Phunky physics
Old Jun 22, 2013 | 11:28 AM
  #41
Minkster's Avatar
Minkster
Originally Posted by SCM_Crash
More like 2 seconds (not 2.8) until we know what the 10ths are for the C6 Z06 run on those tires.
Common denominators here... Lets not forget our basic math skills. 2.8 is closer to 3 seconds than 2.2 or 2.4.
More like significant digits. Tenths of seconds are significant data points in lap times, and to round up to the nearest second is not appropriate for data interpretation/dissection in this case. Just look how lap times are taken these days, down to the thousandths of a second in most cases. Take the Nürburgring for instance, a 13 mile circuit where lap times are posted in MM:SS:XX, which means they’re recorded in thousandths of a second and rounded up. For more common 1.5-3 mile circuits, the appropriate method for general discussion would be to round to the tenth of a second, but in more specific cases (high speed lap times) a hundredth of a second would be significant, just as most lap times are reported. It’s apparent you want to make the C7 look as good as possible, but to have a creditable argument you have to use the appropriate math skills even if they don't support your opinion.
Old Jun 22, 2013 | 12:18 PM
  #42
SCM_Crash's Avatar
SCM_Crash
Believe me, I agree with the tenths being important, but YOU do not have the tenths for the time the Z06 ran. For all we know, the C6Z may have ran a 2:50.8 as well. That's my point that you seem to be misunderstanding.
Old Jun 22, 2013 | 12:34 PM
  #43
Minkster's Avatar
Minkster
I fully understand the point you're trying to make . Regardless, if NO ONE has the tenths for the Z06, why are you rounding the numbers in a way that favors the C7 (Oh never mind, I know that)? After all following your math “logic” applied to both vehicles, the C7 ran a 2:52.
Old Jun 22, 2013 | 12:37 PM
  #44
SCM_Crash's Avatar
SCM_Crash
I was showing you the OTHER extreme of your view. It's simple. You stated it was 2.8 because there was no tenths. I stated it was 2 because there is only a tenths place for the C7. ANY time there's a tenths place for one and not the other, AND the tenths place is greater than 0, the advantage immediately goes to the other number.
So that being said, either keep your lowest denominations common, or don't compare the numbers in a fashion that requires both numbers to have the lowest common denominator.
Simple.
Old Jun 22, 2013 | 06:11 PM
  #45
Minkster's Avatar
Minkster
Simple.
Yes it is simple; use the same standards and practices when comparing data vice presenting it to favor your position/opinion. If you round one set of numbers to a particular precision, you apply that rule to all sets. Normally, it would be to the least number of significant digits available in the data sets, i.e, if you round one lap time to whole seconds, you do the same for all lap times (or delta lap times) for a fair comparison. And I never said 2.8 seconds or anything of the kind for either vehicle, that was in your comments. I was only pointing out that one should use common data formatting (number of significant digits) appropriate for the comparison of different data sets.
And common denominators have to do with division and fractions, not the amount of significant digits that apply .
Enough of this..
Old Jun 22, 2013 | 06:48 PM
  #46
NoOne's Avatar
NoOne
For the GTR comparison.
Put any novice driver in both cars and the GT-R will kill just about anything out on a road course.
You all talk about pro drivers, well there are probably 4-5 pro drivers on this entire site.
The GTR is stupid easy to drive on a road course. I've driven on, point and shoot and you can be a REALLY bad driver as my student was and still pull off amazing times.
Here is the truth, not many on here would drive there cars at 9/10's to even come close to those numbers. Talking numbers is nice, throwing 60-70K around a track with no insurance is another matter.
I prefer to look at how fun a car is to drive. Most would say on a road course that a C6 Z06 is very fast but the early ones were a lot of work to drive. My RX7 was awesome but would scare the crap out of you to get a fast lap.
The GTR was too easy. Look at what they are saying about the new Viper, very fast but bring extra underwear.
I hope they build something enjoyable to drive where I can go have fun and not worry about wadding up a brand new car in search of a mythical .4 seconds I'll never hit.
Old Jun 22, 2013 | 11:03 PM
  #47
SCM_Crash's Avatar
SCM_Crash
Enough of this..
You responded to a post I made, quoting the following post. That's where the 2.8 came from.
Originally Posted by Trackaholic
If you look at the Bash video where Mero talks about the C7 time, you will see a list of times from the various C6 cars with various tires.
The Z06 was listed as 2:50 with GY Gen2 tires.
We also know that GM said the Z06 was 1 second faster on the C7 PSS tires than it was on its own tires. So that would make the Z06 time 2:49 with the same tires as the C7.
Therefore the C6 Z06 is about 2.8 seconds per lap faster than the C7 Z51 with equivalent tire compounds.
The GS on C7 tires would only about about 1.7 seconds slower than the C7, so the C7 is closer in lap time to the GS than it was to the Z06. Of course the video of the C7 looked very clean and smooth, which I think speaks more about the improvement in the car than the pure lap times.
-T
Old Jun 23, 2013 | 03:19 PM
  #48
60av8tor's Avatar
60av8tor
WOW !
Should have known better to light a fuse like this and then not check on it for a couple of days !
Can't post all my favorite responses, but this one is typical of them....THANKS ! The purpose of my question was not to throw dirt, it was to learn.
Sounds as if all any C6 pilot needs to do is get sticky tires and a bit (not even a lot) more power and you are easily in the game....for a fraction of the price a C7 would cost.
If you reply as if I am dumb, I'm cool with that- so long as you are educating, feel free
Originally Posted by herman2p
This may be a bit oversimplified, but hopefully it makes the right point.
From a stop these are the basic equation for acceleration
a(t)=Force(t)/mass = equation of motion for acceleration
Force(t) is the torque that the motor generates translated through the drivetrain and tires. Note: Mass is in the denominator, so higher mass lowers acceleration (BAD). You want the highest a(t) for the whole time you are accelerating, not just the millisecond the engine is peaking.
