NPP default mode
Old Aug 10, 2013 | 07:47 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Default NPP default mode
On the C6, with the engine is off, the default position for the NPP valves is wide open at start up until vacuum builds up. The C7 is of course a totally different exhaust system. As such, I'm wondering if the valves will be in the open or closed position with the console **** set to the quietest position at start up. Hopefully, either Talon90 or GM'er will read this post and be able to fill us in.
Old Aug 10, 2013 | 07:50 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
When in Eco or Tour, the exhaust is closed on start.
Old Aug 10, 2013 | 07:55 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Thank you. That has become an issue on our '12 and one of the reason's my s/o prefers her car on trips of any nature. Needless to say, I prefer the Corvette over her Sonata ..................
Old Aug 10, 2013 | 08:01 PM
RickDI's Avatar
RickDI
So can you adjust the drive mode before you start it? That brings up another question. Is there an ACC key position type thing on a keyless start vehicle?
Old Aug 10, 2013 | 08:03 PM
talon90's Avatar
talon90
NCM Ambassador
There is an accessory press and an "ignition on, engine off" mode which allows you to do anything you can do when the car is but the motor is off. Sme systems are powered down in accessory mode and this takes care of that.
Old Aug 10, 2013 | 08:08 PM
RickDI's Avatar
RickDI
Thanks for the info! Can't wait for the Owner's Manual to be available so I can learn all of these tricks!
Old Aug 10, 2013 | 08:34 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
C6 key less ing. switch works the same way. Tilt the switch inward at the top for engine start, inward at the bottom for acc. mode. One can go to full power on mode w/o starting the engine simply by not depressing the clutch on the M6. On the A6, not depressing the brake pedal serves the same function.
Old Aug 10, 2013 | 08:38 PM
RickDI's Avatar
RickDI
Pretty simple. Thanks!
Old Aug 10, 2013 | 08:40 PM
talon90's Avatar
talon90
NCM Ambassador
Clutch position is independent. You need to hold the rocker in the accessory position for 10 seconds. It will show accessory and if you keep holding it will then cycle everything on but the motor.
Old Aug 10, 2013 | 09:24 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
On the C6 ? Holy Cow Never knew that ........... Thank you Paul
To NPP default mode
