Remote start, is it possible?
The rings only create compression when moving through the compression stroke and the chamber will lose that pressure once the engine stops, but still there's some unplanned load on valve gear and the potential for any rocking and motion of the car (say while being trailered or just being parked in gear every day and allowed to move that half inch downhill till the parking brake and the drivetrain take up the load.)
These are tiny moments of load and wear without oil pressure, but still not in the design of the system. The engine has to take a much worse load for the first rotation of the crank during a cold start after oil has drained and lost pressure in the gallery, but that's designed into the operation of the engine, and unavoidable (unless you get an accusump or the like.)
I don't think any engine manufacturer wants the valve gear or the gearbox gears to be meshed and moving without the engine developing oil pressure.
Of course you see people using 1st gear or maybe reverse as a "safety" for parking (and you see some folks wrench on the parking brake as if trying to hold back time itself, even when parking on a level surface) and you don't necessarily see those engines go "bang" as a consequence, but you do see failures on the track and wonder why one engine fails and another lasts -- I think the cumulative effect of each form of abuse takes its toll and contributes to mechanical failures.
Is that what I read?
I've always been told to do it that way, Too much stress on the tranny.
Back in the day, Buddy had remote start on his 5 spd '85 Celica GT-S - Never had an issue.
Sorry but tranny's have been used this way since the beginning of time. If there was one single ounce of truth to it, the engineers that design them would have warnings and instructions in every owners manual about why not to do it. They certainly wouldn't have designed the C6 to REQUIRE the tranny left in reverse when you shut it off.
I don't mean to be harsh here but if it makes you feel better to make sure your tranny is left in neutral, you go right ahead. I've never blown a motor or a tranny on the street or the track and I have been using 1st gear as a parking brake for 50 years. There is just no evidence to support your theory.
GM recommends that you park the c7 in gear so maybe the gearbox was designed for it?
As far as all those different work around a to add remote start to a manual transmission car they all "could" fail. Here in the land of lawsuits that's the last thing any car manufacture Is going to want to deal with.
(1) You do know people have been leaving parked cars in gear for a hundred years without this happening? Or else you do have pictures of disassembled gearboxes showing this kind of damage?
(2) You do know GM expressly recommended that early C6s be parked in reverse to stop battery drain?
As for people parking Model T's, I just don't know. I'll let you get back to your desk work.
I would like to have remote start, just to be able to get the engine warm in the mornings (I have a quarter mile uphill straight out of my driveway, so I allocate time to let fluids warm a little on really cold starts) and to let the a/c cycle the heat out of the cabin when needed. I can only hope some enterprising individual brings an aftermarket gadget that fools the GM remote start system into thinking it's bolted onto a Stingray with an auto box sitting in Park.
2005 Corvettes equipped with manual transmissions
must be shifted into reverse before the vehicle will
properly shut down. If the transmission is left in any gear
except reverse, the engine will shut off but the vehicle’s
electronics will remain powered. If the driver’s door
is locked, it can not be opened without the transmission
being shifted into reverse, unless the door is unlocked
manually. If the door is manually unlocked and opened,
the horn will provide three short beeps to remind the
driver to place the shifter in reverse and shut off the
ignition. A message will also be displayed on the DIC
advising the driver to shift into reverse. If the driver
ignores this message and ignores the horn chirps and
walks away from the vehicle, the electronics will
continue to be powered until the battery is drained.
Battery run down protection will not be active because
the car is not fully shut off. Drivers must remember
to alert parking attendants and others that may park the
vehicle and may not be familiar with these requirements.
http://www.ferrari.com/English/GT_Sp...raftshaft.aspx
... it's ridiculous to think that the transmission is being damaged or put under undue stress when the car is parked and in gear.Now maybe if a semi truck came along and hit the car and made it move 50 ft with the transmission in gear ... might want to worry about that, if there's anything left of the car.
I take it this change in 2006.
I'm sure you have a theory that proves GM's TSBs wrong, though.
You do know the preferred term is "flat-plane crankshaft," right? Even if the people who make them can't quite spell "crankshaft?"
As for flatcrank, it's a pun.
Parking Your Vehicle (Manual Transmission Models Only)
Before you get out of your vehicle, move the shift lever
into REVERSE (R) and firmly apply the parking brake.
Once the shift lever has been placed into REVERSE (R)
with the clutch pedal pressed in, you can turn the
ignition key to OFF, remove the key and release
the clutch.
I usually put mine in 1st gear before shutting off the engine to keep the clutch/torque tube rattle down. No mention of not putting it into reverse will drain the battery. I think that was just some weird snafu engineering thing that happened in 2005.
