Does anyone know if the new C7 bolt pattern is the same as the C6? Just ordered some new wheels for my C6 and wondering if they might work on a C7 if I ever trade up.
All reports have been that the bolt pattern is the same and some even say the offset is the same as a base C6. I'm waiting to see final specs on the offset in writing.
If by "your C6" you're referring to a ZR, there may not be enough room for those on the C7.
Yep, I bet you are right about that. Particularly in regard to the fronts which appear narrower on the C7. More than likely GM will follow recent tradition and there will be a higher performance C7 in a few years with a wider body profile to accommodate the wider wheels.
