I think the engine is about 30lbs or 70lbs pounds havier than the ls3..i forgot which one.
I don't think it's even possible that it could be a full 70 pounds heavier, but 20-40 pounds is possible when comparing wet sump to wet sump (or dry sump to dry sump) versions of each engine I suppose.
You are probably right and its not 70lbs difference.. but i thought its been discussed here before that its about 40lbs havier..
2900 divided by 465 = 6.24 ( you're living in a dream world)
2900 divided by 450 = 6.44 (to low a weight but okay on horsepower)
3000 divided by 450 = 6.66(realistic weight and horsepower)
3175 divided by 505 = 6.29 (actual Z06 weight and horsepower)
3355 divided by 505 = 6.64 (actual weight and horsepower of 427 convertible)
3208 divided by 436 = 7.36 (actual C6 weight and horsepower)
If you think the new C7 will actually make 450 hp you too are living in a DREAM world. And this is all useless speculation when no one but GM knows the real specifications on weight and Bhp.
So Vince, what do you think it's going to make, 490? Sounds like someone needs to wake up The funny thing is you accuse people of useless speculating, but you do the same. Sounds wacky to me Vince.
Well the C6 made 400 and the 02-04 C5 Z06 made 405 it replaced. Does it sound wacky now? Didn't think so. The difference it my sepculation is based on history sir. And who says it wont make 500 on E85 as in the previous articles and posts? Hmmmm sounds wacky to me again LOL!!!
The standard/base 2014 Corvette will NOT weigh only 2888 pounds.
Not even 2950 pounds.
Now, is 3040 - 3090 pounds possible?
Yes.
All i did was make some calculations based on the artical linked by the OP, these are only possibilities if the author is correct about the weight reduction. To the the people complaining about speculation, please, until GM releases all the info, the whole point of C7 General is speculating about the C7. Anyone who does not like speculation is in the wrong sub forum.
10% reduction is possible.
-Lighter engine
-Lighter frame
-Shorter frame
-Carbon, aluminium, plastics
-And more importantly lighter drivers
Agreed.
Also I think sub-3000lbs is entirely believable. After all they hit 3100 with the Z06 almost 6 years ago. You would think that advancements in technology could cut another 150lbs or so off the car.
