Help Me Understand The Rear 1/4 panel Air Intakes
Here is an article that backs this up:
"With the coupe and convertible engineered simultaneously—per chief engineer Tadge Juechter, the C7 was designed from the beginning as an open-top car—differences between the two body styles are minimal. The only change other than the soft-top is the elimination of the C6.R-style rear quarter-panel vents for the transmission (automatic and Z51) and differential coolers (Z51), which have been replaced by underbody air intakes."
Read more: http://www.motortrend.com/roadtests/...#ixzz2OQ5MAwWj
R/Noland
From what I've read, this is not an accurate statement. The convertible has the vents, but due to the space needed for the top to retract, the vents are located underneath the body just forward of the rear tires yet still exhaust by the rear tail lights.
R/Noland
R/Noland
I was referring to the vents that are located on top of the rear fenders on the coupe and are obviously absent on the convertible. Thus my statement is accurate. If they re not needed on the convertible then they are not needed on the coupe. The coupe could have been designed, for the better, utilizing the same underbody air intakes that are found on the convertible.
Just what advantages do the top mounted vents give the coupe that is not necessary for the convertible to have?
Is the C7 coupe so aerodynamically deficient that it needs those vents, but the convertible doesn't, nor does the C6 Z06 and ZR1, that have higher top speeds then the C7?
Other then "boy racer" looks, that is.
Show me where the top mounted fender vents are necessary. Are they to keep the coupe from going airborne at 100 MPH? 150 MPH? 200 MPH? Show me where they reduce lift on the coupe and show me the reason they are needed on the coupe but not required on the convertible.
Maybe they said they were functional to try and "cool down" the heat they took over the rear tail lights.
The trans and diff are in the back, having the coolers back there helps shift the weight to the back, shorter lines means less weight, also one of the engineers said the air exiting out the back near the tail lights, has the effect of lengthening the car aerodynamically, lowering drag, and finally getting the rads out of the engine bay/radiator area mean less to heat soak the engine, a problem on some tracked C6's
