Are modern torque converter based automatics able to deal with the heat generated by road race track driving? My experience with automatics from a few years ago is that they are easily overheated on the track when run for more than a few minutes at a time. I think that DCTs do better in this regard. Can anyone comment on track suitability of DCT vs. modern TC Autos?
Mark
Corvette autos are not designed for the track. Go over to the Road Racing section and do a search. There are some guys that do race them and they can get pretty hot on the track. A heat transer radiator can fix that. There are shops that can make them very competitive. They can program hard shifts and keep the torque converter locked except for shifts. Also they don't have a dry sump so they can run out of oil in some turns. Tadge said that they are working on an auto to do the job. I think there will be an auto option in the high HP C7.
Mark
I had an HPDE student a few years ago who was driving an '07 auto. It had an aftermarket tranny cooler, and was otherwise stock. Not the best transmission for the track, but it worked. She was a low/advanced level driver, and to give a data point she was running 2:15s on VIR's Full Course, so she wasn't babying it. The converter was unlocking on the track, and the tranny did get hot, but not too hot. The tranny survived for many more events. Like mentioned, a lot of the trick is heat management. Who knows how much life the tranny had left after those events, though.
I think a DCT designed for track use would be engineered around heat management as well, among other things. A Vette DCT would probably be a wet clutch; I would think the clutch fluid would need a cooler. Either tranny could probably be designed for the track if they desired it.
GM tested DCT in the C7 mules and blew it up in 3 minutes of testing.
I'm sure it can be designed to run a proper DCT but its sadly not in the cards for the near future.
Buy a stick shift with rev matching up and down as well as launch control...
The automatic torque convertor c7 has not even been tested and all I'm hearing from those who love DCT's are that the Tq convertor automatic is no good.
Common sense would dictate....waiting for the reviews of the journalists before condemning the the tq convertor automatic..
I hope the DCT does become available sooner rather than later as I'm a big fan...
The new 8 speed ZF gives me hope that GM's new 8 speed automatic will be just as good as a the ZF unit which has been reported to be as good as DCT..
If the Z06/Z07/ZR1/ZR2/L88 or whatever they decide to call it had only a supercharger & AWD (along with fancy carbon fiber body pieces) I am willing to bet it would destroy many supercars out there, even potentially the GT-R.
Pretty sure the C6Z and ZR1 can match and beat, respectively, the GT-R in anything except a short drag race.....
QUOTE]
Where did you get this info from?
He makes things up which is the same as lying.
Lingenfelter is developing a flat crank for LS engines coupled to sequential gearboxes. Maybe there is some GM money behind this project. This will reduce the weight of the crank about 30%. The present 2 plane crank plus the drive shaft will pound a DCT to death. There is no way that you can make it light and cheap. Rev up your Vette and see how long it takes to rev up and slow down. Not exactly like a F458. No auto blip or any other engine management system can change that.
Thanks for that complement. I'm sorry I can't give details etc...but rest assured gm did test a DCT transmission and it did go kaboom within minutes..
As I mentioned....I'm a big fan of DCT and would like one in my next sports car...
Not more than I would enjoy all the attributes of the corvette compared to other brands...but I'll give it a little time to see if we get lucky and have gm oblige...
Interesting edmunds review of the DCT GTR premium versus the half priced stingray manual..z51 manual MRC would tap 57 grand...if GTR had a few options on the 98 grand..it'd be close to double..
Interesting how sometimes the GTR DCT would power down the car or how after five runs it was no launch control to save the transmission...
Cool tech..
Interesting acceleration for the GTR in traction control on...DCT hits hard n launch but with traction control on.....it's pretty even with a well driven manual or automatic...
I think the point of this thread was to showcase how advanced torque-coverter based autos are getting. These new gearboxes shift in < 0.1 seconds in the performance modes. Then go back to smooth shifting in touring modes.
I'll bet C7 completely skips the DCT and goes straight to a high-tech 8-speed auto.
I guess I'm having a hard time believing that todays engineers would design anything that would be destroyed in minutes. Everything is designed using computer simulations for stress, etc. The tranny would be tested on a "work bench" set up first. Then would go through a phased testing period. By the time the drivers would get at it, it would have gone through a lot of testing.
GM builds only one tranny
They put it into a C7
A driver stomps on it and lays 100 ft of rubber
Tranny goes Kaboom
Driver and test engineer look at smoking tranny
Test engineer says "Oh well, that's that"
Test engineer phones GM head hauncho and tells him DCT doesn't work and GM will need to cancel entire DCT program.
Head hauncho says"But we already have paddles in the C7"
Test engineer"well, ,,,hook up the power antenna switch to it"
Head hauncho"We don't have a power antenna:
Teat engineer" Ahhh, well, hook it up to the rev match Switch. No one will ever figure out it was intended for the DCT"
Head hauncho"Great idea"
And that folks is how the rev match switch got to go where it is.
Tranny goes Kaboom
And
OK - Now THAT ^ makes some sense . . . . . though Power Antenna Paddles would have been nice too
