License plate caper
Old Sep 29, 2013 | 10:19 AM
luvlake's Avatar
luvlake
Default License plate caper
Bottom line if I don't care or there is no height restriction in my state, can I take the curved gm insert with Corvette on it and drill 4 holes, bend the plate a bit and attach the plate?
Old Sep 29, 2013 | 10:57 AM
millpond's Avatar
millpond
Yes, you can bend the plate and mount it.
Old Sep 29, 2013 | 12:29 PM
LUVMINE's Avatar
LUVMINE
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
I think you should be good to go. They won't give it a second look.
Old Sep 29, 2013 | 12:34 PM
Bill B 1's Avatar
Bill B 1
I'll make it work one way or another....no way in He11 will I put that awful plat holder on!
Old Sep 29, 2013 | 12:40 PM
Glenmcp's Avatar
Glenmcp
Seems like you need to find out what your State's law is.
Old Sep 29, 2013 | 01:05 PM
Jesterissimo's Avatar
Jesterissimo
And swiftly ignore it. Unless you use those toll booth transponder tags where the cameras have to see you plate when you drive through I doubt anyone is gonna notice. If it looks factory fit they'll assume its legal as long as you don't give them some other reason to scrutinize you.
Consider it your act of defiance against the man keeping you down
Old Sep 29, 2013 | 01:11 PM
Bill B 1's Avatar
Bill B 1
I'm not even going to bother putting one on. We do have a front plate law here in Montana, but I see Vettes all the time without it. I'll take my chances and wait till I get stopped told I have to have it.
Old Sep 29, 2013 | 01:18 PM
MeanDean43's Avatar
MeanDean43
I certainly hope they wash their hands before they 'scrutinize' me!
Old Sep 29, 2013 | 02:11 PM
Glenmcp's Avatar
Glenmcp
I read your post and felt as if I traveled in time to a 1960's hippie protest demonstration.
Old Sep 29, 2013 | 02:14 PM
Bill B 1's Avatar
Bill B 1
Hows it going Dean?? I cant wait to give you the call!
Old Sep 29, 2013 | 02:18 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
You do not live in TX do you ? Our fine is $200.00 for no front plate now.
Old Sep 29, 2013 | 02:20 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Or at least use KY jell right ?
Old Sep 29, 2013 | 02:24 PM
Jesterissimo
I didn't say to leave the plate off - you'd get caught pretty easy - I said to ignore the height requirements. I really doubt the troopers are gonna have a tape measure on their belt to fine you for having the plate mounted 2 inches too low.
Old Sep 29, 2013 | 02:45 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Unless you go back now and change it, nowhere in your first post did you mention the height requirement. Thus, my response.
Old Sep 29, 2013 | 02:55 PM
Jesterissimo
Read the OP's post - he's asking about mounting the plate on the curved panel instead of the high bracket - so this entire thread is about the height requirement.
Also notice my post where I said if it looks factory fit they'll assume its legal - obviously I'm referring to using the curved panel, not leaving the entire plate off.
Old Sep 29, 2013 | 03:18 PM
luvlake's Avatar
luvlake
I believe the rule in Missouri is no lower than 8 inches and no higher than 46 inches. I really don't care about the height, it probably is Ok. I just wanted to know if I could drill some holes in the curved bracket and mount it on it. I'm not using that flat bracket and up with a bracket that looked like the factory C6 bracket. I'm sure someone will come with something similar to how they did the c5 clear bubble plate holder.
To License plate caper
