C7 Interior Comparisons
I rather like it when there is equal symmetry, that invites the passenger to have a role, in the entertainment, hvac, navigation etc., not one that shouts hands off, driver is a lonely control freak.
Automatic is more like an rc robot. Yeah it may have similar capability but there is no human inside of it clad in metal. The robot is not an extension of the human, it's simply a second lower capacity unit that is manipulated.
Stick shift is akin to playing the quitar, piano, or violin. Great brains, physically engaging an organism to multiply it's greatness through some basic extensions of itself.
Automatic is more like a synthesizer. Already produced waveforms, or ones built methodically combined, edited, altered. The brain is still at work but much less body connection is needed.
You say old farts want manual, I say farts of every age want auto. You can lie to yourself and think the mind-body-machine connection doesn't matter. In the end two things have to happen, the performance needs to be supreme, and sweat needs to be poured. If you only have to lift a finger to get great performance it won't be satisfying, in the same way a lot of effort for marginal result is not satisfying.
For me, the Corvette just wouldn't be the same if I couldn't row the gears. With a stick, I control all the timing of the acceleration/power equation. If I do my job correctly, those shifts cleanly slammed home, that clutch quickly engaged/disengaged, that push of the gas at just the right moment...it's just magic!
That is NOT to say there won't come a day when I will need an auto, especially with my bum left knee...but it will be a different experience. Not bad, just different. I do hope I live long enough to drive a great dual-clutch transmission (or equivalent) in a Vette.
Secondly, after teaching every generation that is younger than 50 years old I can day I would take the wisdom of an older person over the supposedly knowledge of youth.
What's next, we should all wear baggy pants because someone that is young does?
If Gm's plan is to design the C7 for the younger buyer, they will fail. All expensive cars are mainly purchased by older buyers. Corvettes are driven by elite folks because we can afford to have a toy that expensive. Trust me, twenty yeast olds would love to drive a C7 if they could afford it.
For the record, I will drive an auto or stick because I want to, not because someone else is driving something they like.
Porsche 911 buyers continue to be 48-52 years old on average, generation after generation, which means it is an aspirational goal for those in their 30s , which marketing loves.
Corvette's buyer average age is creeping up a few yrs with each of the last three generations and is now late 50s and that is what worries GM beam counters.
You see a lot more white haired guys driving new Corvettes than new 911s and that is not a good long term trend .
Corvette needs to attract more buyers in their 40s .
It all makes sense if you ever track one of these guys. The digital tach is up top, it's large, and it lights up when redline is reached. It's helpful if an open pipe car is around you and the sound of your own engine is not there to alert you when to shift. So if you can't rely on sound, you can generally get a very good idea where in the rev range you are by looking through that steering wheel for a split second.
The air vents are located where the hands are usually sitting on the wheel, so that on a cold top down morning your fingers don't freeze and you can continue driving.
The volume and fan speed are hand molded pieces that are very intuitive and don't require a look. With the exception of the tach, which is made as clear as possible, you can drive the **** out of this car without ever looking off the road, while controling the stereo and A/C.
The stereo lid on the earlier models is even better, all black and completely hides the radio for a pure drive. In fact, aside from one vent, that's all the passenger gets access to, as it should be!
Maybe an F1 car where you don't need more than 1/4th of a turn to u-turn can benefit from the extra leg room. But in a passenger car with a high steering ratio that flat part cannot make room for legs under normal driving conditions and then you may have to run your hand over the flat spot too.
