Getting the garage ready
Pics below are:
My '34 ProStreet Rod (8.2 liter BB Chevy) that sits in the middle of a 3 car garage. The Vette will go in the bay next to the wall (when NOT using the welder!) Built my own wall bumper which worked fine for the C6. Takes some flexibility getting out but that keeps me in shape! The other bay is for my wife's SUV.
One aid is a convex mirror with spot light and laser parking aid (you can see the red Laser dot, on the door.
The other is a limit switch alarm that should be useful when backing out at night, the limit switch arm is set 2 inches from the door edge. Note the red indicator light that flashes when activated! Less than $20 worth of parts on eBay.
They were fun to build. Want details, email: [email]Jerry_Uttrachi@NetWelding.com
Porcelain tile is also a little thicker than ceramic tile.
Easy install (for a real tile installer) over your standard cement garage floor.
You lay it with the same mortar as you would any tile flooring. Grout is standard too.
Porcelain tile is normally "Rectified" (perfectly square edges), so you can use very narrow spacing between the tile (narrow grout lines).
Used commercial vinyl tile on my garage floor (1/8 inch thick.) Easy to install and the pic in the above comment showing my Street Rod was taken 10 years after the floor installation. It does discolor where the tires rest and has some other minor stains. Just checked and it currently cost about 1$/sqaure foot at Lowes. A relatively easy DIY project and more durable than paint.
S.
Can't wait to start modding this new Vette!
my house is over a hundred years old, and I am not sure how old my detached garage is.. but it's up there..
getting it ready for the 7th Gen car? this will involve making sure the ZR-1 is over far enough so I can park the Stingray next to it.
Oh, and telling wifey she must now park on the parking pad, outside next to the garage.
I have a ton of spare 16"x1/4" Ceramic tiles since I decided to do hardwood in a few rooms instead and want to put it in the garage but am uncertain.
The house I had in the Philippines had ceramic tile on the entire driveway and carport (they don't have garages in the Philippines).
Although ceramic tile is not as hard as porcelain tile, and not normally as thick, I still never had one crack in the 3 years I owned the house.
These were set right over a cement slab using normal mortar as you would when setting tiles in the house over a cement slab (same as they set the porcelain tiles in my garage here in Florida).
You just need to make sure you don't have any voids in the mortar (large air pockets), because if you do, the tile could crack when driven over the void.
Here are a couple of photos of the ceramic tiles I had in the Philippines: The photos only show a motorcycle parked on the tile, but we had a Camry too, and many heavy trucks had been driven on the tiles without problems.
But .... I still think porcelain tile is a better choice for a garage floor.
Here are a couple of photos of the ceramic tiles I had in the Philippines: I photos only show a motorcycle parked on the tile, but we had a Camry too, and many heavy trucks had been driven on the tiles.
Hook a brotha up! LOL
