The white stuff
Git 'er dun!
Also, the initial subject referenced driving on snow which is quite different from driving in wet, icing, or hydro planing conditions. As long as one understands at what speed his/her tires will hydroplane, hydro planing scenarios aren't that problematic.* And, WX Mode will do absolutely nothing to help with hydroplaning. And, ice is ice.
Driving on packed snow is different but not all that hard. But driving a C5 or C6 in somewhat deep fresh powder or deep slushy snow is what is potentially problematic for mechanical issues perhaps more than handling issues all of which brings us back to tires, technique, and judgment. Because of the intake design on the C7 many of those mechanical damage issues have likely been minimized, but that design process had little or nothing to do with driving in snow.
But it still largely boils down to knowing how to drive and having the right tires and the Michelin PSS high speed summer tires are not exactly wet winter snow tires so, the WX Mode on a stock C7 is is only going to do so much.
* NASA says a tire can begin to hydroplane at a speed equal to 9 times the square root of your tire pressure. The NTSB says to use 10.35 instead of 9. I would tend to trust the more conservative NASA number which would be about 49 MPH for most Corvettes. With tires over 305 I would hazard the number might be more like 40-45 MPH?
You just have to be careful on fresh powder and not bottom out. With good snow tires my rear wheel drive bimmer will go up hills suvs with all season tires cant. The expressions on the stuck SUV drivers getting passed by a little rwd 335 is hilarious.
However, do not drive a Stingray with the Michelins if you get a frozen tire warning message. The tires will crack.
