheels/tires it could still deliver the fuel economy too.
IMO gear it to just touch 200 - 205 mph. With a 6 or 7 speed gearbox, youll still get decent mileage at american highway speeds in the final gear without screwing up the character of the car.
Jack junior, is that you?
The new 7-speed trans is likely to have new gear ratios, not just another gear added to one of the 6-speeds.
A 7-speed manual trans with evenly spaced rarios sounds like a great idea, no more big rpm drop to the tall overdrive ratio. Initially I was envisioning an aggressive overall ratio in 1st gear like the C5Z06/C6Z51/C6GS, which is a lot of fun. But that would require a 1-2 shift before 60, increasing 0-60 times. They're claiming the base C7 will do 0-60 in under 4 seconds.
As with the LS7 and LS9, they might use tall gearing to allow the C7 to reach 60 in first, no 1-2 shift to hurt the all-important 0-60 bragging rights.
Assuming tire diameters remain about the same and with the 6600 rpm redline, the overall ratio in 1st would need to be around 8:00 to 1 or less to do 60 in 1st. If a 3:42 axle was used this would require a first gear ratio like the ZR1's 2:29 or 2:23.
Gearing like this doesn't sound like much fun for those of us who like to shift but the car would really be plenty quick with 50 ft/lb more torque and a couple hundred less pounds to pull.
The best solution might be to equip the light base car with tall gears for the best advertised 0-60 time and EPA numbers. The optional performance package (Z51?) could include better gearing in addition to dry sump, big brakes with slotted rotors, cooling upgrades, suspension upgrades, summer tires on 10-spoke wheels, etc. Heavier but more track-ready.
But it would be really great if the C7s are so damn fast that they can do 0-60 in under 4 seconds even WITH a shift...
But it would be really great if the C7s are so damn fast that they can do 0-60 in under 4 seconds even WITH a shift....
imagine a real engine, lighter car and shifts that is 60 ms
The current C6 GS will do 0-60 in 3.95 seconds and requires upshifting at 50.8 MPH(6500 RPM). No reason a 150 pound lighter car(base C7), with an increase 50 lbs-ft of torque down low and 14 more horsepower, and an extra 100 RPM, can't do 0-60 below 4 seconds including the time to shift gears.
In addition, with my transmission/axle ratios, the 1X4 CAGS becomes more usable. Currently, if you shift at 2,000 RPM(17.8 MPH) to 4th gear the RPM drops to 750 RPM. With my ratios, when you shift to 4th gear at 2,000, the RPM only drops to 875 RPM. With the current C6, once you shift to 4th you end up trying to accelerate and only have a 3.42 gear. With my gearing, you would have a 3.90 gear, which will help the car accelerate easier without lugging the engine.
