Navigation Updates
Old Aug 12, 2013 | 07:13 PM
ZZR1200's Avatar
ZZR1200
Originally Posted by JoesC5
LIFE means as long a there are maps available, unit has sufficient memory, etc, not 5 years max***. I also have a old Garmin (6-7 years old)and I can still get map updates for it, as they are still available). How long will CD's be available for the crappy NAV in my $80,000 C6 to update the maps?
Can I get a new NAV from GM that will install in the hole in my C6's dash that will allow it to be updated via the internet? How about if it takes a dump and need replacement after the warranty runs out? My Garmin takes a dump, I spend $100 for a new one with the latest features and FREE lifetime map updates.
So, even if the LIFE span on my Garmin is 5 years(which it isn't), that's only $20 a year($100 for a new one divided by 5 years) and I get five years of FREE map updates, 4 times annually.. Compare that to the $200 GM gets for a new CD for my factory NAV.
How much will GM charge to update the C7's factory NAV every 4 months? You can't even update the crappy C6's NAV every 4 months as they only issue a new CD every 12 months.
***"¹If you purchase a nüMaps Lifetime subscription (sold separately) or if your Garmin product comes bundled with a nüMaps Lifetime or other lifetime map subscription, you will receive map data updates when and as such updates are made available on Garmin.com during the useful life of 1 compatible Garmin product or as long as Garmin receives map data from a third party supplier, whichever is shorter. A product’s “useful life” means the period during which the product (a) has sufficient memory capacity and other required technical capabilities to utilize current map data and (b) is capable of operating as intended without major repairs. A product will be deemed to be out of service and its useful life to be ended if no updates have been downloaded for such product for a period of 24 months or more. Unless otherwise stated, the updates you receive under the subscription will be updates to the same geographic area included with your Garmin product when originally purchased. In some instances, your Garmin product might not have sufficient memory remaining for you to load an update to the map data, in which case you will need to either (a) select reduced map data coverage for your updates, or (b) purchase separately a microSD™/SD™ card (if and as applicable to your Garmin product) and load all or a portion of the map data coverage for your updates to the card and insert the card into the microSD/SD card slot contained in your Garmin product. If neither of the measures in (a) or (b) can be used to address your product’s lack of sufficient remaining memory, then Garmin may conclude that the “useful life” of your product has expired."
I agree with you Joe. GM will charge us $200 for the c-7 update and $45 for 1/2 hour labor. Lol
Old Aug 12, 2013 | 07:20 PM
Roger Sobin's Avatar
Roger Sobin
Unless you use this new car for business or some reason to be up on all the new streets, highways, and places --- and really need the latest ---
Consider going for every other or ever third update.
Things change, but not that much.
Just an observation . . .
