Oil
Old Aug 8, 2013 | 04:02 PM
snakepit's Avatar
snakepit
Default Oil
What weight oil and how many quarts with the Z51 option.
Old Aug 8, 2013 | 04:52 PM
Zymurgy's Avatar
Zymurgy
Moderator
I haven't seen anything official on this yet, but based on the dry sump 2013's, somewhere around 10.5 quarts. 5W30 has been the recommend weight for years. Must meet dexos1 specification.
Old Aug 8, 2013 | 05:33 PM
Trackaholic's Avatar
Trackaholic
Just saw a photo of the engine bay in another thread. Says 5-30 on the cap.
-T
Old Aug 8, 2013 | 06:28 PM
speedlink's Avatar
speedlink
Sounds exactly right. I'm thinking ti's the same for 2014.
Old Aug 8, 2013 | 07:16 PM
XC6VETTE's Avatar
XC6VETTE
What oil filter will the new motor use....?
Old Aug 9, 2013 | 03:16 AM
SCM_Crash's Avatar
SCM_Crash
Wow... 10.5 qts. LOL I wonder what the life on those will be.
Old Aug 9, 2013 | 10:45 AM
JoesC5's Avatar
JoesC5
GM has stated in their press release that the reservoir holds 10.5 quarts.
Old Aug 9, 2013 | 11:37 AM
yellowray's Avatar
yellowray
10.5 quarts! dang that's a lot of oil. Didn't realize dry sumps systems have that big of a reservoir.
Old Aug 9, 2013 | 11:42 AM
rfheis's Avatar
rfheis
Default Oil
How can I prove that the automatic also has a dry sump....it did not before
Old Aug 9, 2013 | 11:53 AM
stevelischynsky's Avatar
stevelischynsky
With all this oil, what is the recommended oil change interval for ordinary street driving......10yrs?!
Old Aug 9, 2013 | 01:13 PM
JoesC5's Avatar
JoesC5
Nope, one year, as always.
I change out my 10.5 quarts of oil annually(approximately 5,000 miles) in my C6 and it runs me around $60 using Mobil1 full synthetic and a Mobil1 premium oil filter. I could save quite a bit by using the much cheaper dexos synthetic blend oil that comes in the C7.
But with me being an old fart that does not crawl under his cars on his back, I do have two $2,500 4-post lifts so I can stand up when changing my oil. Going take me awhile to pay off those lifts with the money I save changing my own oil instead of a dealer. At least I know it's done correctly, even though I make less than minimum wage when working on my cars.
Old Aug 9, 2013 | 01:35 PM
stevelischynsky
So how does the warranty work when changing your own oil. How do you prove that the oil was changed per warranty schedule and what oil was used should you require engine warranty work.
Old Aug 9, 2013 | 02:09 PM
xp800's Avatar
xp800
My bet is on PF63.
I posted on the filter thread here:
http://forums.corvetteforum.com/c7-g...il-filter.html
The 2014 Silverado with the 6.2L LT1 variant lists PF63 as the filter...it also lists 0W-20 as the "recommended" oil. Hoping it's 5W-30 for the C7 like the observed oil caps say since I have a stockpile of Penzoil Ultra.
http://www.chevrolet.com/content/dam...nd%20print.pdf
Old Aug 9, 2013 | 02:40 PM
JoesC5's Avatar
JoesC5
Keep a simple log along with the receipts where you purchased your oil and filter.
Old Aug 9, 2013 | 02:45 PM
JoesC5's Avatar
JoesC5
Originally Posted by xp800
My bet is on PF63.
The PF48 and PF63 are interchangeable but the PF63 is longer. PF63 might be to long for the Corvette as it will extend down below the bottom of the oil pan, reducing ground clearance. Just a guess on my part, but the photo shows the difference.
check this C&D video at 2:35 and you will see the short filter. http://video.search.yahoo.com/video/...m0&age=0&&tt=b
Old Aug 9, 2013 | 03:18 PM
xp800's Avatar
xp800
Absolutely correct on the size. I wanted to move to the PF63 for my G8 GXP (LS3) after buying an '11 Acadia, but the ground clearance issue was quite obvious. I liked the larger filtering area and capacity. I thought I remember reading that it has better filter media as well. Certainly is more expensive (about double).
The PF63 has been deployed on all the new GM V6 engines with variable valve timing and DI; they're much harder on oil than the LSx family. Given that the '14 GMC with the variant LT1 of the C7 uses the PF63, I'm guessing that the VVT/DI may necessitate the extra filtration capacity. To enable PF63 in C7, the ground clearance issue of the LSx would have been addressed in the LT1 architecture, and I suspect it has.
Since I sold the GXP to make room for the C7, it certainly would make buying filters easier for me!
Old Aug 9, 2013 | 03:49 PM
JoesC5's Avatar
JoesC5
I suspect the reason for an enlarged filter is the change to dexos oil(extended oil changes), not DI, VVT & AFM. If you're going to run the oil to around 10,000 miles(vs 3-4,000 miles with conventional oil), then you need more filtering media to collect and hold the crap so the bypass valve won't be opening up at 6-,7000 miles and bypassing the oil filter, because the filter can't hold any more crap and is plugged up.
To Oil
Old Aug 9, 2013 | 11:42 PM
SCM_Crash's Avatar
SCM_Crash
The Amsoil I use is usually 8.75/qt (with the member discount).
That's $92 + $12 for the filter. LOL
Old Aug 9, 2013 | 11:53 PM
glass slipper's Avatar
glass slipper
The dexos1™ synthetic blend was also in the 2012/13 C6 base model. The dexos1™ is backwards compatible so you could run the cheaper synthetic blend that comes in the C6 except for the fact that you have the dry sump engine...that requires Mobil 1 synthetic or equivalent synthetic so you're still stuck with the expensive oil changes.
No receipts are necessary, just a simple log.
The C5 was running oil to 10,000+ miles by the DIC long before the dexos1™ spec came out. Obviously the enlarged filter doesn't have anything to do with the extended oil changes with the change to dexos1™ oil. I do know VVT and AFM requires very clean oil.
Old Aug 10, 2013 | 07:42 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Originally Posted by glass slipper
The dexos1™ synthetic blend was also in the 2012/13 C6.
Did dexos1 come in the C6, or was it just listed in the owner's manual as the spec? I thought Mobil 1 was still factory fill in the Vette. Did that change?
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
