Weight benchmark
That is the problem.
PS, I've seen all manner of c4's rolled and wrecked. they actually hold up extremely well. i don't know why, they are barely held together to start with. maybe its' that whole 'flexible baby' thing.
I hate arguments where both parties are probably correct but operating under different assumptions.
Also, I agree about disappointment on weight -- if over 3100 lbs. Seems "marketing" (to whom?) and regs require a lot of "stuff" to offset the 150 lbs they cut out (at pretty high cost). Too bad if indeed true....
but it really is moot now, not only did i find that the vettespecs book shows 3152 curb weight for an automatic c4 (all fluids, ready to drive, with 20 (!) gallons of gas), that means a manual car with 16 gallons equivalent to a modern vette, and without the jack and spare, which the new cars don't have would have a 3052 curb weight, which is pretty close (within 35 lbs) to what mine shows on the scales.
also, the new info seems to indicate that the c7 is heavier than a c6 anyways, rendering the whole discussion moot except the main point, that the c6 is more of a jag or CTSV coupe competitor and not really a sports car.
You keep banging the same stupid drum, labeling everything that's not in a C4 as crap, when numerous people have pointed out all of the functional advantages and legal requirements that actually weigh stuff.
You are a one-note troll, and now you are ignored.
.Jinx
The supercharger put about 60-70 pounds on my C6 08 coupe.
As to point 2, my C5Z, and C6's I have driven, are plenty civilized enough for daily use. So, you cut out 150 lbs, and then add 250 pounds (estimated) more "stuff"?? I mean, tires aren't fatter, brakes are marginally bigger, safety regs barely changed (I think), interior niceties (after allowing for magnesium seat frames) cannot be THAT heavy, additional sound-deadeners should not be too heavy AND are unnecessary anyway, digital stuff should add the weight of a laptop max, etc, etc. Heck, a Boss 302 weighs ~3,600 lbs -- just seems like a trim 2-seater should be more than 300 lbs lighter, especially with an OHV engine, aluminum frame, CF hood and Targa panel, etc.
Man do I hope we are somehow misinterpreting or Juechter was misquoted and has decided not to respond...
My thirteen year old, $16K (used) Z, @ >200 lbs. lighter and nearly 400 HP, sure seems like the performance bargain of the century at this point!!!!!
examples: c7 engine - probably 110 pounds lighter (ls3 is 125 lbs)
c7 v. c4 c7 emissions system - at LEAST 10 pounds lighter
c7 frame - at least 150 pounds lighter
c7 body - probably significantly lighter despite size
c7 headlights - at least 20 pounds lighter
c7 magnesium seats - almost certainly lighter
c7 wheels - probably lighter, those old 16's are over 26lbs
c7 drivetrain - maybe 20-50 lbs heavier, 4+3 is no feather
c7 brakes - probably 20 pounds heavier, not more than 30
c7 suspension - that's a wash, within 10 pounds
c7 air conditioning - at least 10 pounds lighter
c7 stereo - willing to bet its lighter
so from a 3030 pound c4 as an example, every component that a car person cares about in the c7, from suspension, tires and wheels, engine to differential, seats, air conditioning, frame and body, combined weighs somewhere between 190 and 300 pounds LESS. So why is the c7 looking like 300 pounds MORE car? it is apparently all sound deadening, wiring, and modules, and just sheer size (4" wider, 2" longer, taller). the airbags combined on a c6 don't weigh 25 pounds, I'm sure the c7 is the same.
the c7 is heavy because they keep making the cars larger, which i disagree with, and because it carries over 900 pounds of purely comfort weight, which I view as excessive for a sports car.
C7 is aprox the same size as C6
Frame is 95 pounds lighter
Tire/wheel is smaller/lighter
Seats has magnesium frame vs steel, should be lighter (C6 is heavy)
CF hood = lighter
CF roof = lighter
smaller rear hatch window, alot lighter
A-arm are hollow and lighter
Cradles are hollow and lighter/stronger
So, it adds up to at least 150 pounds LESS than the C6
Why on earth is it 150 heavier, something does not add up here
There is no way you can add insulation and wiring/computers worth 300 pounds
well we found out soon enough
Rune
Auto companies keep on inventing lighter materials, but then Big Gov cancels their savings out with higher mpg standards & tougher safety tests.
By the way, can you imagine what a 1958 Vette would weigh now - if it had been built with an aluminum engine, aluminum frame, plus the countless other lighter parts from today? Probably around 2500lbs.
.Jinx
You just don't get it. The 1984 Corvette was the best engineered Vette ever and they have been going downhill ever since then. In fact, the C6 ZR1 takes over an hour to get around the Ring whereas Ramey can do it in under a minute(and that includes stopping for a potty break) in his 87. The only reason Ramey is driving a bloated 87 is that 84's are drawing over a hundred grand at Barrett-Jackson. That's the reason I'm driving a horrible handling C6 Z06..I can't afford a C4.
I cannot accept being happy about all the extra weight on other "stuff", even if some of it really does add to the driving/ownership experience. What would be informative would be for the GM engineers or the automotive press to actually break all this out for us -- what's down (which we got in great detail) and what's up (which is conspicuous by its absense in the intro). Then this thread would sound more like a valid debate and less like a schooyard argument.
Rocket science this isn't. One more time: performance improvement, which is desirable, plus safety improvement, which is federally mandated so whether you think it's desirable is moot. Size is part of those performance and safety improvements. That's where the mass is. C4 could not legally be sold today. Stop using C4 as a baseline and only subtracting weight for aluminum engine block & lighter starter etc and acting like that's a realistic expectation for C7. It's not and either you damn well know it or you're clueless. You don't like how fat sports cars have gotten? Write your Congressman and tell them to rein in NHTSA. Ask them to slap the EPA around while you're at it.
.Jinx
.Jinx
modern 5 mph bumpers are LIGHTER than the chrome ones on the c1-3, and probably the same as the c4 (i don't even think that standard has changed).
there appears to be very little required or functional weight in the bs you are talking about.
the simple reality appears to be that an early car has less than 400 pound of wiring and comfort weight, while the c7 appears to have more than 900.
the question of most people around here is, why is that appropriate for a sports car? that is why there are at least 5 threads with people bitching about the weight.
hell, even the wiring is a questionmark. the c6 started to have mutliple circuits using the same wires! this is absolutely godawful for a long term reliable, modifiable, or repairable car, but is supposed to save weight.... i assume the c7 is even worse than the c6 in this regard.
this car should not weigh 3000, much less 3300.
.Jinx
100% right on. C7 was designed by the government. EPA and the NHTSA regs dictated that the engine be designed with DI and AFM, resulting in a heavier engine and torque tube. The 7th gear added to the transmission was because of the EPA, and also added additional weight.
we are looking for the other 865 lbs.