The key takeaway is that peak torque and horsepower numbers are not the complete story. It is the integrated torque/hp (summation of torque/hp over time) that the engine puts out that will determine how fast the car is.
In other words, you don't have the engine at peak torque/hp the whole time while you are accelerating from zero to 60. You have to look at what torque/hp the engine is putting out the whole time you are accelerating. So, it is possible that an engine with higher peak hp/torque numbers will be slower than an engine with a broader power curve but lower peak hp/torque numbers.
Does that make sense?? Even though it is possible, I am not sure I believe that the C7 is faster than a C6 Z06.
Old Jun 23, 2013 | 04:40 PM
  #49
ChucksZ06's Avatar
ChucksZ06
I thought it was just me but CRASH argues the stupid side of a discussion with everyone. Hey CRASH, being contrarian when you are wrong is not cool. Let see, the engines, auto trans, and ecm's have very much in common with the trucks.
Old Jun 23, 2013 | 06:53 PM
  #50
JustinStrife's Avatar
JustinStrife
Originally Posted by 60av8tor
WOW !
Or you could just buy a C5 Z06, do the same, and compete with C6 Z06's. See how that argument works?
Old Jun 23, 2013 | 07:05 PM
  #51
BlueOx's Avatar
BlueOx
Originally Posted by JoesC5
GM has to provide numbers that show their latest is better than what it replaces.
For example, GM said the C5 coupe has a .29 Cd.
They had to better that with the C6, so GM says the C6 coupe has a Cd of .287.
But, Independent tests of both the C5 and the C6 in a wind tunnel in NC that is used by the NASCAR teams(and others) showed that the C6 actually has a higher Cd than the C5 and neither one of then were below .33 Cd.
Guess they never tested them at night...with the air dams up.
Old Jun 23, 2013 | 07:10 PM
  #52
Jasil's Avatar
Jasil
Originally Posted by DREAMERAK
Unless they are on a road course, then the GTR is slower.
Very true!! Remember in modded form look at the One Lap of America results GTR's have beaten everything for 3 years in a row with some of the fastest lap times ever recorded. No modded ZR1, modded Viper, modded Porsche touched the top modded GTR's and if that's not a testament to a 3800lb car I don't know what is.
Add to that more 8 second cars every month which is as rare as a pink whale in the modded ZR1 world.
Yeah, I nuthug a little I know an fwiw stock for stock ZR-1 all the way, but modded I'll take a GTR
Old Jun 23, 2013 | 07:15 PM
  #53
boost2na's Avatar
boost2na
OP, I'll try to answer your question. The C6 Z06 is severely limited at launch because of the torque and less than spectacular tires (until the Michelin PSCs came out). So GM conservatively lists 0 to 60 MPH time as 3.7 s. It's capable of better but very difficult. R&T got a 3.4 s 0 to 60 MPH time (link below).
I developed a model with decent accuracy but it only works when comparing two similar cars or comparing before and after performance of one car with mods. What I really like about it is that torque is accounted for (unlike pure weight to power). Torque is key; an E46 M3 is a perfect example, people can easily coax out 340 to 350 hp but the torque is abysmal, so it's not going to lay down times like a 3400 lb car with an LS1.
I take hp, torque, weight, and do the following:
C6 Z06 hp: 505
C6 Z06 torque (ft-lbs): 470
C6 Z06 weight (lbs): 3200 (as a rough average)
A = weight to blended hp and torque ratio (no units) = (3200)/((505 + 470)/2) = 6.56
Assuming the C7 Z51 will weigh about 3400 lbs, the same calculation gives us: B = (3400)/((460 + 465)/2) = 7.35
Here's where it gets cool. We calculate a multiplication factor C needed to get from A to B: C = B/A = 7.35/6.56 = 1.12
The meat of the model is that multiplying an actual acceleration time by C is what you achieve for the other car. So:
C7 Z51 0 to 60 MPH time = (C)(3.4 s) = 3.8 s
Not convinced? Let's throw one more at it, we can estimate the C6 GS time using the Z06 info; C6 GS: 436 hp, 428 ft-lbs, 3300 lbs:
(3300)/((436+428)/2) = 7.64
7.64/6.56 = 1.16
1.16*3.4 s = 3.94 s (GM lists 3.95 s for the GS)
It gets even better. Let's say the Z06 0 to 60 time (3.4 s) is completely worthless, way too infeasible. We can estimate C7 performance with the same model using the GS data, per above:
GS ratio = 7.64
C7 Z51 ratio = 7.35
7.35/7.64 = 0.96
0.96*3.95 s = 3.8 s [same result, different baseline car]
The funny part is that since hp and torque units are completely different, blending them is actually phunky physics!
http://www.roadandtrack.com/cm/roada...Turbo_data.pdf
Old Jun 23, 2013 | 07:42 PM
  #54
123sugey's Avatar
123sugey
Dig
I believe we should not compare the C7 Z51 vs a C6Z. Top of the line (excluding ZR1) vs a base car with a "package". If its within seconds on a track or within a half second on a drag strip... The C7 is a winner all around. Then, all waiting on on a C7 Z or equivalent surely will be happy
Old Jun 23, 2013 | 07:45 PM
  #55
SCM_Crash's Avatar
SCM_Crash
Stop smoking crack, buddy. I never said they weren't similar. In fact I said they were the same architecture over and over. You said they put LSx motors in trucks and I corrected you. Then instead of admitting you were wrong you continued to tell me how I know nothing about cars because somehow that's affected by you building a couple of motors in the past. (whoopy)
BTW, my favorite comment from you was when you said they put 243's in the trucks. *drep*
