C7 Keyless Entry
Old May 16, 2013 | 08:57 PM
Bat7Man's Avatar
Bat7Man
Default C7 Keyless Entry
One of the things I love about the C6 is the way the keyless entry works. With MOST cars you have to hit a button on the door handle of fob to lock the car when you walk away, and the same when you walk up to the car to unlock it. When I was in a c6, I loved how you walked up and the doors just opened when you used the button. Even more so, the fact that when you walk away with the fob the doors automatically lock without the need to do anything. Does anyone know if this is true and will carry over to the c7?
Old May 16, 2013 | 09:00 PM
Zymurgy's Avatar
Zymurgy
Moderator
I'm sure it will. This is found in other GM vehicles.
Old May 16, 2013 | 09:07 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The system is very similar to the C6. You can set auto lock, much the same as the current car.
Old May 17, 2013 | 07:43 AM
Bill17601's Avatar
Bill17601
AIR FORCE VETERAN
My C5 did that.
Old May 17, 2013 | 09:03 AM
z28lt1's Avatar
z28lt1
Originally Posted by Bill17601
My C5 did that.
Not from the factory (unless my memory is going bad in a hurry).
***EDIT: This is incorrect see, thanks for the corrections***
Old May 17, 2013 | 09:46 AM
sccaracer46's Avatar
sccaracer46
My C5 did!
Old May 17, 2013 | 09:58 AM
vetteLT193's Avatar
vetteLT193
This started in 1993. passive keyless entry is what they called it. It got annoying for some (probably didn't read the manual because all you had to do to toggle passive/off was by holding the door lock button until the locks cycled) so when the C5 came out the key fob had a switch on it. In 2000 it was removed as a feature only to find its way back with the C6.
Old May 17, 2013 | 10:09 AM
z28lt1's Avatar
z28lt1
Thanks for the correction!!! My C5 was 2001 and as such didn't have it, so my memory isn't going bad after all, just my facts are bad...
Old May 17, 2013 | 10:29 AM
michaelinmech's Avatar
michaelinmech
I believe it is the combination of a failing memory together with bad facts that best qualifies us for CF Membership
Old May 17, 2013 | 11:12 AM
Greg00Coupe's Avatar
Greg00Coupe
Yes and no. I have it on my 05 Cadi. I'm sure its the same as with the Corvette. These obviously is an antenna and the fob is constantly transmitting. I've be trying to fix a problem with the Cadi (system broke) and it is not cheap to repair. Coupled with then need to replace fob batteries more often because its always transmitting........... I'll take a traditional fob system over the no need to push buttons system. It's like voice recognition, an overkill.
Old May 17, 2013 | 11:36 AM
HurricaneRN's Avatar
HurricaneRN
Should be like any passive RFID, the radio signal comes from the car and powers the passive circuit then the coded response is sent with the signal boosted by the fob battery. The car is transmitting continuously but the fob should not.
Old May 17, 2013 | 11:42 AM
jkcam6017's Avatar
jkcam6017
Personally, I think the push button door opener is one of the worst features of my C6. What an annoying attempt at high tech. Give me handles that mechanically lift up to open the door.
Flame suit on.
Old May 17, 2013 | 11:57 AM
bigswiss89's Avatar
bigswiss89
i didn't know that. i learned something new about my c6 today
Old May 17, 2013 | 12:54 PM
CCDawg69's Avatar
CCDawg69
Flame suit on.
Give me the button any day!!
Old May 17, 2013 | 12:58 PM
Bill17601's Avatar
Bill17601
AIR FORCE VETERAN
I like the C5 door handle. No hole in the door and works when the battery is dead.
But I have leaned to accept change..so give me a new C7 I do not care how the door opens..
Old May 17, 2013 | 02:31 PM
BuckyThreadkiller's Avatar
BuckyThreadkiller
Successful Plumber
From: Top of the hill, 3rd mailbox on the right. Texas
CF NCM Ambassador
CI 6-7-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10
NCM Member '09
IIRC I had it on my C4, which was a PITA while washing the car, until I figured it out.
Old May 17, 2013 | 09:08 PM
Bat7Man's Avatar
Bat7Man
Glad to help!
To C7 Keyless Entry
Old May 17, 2013 | 10:44 PM
Never-Enough's Avatar
Never-Enough
Flame suit on.
Half the time the damn sensors in the door handles didn't work for me.
Old May 17, 2013 | 10:52 PM
rcallen484's Avatar
rcallen484
Never had a problem in my 2007 nor my 2011.
Old May 17, 2013 | 11:54 PM
Snorman's Avatar
Snorman
Scraping the splitter.
St. Jude Donor '13-'14-'15
What if it came with The Clapper?
S.
