Some additional info...
Old Apr 28, 2013 | 05:30 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Default Some additional info...
I had a beer with one of the C7 engineers last night and we had a long discussion. I haven't seen this info anywhere before so I thought I would put it out there.
The C7 wheel offsets are essentially the same as the C6. So, if you have a nice wheel set on your current C6 it is easily transferred to your C7. Also, if you have a C5 and you like to run C6 wheels, you can continue to use a 1/4" spacer in the rear if you choose to run the new C7 wheel on your C5.
If you currently are running coilovers on your C5 or C6 and you were thinking of moving them over to your C7 it can't be done as is. There has been a change in the mounting position hardware which prevents current coilovers from mating up to the joints. However, if an aftermarket company creates a new bracket it will be adaptable.
That's it for now...will add more as I learn more.
Old Apr 28, 2013 | 06:13 PM
gthal's Avatar
gthal
Thanks for the info!! Many are wondering about offsets.
Kappa's Avatar
Kappa
I have a feeling that a lot of C7's are going to be running around with 315 rear setups in a short amount of time.
Old Apr 28, 2013 | 07:14 PM
sam90lx's Avatar
sam90lx
I dont know if 315s will fit? Thats a huge tire.
Old May 3, 2013 | 10:55 PM
jdmvette's Avatar
jdmvette
Night Owl for life
i was wondering about that.
thanks for the info.
Old May 3, 2013 | 11:04 PM
ZL-1's Avatar
ZL-1
Thanks I was one of the guys wondering about that
Old May 3, 2013 | 11:43 PM
sam90lx's Avatar
sam90lx
Where does the OP say 315s will fit. I think some of you all are reading too much into this. He said C6....not GS/Z06.
Old May 4, 2013 | 12:19 AM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
Thanks for the info
To Some additional info...
