E92 Crack
Old Mar 15, 2013 | 12:19 AM
427 C5's Avatar
427 C5
Originally Posted by Halltech
The Z06 will be FI for sure. I can tell you the hp will be stunning. Forget about the ZR1 for now. The Z06 will be King for a while. All good stuff.
FI on a ZO6 sounds exciting.
Any word on AWD or DCT being available as OPTIONS for any year or version of the C7 ?????
Thanks.
Old Mar 15, 2013 | 02:14 AM
SCM_Crash's Avatar
SCM_Crash
We will have the ultimate wheels for the C7 as well. One Piece 100% carbon fiber wheels by Carbon Revolution. They shed 65lbs on the ZR1.
Currently, only 8.5"X19 and 12"X19" will be available. Orders being taken for May delivery.
On our 2817lb Z06, we will drop 52lbs with the first set ever made for the Corvette.
We'll obviously see how these fit our C7.
HELLO!!!!
You have my attention. Not a fan of the design, but a big fan of the weight. How strong are these and do you have an idea on cost?
Old Mar 15, 2013 | 02:18 AM
petermj's Avatar
petermj
I can tell you, it is a pretty sure thing that we will have one of the first programmers for the new E92 computer. Our contacts already have the code worked out for the DI Cadillac.
It will have new security parameters, but they should be easy to hack.
Our C7 will be first in line.
Also. Cool news from Pratt and Miller last week. They are making the new molds for the C7.R. I wonder how cool that will look. Maybe we can take some of the cues for the rear end from that car once it arrives. I have not seen any of their drawings but there is one out there that looks pretty cool.
Still looking for 490 to 500 HP when the SAE dyno is revealed. GM will flop if it is 450 HP. The reason is that they average 10 HP/Cylinder going from Port Injection to Direct Injection on the same displacement motor. 450 would be 1.5hp/cylinder. Let's keep our fingers crossed.
All good stuff.
You and Hennessey And your claim regarding DI, how exactly you know what the power is before adding up the gains from DI? Just curious about it...
Old Mar 15, 2013 | 03:42 AM
1analguy's Avatar
1analguy
Originally Posted by texvette2
...Your also going to be able to make
your C6 look close to C7. Just wait will have new light pods, and a rear with C7 styled lights
Maybe in "Bizarro World"...
Old Mar 15, 2013 | 06:11 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Originally Posted by michaelinmech
And that's how we respectfully think of you = BlueOx, Full of Guesses
Originally Posted by BlueOx
In the family, I'm referred to as TheGasBaster.
Fixed it .....................
Old Mar 15, 2013 | 08:20 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Just assuming that if the LS3 with NPP is at 436 HP, and DI averages 10/cyl. on the same displacement motors, according to GM, just do the math.
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
423-915-6056
For service email:
orders@halltechsystems.com
www.halltechsystems.com
Old Mar 15, 2013 | 09:22 AM
Kappa's Avatar
Kappa
The LT1 is going to be a baaaaaaaad boy.
Compared to the LS3 you've got a better flowing IM, smarter computer with higher capabilities(it's got a humidity sensor, any thoughts Jim?), 11.5:1 compression, higher flowing heads, LS7 style headers. People forget that the Z51 exhaust is larger than the LS3 exhaust as well.
Even it doesn't hit the 505hp of the LS7, its going to be closer to that number than the hp of the LS3.
Old Mar 15, 2013 | 09:23 AM
Kappa's Avatar
Kappa
Here's a good closeup of the engine. Its going to be a beast once the tuners get ahold of it.
http://www.planetlsx.com/forums/show...ed=1#post89233
Old Mar 15, 2013 | 09:39 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
I am leaning more and more toward 510 HP. I believe the LT1 will match the LS7 motor easily, or at least has that potential.
Let's look at the dry sump version of the LS3 found on the GS. Tested at 414 RWHP by GMHTP Magazine dynoed 3 times in a row within 1 RWHP. Most LS7s average 448 RWHP to 450 RWHP. I have owned two, and both dynoed 448 at the wheels. I have seen maybe 30 different dynos hit numbers close to 448 on the DynoJet. 34 RWHP now separates the LS7 from the LS3 in the Grand Sport according to GM High Tech and Performance Mag.
Forget about correction factors for the moment. 448 RWHP would represent 57 HP lost to DLL average on the LS7. The LS3 Grand Sport making 414 RWHP should be around 471 HP if the motor was recertified by SAE using the same loss factor to DLL.
Now GM's claim of 10HP/cyl for equal displacement. You see the potential for huge numbers. Even 7HP/cyl is 56 more hp than the LS3.
