Crazy problem-seat will not move back!
Old Nov 3, 2013 | 08:25 PM
Periokid's Avatar
Periokid
St. Jude Donor '06
Default Crazy problem-seat will not move back!
I moved the driver's seat forward to install the rear luggage cover.
I then went to drive the car and the seat will not move back. I will move forward but no backward. The seat switch does nothing, the memory buttons do nothing. Easy exit button does nothing. I can't even drive the car, I can't fit!
Any suggestions?
Old Nov 3, 2013 | 08:33 PM
c54u's Avatar
c54u
if you can reach under the seat, make sure the connectors are all securely connected.
check your fuses.
you may also try to disconnect the battery for about 30 secs to see if that resets something.
if that all fails, tow to the dealer.
Old Nov 3, 2013 | 08:42 PM
Periokid's Avatar
Periokid
St. Jude Donor '06
The seat moves forward and tilts forward, does not tilt back or move back. So strange. I'll check the items you suggest.
Old Nov 3, 2013 | 10:05 PM
Periokid's Avatar
Periokid
St. Jude Donor '06
I wonder if it is the safety switch under the carpet behind the driver's seat. It is designed to prevent the seat from moving too far back. I was leaning behind the seat to install the luggage cover. Maybe the switch is faulty? I picked up the carpet and it is a long strip of contact switches.
Old Nov 3, 2013 | 10:34 PM
Slappy3243's Avatar
Slappy3243
This happened to me back when I owned my GTO. It was always a caused by a fuse in that case. It was a common problem on that vehicle but a quick fix. Hopefully it's something simple like that for you .
Old Nov 4, 2013 | 07:53 AM
Periokid's Avatar
Periokid
St. Jude Donor '06
What confuses me is that if it was a fuse, it would not move forward tilt forward. Only movement in the rear direction is dead. It won't tilt back or slide back. Forward, no problem.
Old Apr 18, 2015 | 08:59 PM
Tom Henson's Avatar
Tom Henson
5th Gear
I just had this problem this morning with the passenger seat, went to clean behind the seat. Moved it all the way forward, and all the way as well on the forward tilt. Guess what, won't move back. Won't go any direction. Took it to the Dealer, they will have to get ahold of GM techs. They first tried a software update, that did not work. Did the Dealer get the problem fixed? Thanks
Old Apr 18, 2015 | 09:04 PM
C8Jake's Avatar
C8Jake
make sure the seat back is latched
Old Apr 18, 2015 | 09:07 PM
Tom Henson's Avatar
Tom Henson
5th Gear
It's at the Dealer, Nothing moves. Front back, up down, unable to lift the side latch and won't move it either. Thanks
Old Apr 18, 2015 | 09:24 PM
KOMCZYK's Avatar
KOMCZYK
Default Seat travel limit
Any suggestions?
I have had the same experience. Solved the problem after referring to the owner manual in sections 3-5 and 3-6 which reference "Seat Travel Limit" and "Obstructions". Persevere!
Old Apr 19, 2015 | 06:29 AM
Gk1359's Avatar
Gk1359
Any suggestions?
I have had the same problem. On the back of the press the release button,then tilt the back of the seat forward, then put back in place. There must be a sensor in the seat,this happened to me when I did a mirror tap.good luck hope this helps?
To Crazy problem-seat will not move back!
