Direct Injection Technology
Old Jan 6, 2013 | 12:05 PM
dabmeister's Avatar
dabmeister
Default Aftermaket Direct Injection Technology
Does anybody see this technology available to the masses in the near future? I understand it's new for the corvette but not so for some other gm makes.
Will this eventually make its way to the aftermarket segment and become a game changer for us power thursty enthusiast? What parts other than changing the heads and fuel delivery components will be needed, along with the cost factor, making it a possible must have?
Old Jan 6, 2013 | 12:42 PM
Raitzi's Avatar
Raitzi
Technology was invented in 1902 but that is young compared to other corvette technology like leaf springs from 1804.
On serious note. DFI is very much today's technology and mass production of automobiles using this technology started in 1996. Ferrari adopted technology 2009 which is late that it had already been 15 years in cars costing tenth of the Ferrari California.
I see no reason why you put this to car that does no have it because it is very expensive way to try to increase power.
Old Jan 6, 2013 | 12:53 PM
hig4s's Avatar
hig4s
DI goes into the cylinder, not the head, depending on the design may need a different engine block not just heads.
Old Jan 6, 2013 | 01:33 PM
Frizzle86's Avatar
Frizzle86
Not sure it will make it to the aftermarket enthusiast. There needs to be some major changes in the engine/heads as compression ratio is higher and fuel pressure is also much higher then a traditional injector system.
If it does become available it will be expensive very expensive. Possibly 10 years down the road it might be 'cheap' or 'affordable'.
FYI some car makers have been using DI tech since 04 in their cars.
Old Jan 6, 2013 | 01:49 PM
93Rubie's Avatar
93Rubie
It may eventually come into the aftermarket, however, its is complex and VERY costly. As noted the block, heads,etc...all have to be setup for it.
Injectors, low pressure pump, cam driven high pressure pump (typically), hard lines,etc...all are needed.
You an run much higher compression ratios and get stellar air/fuel mixtures.
I don't see it taking off because of cost constraints in the aftermarket.
Most OEM application are more focus on fuel economy and emissions. Nissan for example has a 1.6 Turbo DI in the Juke. Makes 188HP stock. However, there is a lot of untapped potential in the engine, but the compression ratio is quite low at 9.5 to 1. Tune conservatively so it lives, gives good gas mileage, good drive-ability, and emissions.
Even the new LT1 is WAY lower than it should be. To me 11.5:1 is a joke. If you can run 11:1 in a LS7 with port injection. A DI on PREMIUM should be able to run 13:1+ no issue. GM kept it low so idiots can run 87 in the thing and not kill it. Waste of technology, IMHO. Granted they have MANY factors to consider, but the potential is there. They should use it.
If the aftermarket is going to do DI, its going to hack PCM's and tune it to work better for POWER over OEM concerns. All of this is IMO.
Old Jan 6, 2013 | 01:54 PM
hig4s's Avatar
hig4s
Mitsubishi started using it, under the name of GDI, back in 1996.
In 2003 GM used a DI engine in the Saturn Sky/Pontiac Solstice.
The V6 in the Cadillac (since 2007) and the new Camaro is DI.
Old Jan 6, 2013 | 02:17 PM
Jim Barker's Avatar
Jim Barker
Fuel pressure is the most difficult thing I see, GM uses tri lobe on the cam for hydraulic mechanical assistance. Stand alone pumps would be startermotor size driven positive displacement units to make lots of pressure
Old Jan 6, 2013 | 02:31 PM
glass slipper's Avatar
glass slipper
The fuel is injected into the cylinder through injectors in the combustion chamber of the head, not the block. It wouldn't require a different block.
Old Jan 6, 2013 | 02:40 PM
Jim Barker's Avatar
Jim Barker
GM had to build a whole new motor because of VVT and DI
Old Jan 6, 2013 | 02:45 PM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Which motor was that? Are you talking the new LT1?
toxin440's Avatar
toxin440
hell my 2012 Kia Rio has direct injection - but yeah, I don't really see it ever being so "cheap and easy" that you can add it to any car.
The whole thing has to be designed for DI to work properly, block, injectors, maps, all that jazz.
I'm pretty happy with the 1.6 putting out 138HP and giving me between 35 and 38MPG.
Old Jan 6, 2013 | 04:01 PM
Daekwan06's Avatar
Daekwan06
Isnt GM like one of the last manufacters to use DI? Seems like everybody is already doing it these days. GM has already done it in smaller engines.
Old Jan 6, 2013 | 04:25 PM
Jinx's Avatar
Jinx
I wouldn't expect a lot of direct injection retrofitting, but those engines that were built with direct injection will get tweaked, like everything that came before.
Old Jan 6, 2013 | 04:41 PM
Jet Streaming's Avatar
Jet Streaming
It would be nearly impossible to retrofit. I have it on my 2011 Traverse no problrms at all.
Old Jan 6, 2013 | 04:49 PM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
There are a lot of carbon problems due to early adopters of DI. My DD is one of them. With no fuel in the intake track and then the compounding problem with our emissions systems (PCV) it has led to a lot of issues. My car needs to have a carbon cleaning every 15000 miles to keep it from throwing a code. I can do it myself but Audi will charge about $1500-2000 for this service.
Old Jan 6, 2013 | 07:21 PM
BuddhaZ06's Avatar
BuddhaZ06
Like someone said gm has used it for a few years. As for v8, Ford doesn't have it yet. Just their smaller stuff. I wish they would've made it more compression
Old Jan 6, 2013 | 08:36 PM
Frizzle86's Avatar
Frizzle86
Ford, uses DI on their ecoboost engines. Their N/A engines remain to be DI free.
Found an article on why.
The strategy—instead optimizing the new Ti-VCT system and emphasizing breathing—paid off. Having the extra leeway with breathing allowed both engines to put out more power and torque than rival direct-injection engines, while the variable valvetrain boosts efficiency with low load. The new Ford Duratec 37 produces 305 horsepower and 280 pound-feet, while GM's 3.6-liter direct-injected V-6 makes 280 to 304 hp, and 266 to 273 lb-ft, depending on the application.
Fuel economy, too, is a strong point, with the V-6 expected to yield up to 30 mpg on the highway in the 2011 Ford Mustang and up to 25 mpg on the highway in the 2011 Lincoln MKX (and anticipated for the 2011 Ford Edge). GM's direct-injected V-6 achieves 18/29, at best, in the 2010 Chevrolet Camaro and up to 17/24 mpg in the (admittedly larger) Buick Enclave.
Note this article is from 2010. So this may not be up to date in how Ford currently feels about DI in their Naturally Aspirated V6's and V8s.
Link to article
To Direct Injection Technology
Old Jan 6, 2013 | 08:50 PM
BuddhaZ06's Avatar
BuddhaZ06
I don't get their point on the 3.6 thing. It makes 304-323 to their 305? It also makes more power than their 4.6 n/a v8's lol
Old Jan 6, 2013 | 09:56 PM
hig4s's Avatar
hig4s
Not really. from what I've read modern DI was used by the following manufactures in the corresponding years.
Mitsubishi 1996
Nissan 1997
Toyota 1998
Renault 1999
VW 2000
Alfa Romeo 2002
Ford, GM, and BMW 2003
Isuzu 2004
Mazda 2005
Ferrari 2009
Kia, 2010
Hyundai 2011
Old Jan 6, 2013 | 10:40 PM
Frizzle86's Avatar
Frizzle86
no... the Duratec 37 is 3.7L in displacement. It has no correlation to the 4.6 N/A V8 modular from ford was quite dated in 2010 (time of the article).