I can see some LT1s making close or above LS7 numbers. As I said, I have no hard information on the LT1. I'm waiting for numbers like everyone else. If they come in at 450 HP, that would be a huge disappointment in my opinion, and would not advance the direct injection platform at all. Even the compression ratio would bump 12 HP to the LS3, leaving zero hp gain for DI vs. Port Injection?
Jim Hall
Old Mar 15, 2013 | 10:15 AM
Mike Mercury's Avatar
Mike Mercury
Old Mar 15, 2013 | 10:16 AM
petermj's Avatar
petermj
I do not want to be argumentative but would really prefer for someone to actually dyno the engine and then the car to make sure this is really the case. The engine has a pretty high compression according to GM, it should be more hp than GM claims. Maybe there is something else going on here?
Old Mar 15, 2013 | 11:57 AM
HurricaneRN's Avatar
HurricaneRN
Originally Posted by SCM_Crash
HELLO!!!!
$15,000 set
Old Mar 15, 2013 | 12:05 PM
  #33
michaelinmech's Avatar
michaelinmech
Any sentence that begins with the words "I don't want to be argumentative but" - really means "I want to argue"
Old Mar 15, 2013 | 12:08 PM
  #34
petermj's Avatar
petermj
Old Mar 15, 2013 | 12:20 PM
  #35
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
All good stuff.
I thought the C7 was using the GPEC II computer???
Old Mar 15, 2013 | 12:49 PM
  #36
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Originally Posted by HurricaneRN
$15,000 set
Correct: $14,990 set
http://www.halltechsystems.com/product-p/ulz-crcf.htm
www.halltech-carbon.com/CR9.pdf
Warranty = Lifetime structural and materials and 2 year finish.
DOT – does not have an approval it is a very old specification that has no teeth. In the U.S. the SAE 2530 test is the wheel standard that all the OEM’s adhere to and we have passed these test as well we added 30% to these loads and passed again.
In Europe they have the TUV which are more difficult test to pass than the U.S. the TUV test for aftermarket we passed and added 30% again and passed.
The last most difficult testing protocol is the European OEM wheel test called the AKR and we passed this test added 30% and passed again I will attached to this email our test results with the PASS stamp.
8 to 10 week delivery. 19" only. 100% Carbon Fiber Wheels. Carbon Fiber Material Explained.
Carbon Fiber Reinforced Plastic (CFRP) is a super strong and lightweight material that is gaining increasing favour with engineers. In tension, for a given weight of material it’s at least 3 times stronger and stiffer than steel, aluminum or titanium. Carbon fibers are basically very thin strands of carbon, much thinner even than a human hair. All the individual fibers are bunched together in what is called carbon fiber tow.
Each tow can have between 2,000 and 50,000 individual fibers in the bunch. This tow material is then woven or stitched together to create different carbon fiber cloth materials. The tow can also be used directly to manufacture certain parts. The step between these dry tow and fabric materials and a finished solid material is the introduction and curing of a resin to turn the carbon fiber into a CFRP.
You will not have to visualize these on a Corvette. Our ULZ700 will sport these wheels in May and be at the Katech Autobahn for viewing and testing by Johnnie O'Connell. Our Z06 is 2817lbs (no fuel) now, and will be 2765lbs with these wheels and Pilot SCs. 660 HP.
Carbon Revolution’s wheels are also tested for lateral impact performance. In this test, a calibrated striker hits the wheel on the spoke face, mimicking how a sliding vehicle would impact a curb. All Carbon Revolution parts exceed the loading requirements of this widely accepted test.
How many aluminum wheels could survive this at 60mph?
Old Mar 15, 2013 | 12:59 PM
  #37
Mike Mercury
I talked with our car expert here at work. He said the 10hp/cyl is a good rule-of-thumb... if the goal is solely performance based.
But with consumer cars (and AlGore CAFE nonsense)... part of the advantage with DI can be used to improve fuel economy. And with that as a part of the equation - you won't see a full 10hp/cyl increase.
To E92 Crack
Old Mar 15, 2013 | 01:22 PM
  #38
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
A few years ago, this was the only way you could purchase these wheels. Buy a $650,000 Ultimate Aero:
http://www.thecarbonfiberjournal.com/?p=1140
Halltech has been involved in the development of these wheels for the Corvette. 3 years ago they had no interest. Today it is a reality.
Old Mar 15, 2013 | 01:28 PM
  #39
petermj's Avatar
petermj
Now, what are the chances for two super car builders to have the same last name and then name their companies after themselves?
At less than 2800 lbs and packing all this hp, you have something that C7 should have been. This is outright impressive
Old Mar 15, 2013 | 01:30 PM
  #40
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
My take as well.
